E52 RM-469 v51.018 SEAP
AquaSta
Moderator
E52 RM-469 v51.018 SEAP South East Asia Pacific - Khu vực Đông Nam Á
Dung lượng: 111MB
DP Information:
DP Name: 051.018_SEAP
DP Filename: rm469_CareDP_7.0_051.018_SEAP
DP Type: Care
DP Version: 7.0 MAJOR
Description: 051.018_SEAP
DP Content:
0592205 051.018 THAI White Al
0590967 051.018 APAC1 CAMBODIA Golden Al
0578079 051.018 VIETNAM Metal Al
0586660 051.018 APAC1 MALAYSIA Golden Al
0591703 051.018 APAC1 Black Al
0590966 051.018 APAC1 CAMBODIA Metal Al
0590396 051.018 APAC2 PHILIPPINES Golden Al
0591710 051.018 APAC2 AUSTRALIA Black Al
0578077 051.018 APAC1 Metal Al
0586662 051.018 APAC1 MALAYSIA Metal Al
0592200 051.018 APAC1 MALAYSIA White Al
0591715 051.018 THAI Black Al
0591708 051.018 APAC2 PHILIPPINES Black Al
0584119 051.018 HONGKONG Golden Al
0581292 051.018 APAC2 PHILIPPINES Metal Al
0591714 051.018 INDIA Black Al
0581291 051.018 APAC1 INDONESIA Metal Al
059B9B4 051.018 INDIA Golden Al
0592204 051.018 APAC2 VIETNAM White Al
0592201 051.018 APAC1 INDONESIA White Al
0578083 051.018 HONGKONG Metal Al
0584116 051.018 APAC1 INDONESIA Golden Al
0578080 051.018 INDIA Metal Al
0591712 051.018 APAC2 BANGLADESH Black Al
0578081 051.018 THAI Metal Al
0591704 051.018 APAC1 CAMBODIA Black Al
0591711 051.018 APAC2 NEW ZEALAND Black Al
0591717 051.018 HONG KONG Black Al
0578082 051.018 TAIWAN Metal Al
0592203 051.018 APAC2 BANGLADESH White Al
0593542 051.018 APAC2 NEW ZEALAND Metal Al
0584115 051.018 APAC1 Golden Al
0592202 051.018 APAC2 PHILIPPINES White Al
0591713 051.018 VIETNAM Black Al
0591707 051.018 APAC2 Black Al
0580194 051.018 BANGLADESH Metal Al
0591716 051.018 TAIWAN Black Al
0584117 051.018 THAI Golden Al
0591705 051.018 APAC1 MALAYSIA Black Al
0584118 051.018 TAIWAN Golden Al
0578078 051.018 APAC2 Metal Al
0592199 051.018 APAC1 CAMBODIA White Al
0581293 051.018 APAC2 AUSTRALIA Metal Al
0592198 051.018 APAC1 White Al
0591706 051.018 APAC1 INDONESIA Black Al
0586661 051.018 VIETNAM Golden Al
DP tracking:
Filename: DpSpec.xml
Timestamp: 2010-08-23 at 09:33
Tool: CST 8.35a
Download torrent (tốc độ tốt)
Rapidshare
Download Firmware Vietnam: http://www.mediafire.com/?2ia3awg1cnzg58o
Những cập nhật trong phiên bản mới là:
* Browser upgrade to 7.2.6
* QuickOffice upgrade to 6.2.439
* Office 2007 compatibility improved
* OVI Music client update
* Lotus Notes Traveller 8.5.1 update
* myNokia update
* OVI Store 1.6 update
* OVI Sync 2.0 update
* OVI Files widget 1.2.3.0 update
* Nokia Chat 2.0 added
* Email, calendar, contacts improved
* Performance, stability & usability improvements
ủa sao mình check navifirm vẫn chưa có mà sao bạn có được firmware đó vậy
Hình như bản này chỉ dành cho DeveloPer nên có tên đây đủ là E52 RM-469 CareDP 7.0 051.018 SEAP. Nếu bạn dùng phần mềm cập nhật FW của Nokia thì chỉ có FW 34.001 mà thôi.
Nếu bạn thích thì có thể lên trang web này tải về
Nokia đã cho phép upgrade lên phiên bảng 51.018 bằng OTA và software rồi đó. Những thông tin ban đầu
* Web browser upgrade to 7.2.6.2.
* QuickOffice upgrade to 6.2.558.
* Thêm Ovi Sync trong phần Applications.
* World Traveler upgrade to 1.5(4) (Nếu upgrade bằng tay thì sẽ tốn thêm bộ nhớ máy).
* Nokia Map upgrade to 3.03 nhưng không có bản đồ chi tiết cho VN.
* Realplayer upgrade?
Các bác cho em hỏi, em đang up thì bị mất điện, giờ máy bị dead phone, ko khởi động được, đã thử qua JAF và Phoenix mà không được ạ, cao thủ nào giúp em với
Nếu ở HN mang qua mình xem thử.
Nếu còn bảo hành thì qua Nokia Care còn không thì nhờ bác habaolinh vậy
em cũng như bác này đi lên nokiacare sửa.lên lấy máy thì nó nói thay board rồi.Như vậy có phải là luộc đồ ko các bác:((
Thay board chưa chắc bị luộc đồ. Có thể là board mới 100%. Bạn k an tâm thì nhờ ai đó rành về điện thoại mở ra xem board như thế nào.
down về rồi thì up làm sao đây bạn? mình giải nén rồi copy vào C:\Program Files\Nokia\Phoenix\Products mà sao phoenix không nhận ra fimware vậy nhỉ?máy mình e52 469 v051.18 mình muốn hack để cài vietmap.mong các bạn chỉ cho vì mình lần đầu up cho nokia
