E72 bi dead phone khi flash bằng phonenix
phandinh2610
Tình hình là em có flash lại cho e72 bằng phonenix thì bị dead phone, từ hum qua tới giờ cũng đã search đủ kiểu cứu phone bẳng phonenix ở chế độ dead phone nhưng không được và cứ báo lỗi:
Flashing started
Creating product data items list
Product data items list created
Backup not required
Flashing phone
Initializing
Scanning image files...
Waiting for USB device...
Loading secondary boot code: 15168 bytes
Secondary boot loaded
BB Asic Index is: 00
Asic ID is: 000000030000022600010007600C192102011104
EM Asic ID is: 00001040
EM Asic ID is: 00001030
Public ID is: 09100119DC6C0344333A2125573E3F3ACBB24981
Asic Mode ID: 00
Hash: 25B977A055BE9B5DEC0C38A2A279C695
ROM ID: 3E273BF637BE26FA
Device type is: 05
Device Index is: 00
Manufacturer code: 0000
Device ID: 0000
Extended device ID: 0000
Revision ID: 0000
Device type is: 04
Device Index is: 00
Manufacturer code: FFFF
Device ID: 0000
Revision ID: 0000
Device type is: 00
Device Index is: 00
Device ID: 0000
Revision ID: 0000
Device type is: 00
Device Index is: 01
Device ID: 0001
Revision ID: 0000
Device type is: 03
Device Index is: 00
Manufacturer code: 00EC
Device ID: 0058
Revision ID: 0121
Loading update server code: 812840 bytes
Update server loaded
Asic CMT: Start programming 190441 KB...
Asic CMT: Programming data sent: 0%
Asic CMT: Programming data sent: 10%
Asic CMT: Programming data sent: 20%
Asic CMT: Programming data sent: 30%
Asic CMT: Programming data sent: 40%
Asic CMT: Programming data sent: 50%
Asic CMT: Programming data sent: 60%
Asic CMT: Programming data sent: 70%
Asic CMT: Programming data sent: 80%
Asic CMT: Programming data sent: 90%
Asic CMT: Programming data sent: 100%
Programming complete
Asic CMT: Verifying communication to device...
Waiting for communication response: 25
Waiting for communication response: 24
Waiting for communication response: 23
Waiting for communication response: 22
Waiting for communication response: 21
Waiting for communication response: 20
Waiting for communication response: 19
Waiting for communication response: 18
Waiting for communication response: 17
Waiting for communication response: 16
Waiting for communication response: 15
Waiting for communication response: 14
Waiting for communication response: 13
Waiting for communication response: 12
Waiting for communication response: 11
Waiting for communication response: 10
Waiting for communication response: 9
Waiting for communication response: 8
Waiting for communication response: 7
Waiting for communication response: 6
Waiting for communication response: 5
Waiting for communication response: 4
Waiting for communication response: 3
Error 0x8401F121 communicating to phone. Unable to verify comm.
Warning: Unable to communicate to product after flashing
Starting to recover the phone
Recovering phone
Initializing
Phone recovery completed. Waiting for phone to boot up
Bootup successful
Verifying communication to product (before flash finalizing)
Failed to verfy communication to product
All operations completed
Firmware updating failed.
HRESULT 0x8421001c (-2078212068)
Firmware: Cannot verify communication to phone after flashing. Make sure that phone booted up correctly and retry.
Các bác cho em hỏi máy em giờ nên xử trí ntn, sinh viên nghèo ko có tiền đem ra nokia care chạy lại phần mềm,có bác nào bik chổ nào chạy lại bằng box chuyên dụng mà giá rẻ chỉ em với.Thanks các bác nhiêu ............!
JAF mới cứu đc deadphone thôi bạn à !
Tham khảo các bài viết dùm JAF nhé !
Cẩn thận chạy bị mất log đó, nó báo thế là lỗi không đồng bộ được sau khi flash xong. Nên đưa ra thợ có BOX chuyên dụng để cứu đi.
bạn thử flash dead phone bằng bản Phoenix_Service_Software_2010.08.004.41526_crack xem sao...hqua mình up cũng bị dead fone phải flash lại = bản Phoenix kia..
Flashing started
Backup not required
Flashing phone
Initializing
Asic Mode ID: 00
Device type is: 05
Device Index is: 00
Device ID: 0000
Revision ID: 0000
Device type is: 04
Device Index is: 00
Device ID: 0000
Revision ID: 0000
Device type is: 00
Device Index is: 00
Device ID: 0000
Revision ID: 0000
Device type is: 00
Device Index is: 01
Device ID: 0001
Revision ID: 0000
Device type is: 03
Device Index is: 00
Device ID: 0058
Revision ID: 0121
Recovering phone
Initializing
Bootup successful
Trong quá trình tải FW ở NaviFirmPlus bạn chọn Nokia care Suite nhé ? Không nên chọn ở Production External , và nhớ chọn FW mới nhất nhé ? Chúc thành công
nếu cứu không được thì bác thử dùng bản Phoenix 2010 , bản 2011 nhiều khi không tốt bằng , còn vẫn bó tay , thì liên hệ , em giúp tiếp : nguoilinhchinhutnhat8891 ( online tầm 20h00 trở đi )
