Emulador Final Burn V0.0011 CPS1, CPS2, CPS3, Neo geo (Game Giả Lập)
nthoa87
It copies the executable one for a folder created for you called FinalBurn in your card (SD/MMC/etc). When opening executable it to go for the first time? to create the folders that it needs to function. To play the ROMS are enough to you to copy all that to want for folder ROMS. To run necessary games NEOGEO of the BIOS in the same folder of the ROMS, pods to draw it in one more below pack. When very great loading ROMS it creates one cache so that of the following times he can soon start to play, without needing to load, alternatively pods to use a program it PC to create cache for yours pocket, later moves the filing-cabinet bred of the PC for pocket. You also have the necessary material for this in one pack in the end of this post. When opening a ROM it shows to you to all the ones that can run or only the ones that ROM finds in the folder
http://img99.imageshack.us/img99/3146/screen001gd0.jpg
If you it does not appear some game that you have there is because you still do not have the versions that it supports. To configure keyboard keys: After loading a game you have to configure its keyboard keys, the keyboard keys are recorded separately for each ROM. I have a Qtek S100 and use to that lying with a hand for the keyboard keys that I have in top (camera and recorder) for A and B and to another hand for the directional keyboard keys and keyboard keys you add. In the fight games I advise to be with high punch and high kick in the hand of the right and others that interest you to use as aid in the hand of the movements left
Example:
http://img460.imageshack.us/img460/3769/teclasad6.jpg
Links down rom:
http://vgbr.com/forum/lofiversion/index.php?t25584.html
Link down chươnng trình ở đây
http://www.box.net/shared/rujdzst0ck
cái này theo hình thì là cho phone edition chứ có phải cho smartphone đâu bạn
thử pass nthoa87 hay pdaviet.net xem sao :D
mình sài được cho mpx220 mà bạn ơi
up lại đi bạn ơi. không thể down được
nó báo như sau:
This user is out of bandwidth.
Please email support@box.net for support or upgrade for more bandwidth
cái này cứ copy vô thẻ nhớ rồi chạy trực típ từ máy đc mà
đã test trên HTC S620
các bác ơi ,làm sao cài dc roms cho cái này , cả chìu hum nay em down roms cho nó mà cop zô thì nó lại hok nhận
