EquiLibriuM by Team DroiD | based on N97v30 | 5800, 5233, 5230, 5530, X6|All RMs
shashwat
CFW Name: EquiLibriuM
CFW Creator: Team Droid Xtreme.Infinity & shashwatt
Model : Nokia 5800, 5233, 5230, 5530, X6
Supported RM's : All RM supported
Base Firmware : N97v30.0.004
Release Date : 10-January-2012
Languages Present : English
Credits :
PNHT Team
Thanks to binh24 for N97v30 port
Mods and Resources :
dan-av, CODeRUS, die2mrw007.
10202be9 (Cenrep) Description Files :
Szakalit, CODeRUS.
A Special Thanks to Twin Tigers for developing Splashscreens :)
Ringtone modified from Dj Tiesto Bright Morningstar... Dj Tiesto's courtesy..
Credits to our beta-testers.. $o $eRiOu$, tristar2, Gaurav.Pratim, vishalalok
nhelske for making awesome Android Theme Effects...
Boot animations and sound from Krystal CFW.
Now the credits to that person without whose efforts and helps this project wouldn't have been possible..A very good friend and always helpful pal..Hey Nitya...Thnx bro..:)
Screenshots:
EXCLUSIVE POWERSUITE
AT STARTUP
MESSAGING:
Messages sent by you will be saved up to 500 messages
Delivery reports ON by default
Messaging application no longer lags when containing large number of messages
4x11 Qwerty + Alphanumeric keypad added with Auto rotate QWERTY
Default memory assigned to C:/ for better performance
N8 Emotions Support(Smiley)
6 page custom symbols support
MENU:
Glossy Anna Icon Pack
All Lags in Menu removed
Optimized to run very fast and smooth (Tweaked Kinetic Scrolling in Menu)
6x2 N8 landscape grid layout for Menu
MULTIMEDIA:
Camera will not leave in background after exit (SAVES RAM)
Voice recorder set to High quality
Voice recorder records upto 14 hours
Voice Recorder will save the file in E:\
Camera Image Quality improved
Camera already in use bug solved completely
Gallery searching improved
OVI Music removed from Music Homescreen
Video Capture predefined frame rate increased to 25fps
Music Player will read E:\Music\
Music player will refresh faster
One touch N8 Equalizer
Sound quality optimised to smooth and better quality experience
FILE MANAGER:
Nokia default file browser can send sisx, sis, jar and any protected items via bluetooth, mms and uploads
BROWSER:
New and Improved Belle UI Web Browser
Supports HTML5
Download manager will be started on browser start-up to resume
Browser will prompt to continue download if connection breaks due to power failure
Browser Cache set to C:\
- Default Homepage set to http://www.ovi.com
Auto form data save activated
INSTALLATION FEATURES:
Java permission is set to default
PNHT installserver patch added (Now install any unsigned apps).
Secure Widget Preinstall (OVI Store Installer) will not run on first startup but will install at one click from menu icon
LIGHTS BEHAVIOUR:
- All lights bugs fixed! (thanks again to die2mrw007)
- Green Charging light disabled.
- Breathing light OFF by default
- Tap to unlock support
- All lights off when charging in Switched OFF state
- Lock/Unlock vibration removed
GRAPHICAL PERSONALISATIONS:
- EquiLibriuM customized SplashScreen and ShutdownScreen.
- Bootscreen Volume set to : 07
- Custom Boot/Shutdown animation locations -
E:\Boot\
Startup.mp3
HOMESCREEN:
- Widgetized Nokia Homescreen
- Full widgets support
- 5 Additional shortcuts bar. Total : 6
- Swipe to clean HS (clock widget removable)
- Original Belle dialer icon
- "0" activates KillMe app instead of Web Browser
Camera:
- Increased fps to get better quality shots
- camera completely fixed!
- "camera already in use" bug fixed
- Touch UI capture button working
General Modifications :
- "Restart" Option instead of "Lock Screen and Keys" in Power Menu by CODeRUS.
- Glossy Anna Icon Pack is used. (With 0 bugs) Now icons change according to the theme applied.
- Tap to Unlock added
- Camera will not eat RAM after closing it.
- Default bluetooth name: Nokia EquiLibriuM
- FOTA reserved space removed to get more space in C:\ (Phone Memory)
- Voice recording during call fixed. Your phone won't crash if you record and call someone at the same time.
- RAM Cache in C:\ for better performance
- Blazing Fast Screen Rotation
- CPU load decreased (Get a very fast phone)
- Disabled My Nokia Service. It will prevent phone to send premium message to 5555 (Nokia) after first boot.
- Zero start up of background applications
- Auto optimization of RAM cache for keeping up your phone faster even after heavy usage
- Blank UDA supplied to get highest possible free space on C:\
(rename the supplied uda.fspx file according to the original uda.fspx)
- Lags in Menu removed. The Kinetic Scrolling is optimized. Experience the fast and smooth touch feel.
- Display rotation is ON by default
- Breathing light is OFF by default
- Digital clock set as default. N8 Clock fonts used so the digital clock now looks like the N8 clock
- Calibri Fonts with symbol support added (Belle Modded)
- Operator Logo ON/OFF settings available in homescreen settings (depends though)
- Delivery Reports ON by default in Messaging
- Theme effects are OFF by default
- Removed "Check for Updates" in Device Updates
- "speed dialing" ON by default
- "In call timer" ON by default
- Profile "General" renamed to "EquiLirbiuM"
- Homescreen landscape enabled. Dialer landscape disabled.
- Tap to unlock respect sensor orientation.
- Changed the default widgets layout. Nokia Notifications with symbian anna icons widget comes preinstalled.
- Now Music Player will not return you to Menu after exiting it.
- Gallery loads faster
- Brightness mod added
- Latest Ovi Store Provided
Performance Upgrades:
- Highly Optimized Application/Gaming frame rates
- Increased Response Rate (Now touchscreen will be more responsive)
- CPU frames render was increased.This will result in a smooth phone experience.
- Graphical Complexity reduced. Performance Booster without any side effects.
- Music Player response highly increased (Instantly pauses/plays on clicking the buttons)
- Increased Heap Size further to boost up performance
- Lags in Menu, messaging and Other Large Applications removed
- Polished the UI for heavy usage
- Phone will never slow down and the RAM won't be decreasing (RAM Caching modded)
- Smooth Kinetic Scrolling
- Music Player is now a lot more faster!
- CPU mod optimized to get complete stability and a great battery life!
Ovi Maps 3.06 beta11 added with no QT conflict issues. Special thanks to debsin
REMOVED APPS :
All Default Themes, Chat, Podcasting, Image Print, OVI Contacts, OVI Music, Here and Now, Online Support, Phone Switch, My Nokia, Quick Office, Adobe Reader, Help.
Applications Added in Rofs: BTSwitch 1.0, Rom Patcher 3.1, KillME 1.36, AutoInstaller , Nokia File Browser.
Run AutoInstaller if you need: Best Screensnap , Brightlight.
Some Wallpapers are provided in Folder E:\EquiLibriuM\
ADDITIONAL MODS
Belle Navigation Mod Removal Pack by srgudhka
Procedure: Paste the files from above link in ROFS2 after extraction..Repack..JAF
INSTRUCTIONS
If you dislike the Boot Animation effects and sound, U can disable it by deleting folder named "Boot" in E:/
Please Note:
1. Before Flashing please delete folders Private, Data, Resource, cities, Sys, System and any other folders from Memory Card which are not used by you.
2. After successful flashing, wait for sometime till all the widgets gets loaded to the Homescreen.
3. Vibration in call is disabled by default. Though after first boot it will not take effect. Hence you are required to change the profile to any other and revert back to EquiLibriuM Profile. This will just solve the issue
4. Using the provided uda file with Core link is highly recommended. Failing which you may counter bugs.
Refer this Tutorial to Flash your phone with EquiLibriuM :)
The EquiLibriuM port for Nokia 5800 need to b worked upon..
Some bugs are found by the users...
We are trying our best to fix the bugs and upload the new bugless Port..
It will take about 1-2 weeks...
Your patience will b highly appericiable..Sorry for the inconvenience caused..
(rename it accordingly)
Nokia 5230
Core (v51.0.002): Click Here
Core (v51.6.002): Click Here
EquiLibriuM ROFS+uda :EquiLibriuM for 5230 RM-588
Core files version 50.0.001 or higher can be used with this rofs
(Rename the rofs file according to the Core version you use)
Nokia 5233
CORE (V50.1.001): Click Here
Core (V50.9.001): Click Here
Core (V51.1.002): Click Here
EquiLibriuM ROFS+uda :EquiLibriuM for Nokia 5233 RM-625
Core files of v50.1.001 or higher can be used with this rofs
Nokia X6
CORE (v32): Click Here
CORE (v40): Click Here
EquiLibriuM ROFS+uda : EquiLibriuM for RM-559 X6
Nokia 5530
Core (v32): Click Here
Core (v40): Click Here
EquiLibriuM ROFS+uda :EquiLibriuM for 5530 RM-504
For Suggestions or any Queries,Find us hêre:)
Lastly, THANK YOU FOR CHOOSING EQUILIBRIUM..ENJOY
Tiếng Việt :
Hỗ trợ tất cả các RM
Ported từ N97v30.0.004
Ngày đăng : 10-01-2012
Ngôn ngữ hiển thị : English
Credits :
PNHT Team
Cảm ơn binh24 for N97v30 port
Szakalit, CODeRUS.
Đặc biệt cảm ơn Twin Tigers vì cái Splashscreens :)
Nhạc chuông lấy từ Dj Tiesto Bright Morningstar... Dj Tiesto's courtesy..
Cảm ơn những người đã test trong suốt thời gian beta $o $eRiOu$, tristar2, Gaurav.Pratim, shalalok
Cảm ơn nhelske nhờ hiệu ứng Android Theme Effects tuyệt hảo
Hình và nhạc lúc khởi động lấy từ Krystal CFW.
Và cảm ơn người bạn tuyệt vời đã nỗ lực giúp đỡ tôi trong suốt quá trình hoàn thành CFW này..Hey Nitya...Thnx bro..:)
Add thêm bộ Power Suite: Lock, restart, shutdown (1 chạm)
Nhắn tin:
Lưu 500 tin gửi đi
Mặc định nhận thông báo đã gửi tin nhắc (delivery report)
Trình nhắn tin vẫn ổn định khi có nhiều tin nhắn
4x11 Qwerty + Alphanumeric keypad tự chuyển sang QWERTY khi xoay ngang
Bộ nhớ mặc định ở ổ C:\ giúp truy cập nhanh hơn
Mặt cười N8
6 trang kí tự
MENU:
Fix lỗi lag khi truy cập menu
Chạy nhanh vào mượt (Tweaked Kinetic Scrolling in Menu)
Menu 6x2 landscape
MULTIMEDIA:
Trả ram khi thoát camera
Ghi âm ở mức High
Ghi âm 14h liên tục
File ghi âm lưu ở E:\
Tăng chất lượng ảnh chụp
Fix lỗi Camera Already In Used
Tăng tốc độ hiển thị Gallery
Xoá OVI Music
Tăng lên 25 khung hình/giây khi quay phim
Có thể chụp hình bằng nút cảm ứng
Quét file nhạc ở E:\Music\
Tăng tốc cập nhật thư viện nhạc
Âm thanh mượt mà và sắc nét hơn
FILE MANAGER:
Gửi mọi file qua bluetooth, mms và uploads
BROWSER:
Trình duyệt với UI của Belle
Hỗ trợ HTML5
Tiếp tục Download khi khởi động lại trình duyệt (có popup thông báo)
Cache ở C:\
Trang chủ http://www.ovi.com
Lưu tên và password cho các web (auto form data)
Hacked với installserver
Không cài sẵn OVI Store Installer, sẽ hoạt động khi ấn vào icon ovi store
Đèn:
- Tắt đèn xanh khi sạc
- Tắt lim dim (có thể enable trở lại)
- Tap to unlock
- Tắt đèn khi sạc ở trạng thái switch off
- Tắt rung khi khoá máy
- hình nền khởi động của EquiLibriuM
- Âm lượng khởi động ở mức 07
- Thay đổi hình và âm khởi động ở E:\Boot\Startup.gif và Startup.mp3
HOMESCREEN:
- Widget và 5 shortcut bar
- Ẩn được profile widget
- Ấn 0 sẽ vào KillMe (thay vì vào web)
Các mod chính :
- "Restart" thay cho "Lock Screen and Keys" khi ấn nút nguồn (by CODeRUS).
- Glossy Anna Icon Pack, thay đổi theo theme
- Xoá FOTA ở C:\
- Ghi âm và Gọi đồng thời mà không sợ die máy
- RAM Cache in C:\
- Xoay ngang màn hình với tốc độ cực nhanh
- Giảm thời gian load CPU
- Tắt tin nhắn từ My Nokia
- Tắt các chương trình chạy nền
- Tự làm sạch RAM kể cả sau khi chạy các ứng dụng nặng
- File UDA đính kèm không chứa thông tin => tăng dung lượng ổ C
- Menu mượt mà, không lag
- Bật sensor
- Tắt đèn lim dim
- Đồng hồ điện tử N8 (font chữ số N8)
- Calibri Fonts hỗ trợ kí tự và Belle Modded
- Logo mạng có thể chỉnh tại homescreen setting
- Tắt Theme effects
- Xoá "Check for Updates" trong Device Updates
- Xoay ngang Homescreen. Không xoay ngang Dialer
- Tap to unlock có thể xoay ngang (phụ thuộc vào trạng thái hs khi khoá máy, không tự động xoay)
- Sắp xếp lại widget mặc địch, hiện notifications
- Không vào lại menu khi thoát music
- Tăng tốc hiển thị Gallery
- Thêm mod điều chỉnh độ sáng
- Store mới nhất
- Tăng tốc và khung hình khi chơi game
- Cảm ứng nhạy và nhanh hơn
- Máy chạy mượt mà nhờ CPU render nhanh hơn
- Giảm chi tiết đồ hoạ để tăng tốc hoạt động
- Music Player đáp ứng tốt hơn (ví dụ pause/play ngay khi ấn nút, không có lag)
- Không lag. từ menu, tin nhắn đến các ứng dụng khủng
- Cải thiện UI cho các máy chạy vs cường độ cao
- RAM sẽ không bị mất dần trong thời gian sử dụng
- Music Player nhanh hơn rất nhiều
- CPU mod để máy ổn định hơn và tối ưu pin
Ovi Maps 3.06 beta11 không bị xung đột với QT.
Ứng dụng đã xoá :
Ứng dụng cài sẵn: BTSwitch 1.0, Rom Patcher 3.1, KillME 1.36, AutoInstaller , Nokia File Browser.
Chạy AutoInstaller sẽ cài sẵn: Best Screensnap , Brightlight.
Một số hình nền có sẵn trong Folder E:\EquiLibriuM\
INSTRUCTIONS
Nếu không thích hình và âm khởi động thì các bạn cứ xoá Boot ở ổ E (riêng mình thì thấy nó rất ảo, không biết có phải phong cách của cfw nước ngoài nó vầy không, rất hổ báo =)))
Please Note:
1. Trước khi Flash, xoá các folder data, private, resources, cities, sys, system và các thư mục "lạ" trong ổ E (do các fw trước tạo ra)
2. Sau khi flash, chờ một lúc để các widget load và chạy ổn định
3. Tắt rung khi thực hiện cuộc gọi. Có thể sẽ không có hiệu lực sau khi flash, bạn chỉ việc đổi qua lại các profile là được
4. Dùng file UDA của tôi để tránh bug
các bác test thử ra sao đi...sao chằng có ngôn ngữ tiếng việt gì cả....chắc phải google dịch quá....lần đầu tiên thấy người nước ngoài post bài bên Việt nam...
Question is this version that supports C5-03 is not so foreign citizens ban.ban real game.
thực sự tôi biết không có tiếng việt, chỉ cần đăng CFW của tôi ở đây, xin lỗi nếu tôi đã làm một cái gì đó sai: (
em đã test rồi.nói chung là được nhưng mod belle khi vào web vẫn còn bị lỗi ký tự,ngoài ra ram thấp,chưa cài gì ma ram chỉ có 34MB
chú ý lần sau k quote nguyên bài nha bạn luutanvu
@haydenvoitoi_6 : bài đã dài kon` quote cả bài x(
@shashwat: Nếu có thể, bạn edit bài, cho bớt hình ảnh vào code thẻ ẩn nội dung.tks!
khởi động lại nó và ram của nó sẽ là 57 mb
tôi đã không có được bạn, tôi mới ở đây
Tested...Good Firmware....Tks u so much.....ram 61,2mb, not 34mb :D
không có vấn đề giao phối, nó dựa trên n97v30, vì vậy tốt nhất trong ram
làm thế nào để tôi làm cho nó cho các bạn, tôi có nghĩa trong tiếng việt, bất kỳ cơ thể có thể làm cho nó cho tôi?
you can write english and we can understand it, please don't use google translate
Can you support into vietnamese version ,pls ?
k có tiếng việt đâu, tự add mà add hay bị lỗi lắm, dùng tiếng anh đi
không có font tiếng việt cho người việt anh ơi ( nếu xem văn bản tiếng việt sẽ bị hiện cá kí tự như mũi tên)
