[final] - Wrcx 5.2.1437 - 3 Roms
support
Xin được phép để nguyên văn của tác giả nhé
WRCX Roms (5.2.1437)
Core: 5.2.1437.17944.301
I have ported this rom from the latest dopod hermes rom (More space in Memory Map than Trinity)
The OEMDRIVERS folder has finally been rebased! So no-more random power offs, also I tidied up OEMAPPS
so now everything works perfectly (sim_tkit,etc).
Unfortunately this may quite possibly be my last public rom release (apart from the upcoming kitchen)
due to the high number of "fuckwits" also known as wannabe chefs.
You guys SUCK, and I mean S-U-C-K, You make no attempts to improve the OS you merely want all the
credit for pasting some OEM Packages into the build. LAME - Even lamer are those
who make a kitchen from my kitchen, I mean COMEON you are doing less work than the wannabe chefs!!
I reckon by now everyone has got the gist, I just plead to WM6 users not to donate to wannabe chefs
and put the money into something worthwhile.
ANYWAY...Moving on....
My thanks going out to:
cmonex - My partner in crime
Bepe - Thanks for Xipport, Pkgtool and BuildOS
mamaich - Thanks for imgfs_tools
Today you get 3 Roms from me, Info below.
WRCX 1 (Classic)
OEM Applications:
ArcsoftMMS=4_0_31_23
AudioManager=1_2_614712_q (Non Touch Skin)
BT_BPP=1_5_0_0
BT_FTP=1_2_30234_2
BT_SAP=2_02_b0925_r3
Camera=3_00_25498_AKU20
JbedJava=0_0_20070622_2_1
JeyoInformer=2_2_0_419
NetworkWizard=1_0_29982_4
SpriteBackup=5_1_0_WWE
StreamingMedia=2_20_615718_00 (Non Touch Skin)
SymbolPad=1_0_24876_11
TaskManager=1_51_30229_1
VoiceRecorder=1_10_611711_0
ZIP=1_20_27596_0
HTC Bluetooth QuickLink
Modaco NoData
SetupVoIP
SoftKeyApplet
OS Modifications
Removed:
AUTOUPDATE
Catalog
SQM (Service Quality Monitoring)
CEIPUI (Customer Experience Improvement Program)
Transcriber
Replaced:
MXIP_NOTIFY.VOL (Removed call to CEIPUI)
Added:
VoIP
WPCTSC (Terminal Services aka Remote Desktop)
Screenshots
Download:
http://rapidshare.com/files/60388358/WRCX1.exe
WRCX 2 (TouchFLO)
OEM Applications:
BT_BPP=1_5_0_0
BT_FTP=1_2_30234_2
HTCHome=1_5_620722_0
ZIP=1_20_27596_0
PHONE_CANVAS=1_0_27507_0
SMART_DIALING=2_5_27526_0
Modaco NoData
SetupVoIP
SoftKeyApplet
OS Modifications
Removed:
AUTOUPDATE
Catalog
Transcriber
WindowsLive
Replaced:
Added:
VoIP
Screenshots
Download:
http://rapidshare.com/files/60388292/WRCX2_touchflo.exe
WRCX 3 (Best Of Both, My Favorite)
OEM Applications:
BT_BPP=1_5_0_0
BT_FTP=1_2_30234_2
Modaco NoData
SetupVoIP
SoftKeyApplet
OS Modifications
Removed:
AUTOUPDATE
Catalog
Transcriber
Replaced:
Added:
VoIP
Screenshots
Download:
http://rapidshare.com/files/60388373/WRCX3.exe
Plain SplashScreen
Screenshot
Download:
http://rapidshare.com/files/48008146/WM6_Splash.exe
Have Fun Guys!!
Hic hic, muốn test quá mà có ai up lên hót khác giúp em cái ko ?
cảm nhận ban đầu là Rom chạy rất smooth, không ngờ lại good như vậy. mình dùng wrcx2
Đã có bác nào chạy wrcx3 chưa, các bác có thể so sánh với NBD 8.2 cho mọi người biết với ?????
Đã chạy thử wrcx3, bản thân em thấy có vẻ thích hơn là octaivoi 4.0, dù thiếu nhiều config tùy chọn hơn, chắc phải tìm mấy cái đó thêm vào xem sao.
Mình dùng wrxc1, rất ngon. Độ lên 8mb pp chạy ầm ầm, tuy chỉ kém TNT3.0 tí xíu nhưng rất tiết kiệm pin, nghe nhạc 2h30 phút liên tục và 1 vài cuộc gọi hết 30% pin!
Trên đây là cảm nhận của mình
Mình cũng đang dùng wrxc1. Rất ổn định và rất nhanh. Rom còn ở dạng vanilla nên phải cài thêm nhiều phần mềm cần thiết.
con này so với WM6 Pro3 thế nào các bác.
Em kết bộ SPB nên kô dùng TouchFlo-dang cần uprom mà chưa biết nên dùng con này hay Pro3
Bạn nên dùng ROM này đi, ROM này đi với Spb Shell nữa là tuyệt vời, lên PP 6MB hoặc 8MB tùy bạn, chạy rất ngon :D
e cũng mê cái touch flo, nhưng ko biết nên up cái nào, wxc3, wxc2 hay pro3 hay NBD 8.3 nữa. Bác nào có kinh nghiệm thì chia sẻ với. ;;)
Thanks
Nếu mê TouchFlo thì corbi dùng thử octaivoi4.0 đi ^^ mình thấy Touch bản đấy rất ổn và nhạy :)
Bản rom này dùng có vẻ ổn đấy.Tuy nhiên nếu thêm một số phần mềm Việt vào để xài thì ngon hơn nhỉ.
Ngày mai rỗi rảnh cook một bộ dựa trên bản rom này xài chơi!=D>=D>=D>=D>=D>
Bạn nào dùng Rom này thử up bản Extension Rom này xem sao nhé!
Trong đó mình thêm vào một số phần mềm nhỏ nhưng cần thiết:
- BatteryStatus.0.03 (Cái này có sẵn rồi;;))
- XComsoft_mCalc_v1.1 (thay thế cho cái máy tính xấu òm có sẵn của WM)
- vnkbrd_black_skin - Bàn phím tiếng Việt
- Bộ font tiếng Việt đầy đủ
Tải tại đây nhé:
http://www.4shared.com/file/22733175/f2b979d8/wizard_Ext-rom_update.html
Thx bác Aivanho đã có lòng giúp anh em :D
Không có gì:D
Ngồi buồn tạo bản ExtRom chơi nhưng thực ra chưa có điều kiện để up thử. Anh em nào dùng rồi cho biết tác dụng nhé!
Cuối tuần rảnh rỗi sẽ đưa luôn mấy cái đó vào Rom, chỉnh sửa lỗi về bàn phím và bỏ bớt một số thứ mặc định của WM mà theo mình là thừa như 2 bản game tích hợp sẵn (chán òm), calculator (thay thễ bằng Xcom Cal :D) , note (Có trong bộ Office Mobile đi kèm rồi)... và cả mấy themes nữa, chỉ để lại themes mặc định của WM thôi.
Nếu không có gì thay đổi thì đầu tuần tới sẽ up lên chia sẻ cùng anh em =D>=D>=D>=D>=D>
cho tui hỏi down cái splashscreen về làm ji zi?????
splashscreen dành cho G4 ko up trực tiếp bằng tool bình thường được, sau khi up bằng shelltool thì down cái này về up như bình thường nó sẽ thay đổi cái màn hình khởi động của máy:|
Tải tại đây nhé:
bác mà kèm thêm soft gõ tiếng việt cho phím cứng thì trên cả tuyệt vời!
