FreeCallSprite_v1.06 Ứng dụng báo rung cuộc họi (cập nhật trang 6)
Ừm cái này dùng cũng khá hay.Mình dùng N73ME vẫn thấy rung khi bên kia nhấc máy.Nhưng nếu cài thêm phần mềm FreeCollCalls nữa chắc không ổn.Hai thắng đó úynh nhau chít.
ko hề úynh nhau đâu bạn,minh cài cả 2 cái dùng đều ok mà (mình cũng dùng N73 ME)
FreeCallSprite v1.06_báo rung cho cuộc gọi
FreeCallSprite v1.06 dev 0819 by junnikokuki@opda-unsigned[Updated 19th August 08]
Dial-up wizard as the first test version of Dev, the use of the time need to note that there may be unknown software Bug, if willing to help us improve, specific issues can be sent to junnikokuki, of course, we will also do some pre-release testing, but After all, did not like the official version of the same test a long time. So named Dev version, users need absolute stability of the recommendation or install the latest version of stability.
Dial-up wizard is a third edition of the S60 features enhance dial-up software.
Dial-up wizard's main functions:
1, connected to remind: support vibration, lighting, and other speakers reminded the way
2, dial-up key tone
3, dial-up assistant (based on the importation of the alphabet or numbers to find the corresponding number of contacts)
Dial-up wizard supports the following phones (mobile phones are currently not supported FP2):
3250,5310,5700,6110 N, 6120C, 6121C, 6220C, 6290, E50, E51, E60, E61 (i), E62, E65, E70, E71, N73, N75, N76, N77, N80, N81, N82, N91 , N93 (i), N95, and so on.
Dial-up sign before installation wizard, you can use the developers signed the certificate.
Note: This version requires NetworkControl authority, so I do not support the Open Signed Online.
1.06 Dev0819 CHANGELOG:
1, the section name shows increase
2, E71 support
3, FP1 operation to remove the blue circle (from the task list hide -> enabled)
4, support Quanpin View (with the first letter of the election can only find a need Quanpin dictionary)
Note: Quanpin find more of memory, if your card number below 100, strongly recommended the use of initials to find ways.
Quanpin dictionary files on C: \ Data \ FreeCallSprite \ cover the original document (Note backup).
The letter, headed by its own procedures for the dictionary file.
Sau khi cài đặ xong FreeCallSprite copy FreeCallSprite.dic vào C:\Data\FreeCallSprite\
FreeCallSprite v1.06 dev 0902 [Updated 02/9]
1.06 Dev0902 CHANGELOG:
1, that the task list can not hide the mistakes
2, that offline mode dial-up procedures to withdraw from the mistakes
3, lights flashing patterns that some time after the screen backlight turned off the wrong
4, human amended the document Quanpin dictionary
5, optimizing the memory occupation
6, adjusted the display order, the default number to find when the former number, find the name when the former name. DisplayOrder increase of the cfg.
7, adjustment of the sort
8, an increase View mode selection, optional initials or Quanpin, do not need to change the dictionary file
ủa sao mình cài nó lại báo cer error contact application suplier ,trong khi mình đã hack fone rồi
mình cũng bị vậy nè. mình xài e61i. hack sign rồi.mà sao lại báo thế:-??
mình xài N73 MU, mình cài cũng bị báo lỗi như vậy, mình dã chỉnh ngày tháng lại và cả App.mgr cũng như vậy ngoài cách sign ra còn cách nào khác ko vậy. THANKS trước
Sign, hack phone rồi mà cài cứ bảo chưa Sign thì bó tay,(cer error contact application suplier ) pm này chắc có vấn đề?
Có ai sai cái này bị mất rung ko, mình cai thử thì thấy máy nào 1 thời gian sao, co cuộc gọi tới thì nó ko bao rung :)
Đúng là có lỗi này. Đó là bug của hệ điều hành. không chì phần mềm này mà nhiều khi chơi game có chế độ rung, sau một thời gian máy lại không rung nữa, tắt đi bật lại thì lại thấy rung.
Lúc đầu định nói nhưng chưa test nhiều máy, sao khi test thử E71, N95, 6120 thì bị lỗi này, sau khi remove thi ok :)
Đúng rùi mính sài N81 cũng có hiện tượng này.Nên hok sài nữa rùi.>_<.
Theo mình nghĩ thì các máy đời cao có thể nhà sản xuất đã mặc định tính năng báo rung không cho phép pm thứ 2 can thiệp vào để đảm bảo về tính an toàn cho máy.
FreeCallSprite v1.08 released
my.php
supports phones:
3250, 5700, 6110N, 6120C, 6121C, 6220C, 6290, E50, E51, E60, E61(i), E62, E65, E70, E71, N73, N75, N76, N77, N80, N81, N82, N91, N93(i), N95
Download:
Mã:
[URL="http://junnikokuki.spacesbloggers.com/downloads/FreeCallSprite_v1.08_freeware_by_junnikokuki@opda.net.cn_unsigned.sis"]http://junnikokuki.spacesbloggers.com/downloads/FreeCallSprite_v1.08_freeware_by_junnikokuki@opda.net.cn_unsigned.sis[/URL]
bấm vào nó chớp 1 cái rồi thôi
cài thử từ v.1.05 đến 1.0.8
Thế là không tuơng thích với máy của bạn rồi, thường các pm không tuơng thích vẫn cài được nhưng không vào được, khi bấm vào Icon là cứ im ru hoặc văng ra.
