FW mới 031.023 của E72 rm530_CareDP_6.0_SEAP.exe ( Ngày phát hành 19/04/2010 )
habaolinh
Super V.I.P
Major Data Package v6.00 MCU SW 031.023
Published 19/04/2010
Size 156.2 MB
APAC - Phones -> E72
File type -> Product Software & Bulletin
DP Information:
DP Name: SEAP
DP Filename: rm530_CareDP_6.0_SEAP
DP Type: Care
DP Version: 6.0 MAJOR
Description: SEAP
DP Content:
0587046 031.023 CAMBODIA QW BROWN
0586202 031.023 HONG KONG QW BLACK
0587050 031.023 NEW ZEALAND QW BROWN
0587040 031.023 INDIA QW GREY
0587031 031.023 SINGAPORE QW GREY
0586212 031.023 PHILIPPINES QW BLACK
0586222 031.023 VIETNAM QW BLACK
0586218 031.023 EMERGING ASIA QW BLACK
0587032 031.023 MALAYSIA QW GREY
0587051 031.023 BANGLADESH QW BROWN
0587052 031.023 EMERGING ASIA QW BROWN
0598496 031.023 INDIA QW WHITE
0586215 031.023 NEW ZEALAND QW BLACK
0599640 031.023 THAI QW AMETHYST
0598486 031.023 SINGAPORE QW WHITE
0599637 031.023 EMERGING ASIA QW AMETHYST
0587039 031.023 EMERGING ASIA QW GREY
0586208 031.023 MALAYSIA QW BLACK
0586213 031.023 AUSTRALIA QW BLACK
0587048 031.023 PHILIPPINES QW BROWN
0599631 031.023 CAMBODIA QW AMETHYST
0587037 031.023 NEW ZEALAND QW GREY
0598494 031.023 BANGLADESH QW WHITE
0599632 031.023 INDONESIA QW AMETHYST
0598497 031.023 THAI QW WHITE
0598493 031.023 NEW ZEALAND QW WHITE
0586667 031.023 HONG KONG QW GREY
0598498 031.023 VIETNAM QW WHITE
0599634 031.023 AUSTRALIA QW AMETHYST
0599635 031.023 NEW ZEALAND QW AMETHYST
0599630 031.023 MALAYSIA QW AMETHYST
0592124 031.023 TAIWAN QW WHITE
0598032 031.023 TAIWAN QW AMETHYST
0587033 031.023 CAMBODIA QW GREY
0587055 031.023 VIETNAM QW BROWN
0599629 031.023 SINGAPORE QW AMETHYST
0599636 031.023 BANGLADESH QW AMETHYST
0586209 031.023 CAMBODIA QW BLACK
0586210 031.023 INDONESIA QW BLACK
0587047 031.023 INDONESIA QW BROWN
0587034 031.023 INDONESIA QW GREY
0598487 031.023 MALAYSIA QW WHITE
0592123 031.023 TAIWAN QW BLACK
0587042 031.023 VIETNAM QW GREY
0587043 031.023 SINGAPORE QW BROWN
0599639 031.023 INDIA QW AMETHYST
0598490 031.023 INDONESIA QW WHITE
0586668 031.023 HONG KONG QW BROWN
0587054 031.023 THAI QW BROWN
0587041 031.023 THAI QW GREY
0587036 031.023 AUSTRALIA QW GREY
0587035 031.023 PHILIPPINES QW GREY
0586219 031.023 INDIA QW BLACK
0587053 031.023 INDIA QW BROWN
0594704 031.023 TAIWAN QW BROWN
0599633 031.023 PHILIPPINES QW AMETHYST
0587038 031.023 BANGLADESH QW GREY
0598495 031.023 EMERGING ASIA QW WHITE
0587049 031.023 AUSTRALIA QW BROWN
0587045 031.023 MALAYSIA QW BROWN
0598033 031.023 HONG KONG QW AMETHYST
0598488 031.023 CAMBODIA QW WHITE
0586207 031.023 SINGAPORE QW BLACK
0598491 031.023 PHILIPPINES QW WHITE
0599641 031.023 VIETNAM QW AMETHYST
0586220 031.023 THAI QW BLACK
0586216 031.023 BANGLADESH QW BLACK
0598492 031.023 AUSTRALIA QW WHITE
DP tracking:
Filename: DpSpec.xml
Timestamp: 2010-04-16 at 06:04
Tool: CST 8.35a
Có hướng dẫn không bạn ơi. mình không hiểu lắm cái này là FW mới à?
sao mình check trên NSU nó báo noupdate vậy ta . mình vẫn đang ở 23.002
Thường thì sau vài ngày nữa mới có bản update qua NSU nếu đây là FW chính thức. Còn nếu đây là FW cook thì chỉ có thể up offline thôi
tớ thấy cái v0.3 có từ lâu ùi mà :| thằng bạn nó up xong kêu dùng chán lắm nên tớ cũng chưa up :))
Hack được hết bạn à. Dùng cách hack flash FW là ok hết thôi
dùng cách này chỉ khi chưa up thì nên dùng. Nhung mà khi ta format là lại phải hack flash lại, mất thời gian quá. Thôi thì cứ tạm sign và cài, chờ xem helloox có ra ver để hack fw này ko.
Bạn cho mình hỏi nhe? mình hơi gà tí.
Mình sài E72 hàng xách tay, màu đen số Imei + Code của nó vậy nè:
Imei : 356030030321829
CODE E 72: 0591928120904c
Software version : 022.007
Language set 45.01
Model E72-2
Type RM-529
Vậy mình có Up FW này được không? Và Up như thế nào vậy bạn?
Thanks!
Language set 45.01
Model E72-2
Type RM-529
Thanks!
Cách up đơn giản nhất là dùng Ovi, hjhj... Nó tự làm cho mình chỉ việc ngồi nhìn
Bạn có thể hướng dẫn mình cách hack FW mới này bằng cách flash FW ko? Máy mình mới mua thôi.FW cũ chưa up FW mới.
Mình muốn up lên FW mới nè. Nó cải thiên nhiều tính năng và thêm một số ứng dụng. Bạn nào đã hack thành công bắng cách flash FW gì đó thì hướng dẫn cụ thể giúp mình.Email của mình là: kut3_76@yahoo.com
