FW mới cho Nokia N81 8GB - V21.0.008
Zenki
Super V.I.P
Chưa có change log cụ thể nhưng 1 số User đã update và có nhận định như sau
Finally, all you N81 8GB owners that have been stuck on Firmware V11 for what seems like forever, can now, finally update via The Nokia Software Updater. V21.0.008 is now available for most Product Codes. Normal N82 owners may also have an update available, so if you do, please let us know! Thanks.
You can also check your Product Code online here to see if the Update is available, before you connect your N82 up to your PC.
As you can see from the image on the left hand side, I have now installed V21 onto my N81 8GB. I can confirm improvements to both Navi Wheel, resulting in smoother, more positive feedback, and also now, the N81 gets N96 style Transitions, with smooth glide menu navigation cursor, maximize, and minimize menu opening, and closures. Very impressive.
I have also noticed, that now, when you open up the gallery, it automatically opens up viewing in landscape mode, and enables Navi Wheel smooth navigation through your various images, and videos.
As to the camera, there is obviously still no auto-focus, and as of yet, cannot find any improvements within the camera function, still quite poor, which is a shame.
Bluetooth, and Wlan however appear to have been improved dramatically, with improvements to being able to find devices much further away than before. Bluetooth now, finds a couple of my neighbours handsets, which it did not before, and WIFI seems much more stable.
1. Cải thiện chức năng Navi Wheel dùng mượt hơn trước đây
2. FW mới này còn thêm cho N81 8G một số style giống N96 trông rất ấn tượng
3. WIFI và Bluetooth cũng được đem ra màn hình Standby và cải thiện hơn FW cũ
Vấn đề hack sao em? Cái này mới đáng quan tâm :D nếu ko được thì nêu ra cách giải quyết cho anh em luôn nha. :)
Cho em hỏi nếu nâng cấp fimware lên thì điều đâu tiên có cần khôi phục lại cài đặt ban đâu của máy + thời gian update là bao nhiêu vậy ?
Không cần khôi phục cài đặt ban đầu của máy đâu bạn. Cứ gắn cáp vào update thôi. Update xong thì format lại thẻ rồi cho vào sử dụng bình thường. Thời gian update còn tùy thuộc vào đường truyền và dung lượng của gói FW, mình nghĩ không quá 30 phút :)
cái này update song có phải hack lại font không bro.????????không phai fomat thẻ nhớ lại cũng chẳng sao mà.các trương trình vẫn chạy ok.
ma cái này có code chữ trung quốc chưa bro
Code thì bạn dùng thử Code trước đây xem nó có nhận FW mới này không ?
Update xong thì khuyên nên format lại thẻ, có nhiều chương trình không chạy được đâu :)
Đã update xong
1. Cải thiện chức năng Navi Wheel dùng mượt hơn trước đây --> đã check
2. FW mới này còn thêm cho N81 8G một số style giống N96 trông rất ấn tượng --> chưa thấy
3. WIFI và Bluetooth cũng được đem ra màn hình Standby và cải thiện hơn FW cũ ( Thấy mỗi Wifi + chức năng chia sẻ ảnh trực tuyến )
Đã update xong
Bạn check thử có hack phone được không nhé :p Nhân tiện bạn thấy có gì mới thì chụp screenshot chia sẽ lên cùng mọi người đi :)
khi cập nhật cho N81 - 8GB mình có cần sao dữ liệu trong bộ nhớ 8GB lại không vậy ?
Dữ liệu như nhạc, hình ảnh, vv..v trong ổ cứng thì không mất nhưng phần mềm thì mất. Tốt nhất là 4mat cả ổ cứng và máy sau khi up:)
sao sau khi update mà format lại sau đó cài 1 số phần mềm chạy phát restart máy lun là sao hả bạn ( 1 số thôi nhưng toàn phần mềm hay Y_Y )
Sau khi format khuyên bạn nên format luôn ổ cứng 8G vì sau khi update xong có thể 1 số PM được cài trước đây không sử dụng được mà phải cài lại :)
Sao khi cập nhận FW mới cho N81 minh nhận thấy rằng sự thay đổi của FW này chính là hiệu ứng khi truy cập menu . còn navi wheel thì vẫn như xưa đâu có nhạy hơn , mà vẫn không hiểu tại sao N81 lại không xem được video 25FPS tức nhức vụ này .
