G-force v1.20, NulDel 4.4, ShowDelMsg v1.0 - Dọn rác cho điện thoại
TruongHan
Super V.I.P
Cả 3 phần mềm yêu cầu cài python 1.4.5 và modules trên ổ E:/,cả 3 app đều cài trên ổ E:/,NulDel thì chép file module CFileMan.pyd ivào C/sys/bin.Chương trình sẽ tự động dọn dẹp và show trạng thái trên màn hình
All 3 programs require installation of python 1.4.5 and modules on E:/, download them from HERE.
All 3 apps are free and can be installed on E:/, for NulDel you will need to put module CFileMan.pyd in C/sys/bin (need hacked phone).
G-force and NulDel are similar apps for cleaning, use whatever you want.
To navigate trough SMS down and up in ShowDelMsg, to exit G-force with right button, you will need WFvirtualKeyboard_0.9.4.mod download HERE.
G-force v1.2.0 English by I_placebo
The program starts automatic cleaning after opening and displays a report on the screen of the phone after cleaning.
Cleaning features: history bayanICQ, QIP (mob.agent story does not touch), PAIbN thumbnails, including cache of RescoPhotoViewer (regular no longer blows), the whole cache of default browser and Opera, FOTA reserved.bin file, all installation sis of private/10202dce, many unwanted system logs, log edit (settings are not touched), and uninstall t.d. All the junk in no way affects the work programs and generally phone.
New in this 1.20: Fixed bugs, changed the algorithams so not to affect adjustment programs, as well remove unnecesarly items that all programs left over.
NulDel v4.4 English by I_placebo
NulDel - application to delete files, empty folders and deep cleaning of your smartphone from a file of garbage.
Authors do not bear any direct or indirect responsibility for the harm caused to your smartphone with this application.
Key features:
- Remove empty files, folders;
- Cleaning debris, removed all folders _PAlbTN of the entire system on disks C:/ and E:/
(memory card);
- Removed all non-required *.R# except *.R01 and *.R16 (there will be only Russian and English localization);
- Removes reference *.H# except *.H01 and *.H16;
- Removes the entire system cache and temp files;
- Removed log in defeat at Real Player;
- Removes the last set of log / remote applications;
- Deletes a file Reserve FOTA (firmware by air);
- Deletes the cursor position in a text editor Ded;
- Deletes a file from the preview Resco Photo Viewer;
- Removed the cache from Opera;
- Delete a list of bluetooth devices;
- The "Delete more - Fast distant known debris, ie without a full scan of all Smart;
- Displaying the size of garbage in kilobytes for cleaning debris and items known debris (an algorithm is a curve, but workable) In development: Display the full path to the file/folder after scanning, improved calculation algorithm of remote file in bytes, kilobytes, megabytes;
- Deletes history BayanICQ, Smaper, MobileAgent, QIP, Slick [new], etc.
Added / Changed:
- Chapters debris, add your own files or folders to remove (the list already contains 50 entries);
- A little changed counting garbage (view more accurately, but trust is still not always worth it);
- The background color and text in Help and About are taking from the system theme (was crashive);
[!]- In the archive is also required to run the module CFileMan, which should put in C:/sys/bin.
mình chưa download và dùng thử nhưng nghe có vẻ là 1 chương trình rất hay và hữu ích :) phải tìm hiểu thêm về ngôn ngữ python này đã +_+
mình update python lên v2.0 . bây giờ không còn dùng được mấy cái này nữa. với lại lúc đầu cài python 1.45 chạy mấy phần mềm này cũng bị lỗi nhiều lắm. có phần mềm này mà dùng trên nền python 2.0 ko
Tôi cũng như bác vậy. mà nếu down python 1.4.5 thì down ở đâu? tôi đang sai bản python 2.0
Bắt buộc dùng cả 3 phần mềm hay chỉ những phần mềm mình cần thôi hả anh? Em muốn phần mềm dọn rác thì chỉ cần cài nulldel thôi àh?
Sau khi dọn 1 đóng rác bằng NulDel kết quả nhận được là "Lỗi hệ thống" (n97) :)). Khởi động lại vài lần xem thế nào thì kết quả như nhau "Lỗi hệ thống" :((
cái G fone kia sài thì god nhưng mà có một nhượt điểm là ! lúc gửi SMS nó cứ báo chờ hoài kô chju gửi phải gửi 2 lần mới đc, nhưng mà rất mạnh , chắc dọn rác song lại xóa đi thui khi nào cần mới cài lại thank các bác
Nghe nói lỗi hệ thống kia làm em cũng run quá. Bác TruongHan giải thích vụ này giùm anh em đi :-??
Anh ơi có phần mềm dọn rác nào mà ko cần hack máy ko anh? Nếu có thì chỉ giúp em nhé :D
ShowDelMsg v1.0 English Unsigned By Nima79.rar‎ cái này là rọn rác ah bạn.sao nó lại chạy inbox là sao?inbox là hòm tin nhắn mà!
Hic, cái điện thoại bé xíu thì có mấy rác mà dọn chứ, nếu dọn rác mà nhanh hơn nhiều thì trong ROM của Nokia đã tích hợp luôn rùi, dọn rác rùi vẫn vậy, dùng mấy PM thấy chả có gì nên không dùng nữa
vậy là bạn chưa gặp thôi.....đơn giản nhất là khi xài ttpop.....khi remove còn dính file text thì sau khi cài bản mới zo6 sẽ lỗi liền....đối với những bạn ko mò thường xuyên thì làm sao biết cái file text đó ở đâu mà xóa đi?????....nó ko cho cài mà lại báo lỗi cập nhật....đúng là nó ko ảnh hưởng gì mấy đến tốc độ máy.....nhưng có lúc cũng cần xài đến......
