TP.HCM Google Nexus 7 2013 Treo Flash Ok !
Taki7610
Unlock_GSM
Mã:
07d92d2a        fastboot
sending 'bootloader' (3911 KB)...
OKAY [  0.130s]
writing 'bootloader'...
OKAY [  1.575s]
finished. total time: 1.709s
rebooting into bootloader...
OKAY [  0.007s]
finished. total time: 0.009s
< waiting for device >
erasing 'system'...
OKAY [  0.573s]
sending 'system' (717936 KB)...
OKAY [ 22.620s]
writing 'system'...
OKAY [ 31.616s]
finished. total time: 54.818s
sending 'recovery' (7564 KB)...
OKAY [  0.245s]
writing 'recovery'...
OKAY [  0.290s]
finished. total time: 0.541s
sending 'boot' (7018 KB)...
OKAY [  0.228s]
writing 'boot'...
OKAY [  0.286s]
finished. total time: 0.522s
erasing 'userdata'...
OKAY [ 21.111s]
formatting 'userdata' partition...
Creating filesystem with parameters:
    Block size: 4096
    Blocks per group: 32768
    Inodes per group: 8192
    Inode size: 256
    Journal blocks: 32768
    Label:
    Blocks: 7045115
    Block groups: 215
    Reserved block group size: 1024
Created filesystem with 11/1761280 inodes and 154578/7045115 blocks
sending 'userdata' (139085 KB)...
writing 'userdata'...
OKAY [ 11.970s]
erasing 'cache'...
OKAY [  0.468s]
formatting 'cache' partition...
    Block size: 4096
    Inodes per group: 7168
    Inode size: 256
    Journal blocks: 2240
    Label:
    Blocks: 143360
    Block groups: 5
    Reserved block group size: 39
Created filesystem with 11/35840 inodes and 4616/143360 blocks
sending 'cache' (10984 KB)...
writing 'cache'...
OKAY [  0.922s]
finished. total time: 34.482s
your Nexus 7 2013 is now restored! :)
rebooting...
finished. total time: 0.005s
Press any key to continue . . .
bạn ơi, mình hok thể nào unlock bootloader dc sao mà up stock hả bạn, đã thử rất nhiều, NRT sdk đã cài.. máy mình up 5.0.2 ota rùi treo logo.. mình đưa về fastboot bằng tay rùi ghim pc.. máy tính vẫn nhận... mà cái vụ unlock bootloader thấy đa số kêu phải stick usb debug mà treo sao mà stick... gõ lệnh cmd fastboot oem unlock thì vào màn hình unlock chọn yes.. rùi treo luôn chả chạy tiếp.. flash trực tiếp rom gốc thì báo failed " remote bootloader is locked" điên hok tả dc.. a e nào cao kiến chỉ với
