H@ck E72 051.018 Việt nam (Phoenix)
vnmsc
Tải FW tại đây : rm530_CareDP_7.0_051.018_APAC.exe
Code :
# DP Information:
# DP Name: 051.018_APAC
# DP Filename: rm530_CareDP_7.0_051.018_APAC
# DP Type: Care
# DP Version: 7.0 MAJOR
# Description: 051.018_APAC
# DP Content:
# 0587046 051.018 CAMBODIA QW BROWN
# 0586202 051.018 HONG KONG QW BLACK
# 0587050 051.018 NEW ZEALAND QW BROWN
# 0596238 051.018 CHINA WLAN QW BROWN
# 0587040 051.018 INDIA QW GREY
# 0587031 051.018 SINGAPORE QW GREY
# 0586212 051.018 PHILIPPINES QW BLACK
# 0586222 051.018 VIETNAM QW BLACK
# 0598034 051.018 CHINA WLAN QW AMETHYST
# 0586218 051.018 EMERGING ASIA QW BLACK
# 0587032 051.018 MALAYSIA QW GREY
# 0587051 051.018 BANGLADESH QW BROWN
# 0587052 051.018 EMERGING ASIA QW BROWN
# 0598496 051.018 INDIA QW WHITE
# 0586215 051.018 NEW ZEALAND QW BLACK
# 0599640 051.018 THAI QW AMETHYST
# 0598486 051.018 SINGAPORE QW WHITE
# 0599637 051.018 EMERGING ASIA QW AMETHYST
# 0587039 051.018 EMERGING ASIA QW GREY
# 0586208 051.018 MALAYSIA QW BLACK
# 0586213 051.018 AUSTRALIA QW BLACK
# 0587048 051.018 PHILIPPINES QW BROWN
# 0596236 051.018 CHINA WLAN QW BLACK
# 0599631 051.018 CAMBODIA QW AMETHYST
# 0587037 051.018 NEW ZEALAND QW GREY
# 0598494 051.018 BANGLADESH QW WHITE
# 0599632 051.018 INDONESIA QW AMETHYST
# 0598497 051.018 THAI QW WHITE
# 0598493 051.018 NEW ZEALAND QW WHITE
# 0586667 051.018 HONG KONG QW GREY
# 0598498 051.018 VIETNAM QW WHITE
# 0599634 051.018 AUSTRALIA QW AMETHYST
# 0599635 051.018 NEW ZEALAND QW AMETHYST
# 0599630 051.018 MALAYSIA QW AMETHYST
# 0592124 051.018 TAIWAN QW WHITE
# 0598032 051.018 TAIWAN QW AMETHYST
# 0587033 051.018 CAMBODIA QW GREY
# 0587055 051.018 VIETNAM QW BROWN
# 0599629 051.018 SINGAPORE QW AMETHYST
# 0599636 051.018 BANGLADESH QW AMETHYST
# 0586209 051.018 CAMBODIA QW BLACK
# 0586210 051.018 INDONESIA QW BLACK
# 0587047 051.018 INDONESIA QW BROWN
# 0587034 051.018 INDONESIA QW GREY
# 0598487 051.018 MALAYSIA QW WHITE
# 0592123 051.018 TAIWAN QW BLACK
# 0587042 051.018 VIETNAM QW GREY
# 0587043 051.018 SINGAPORE QW BROWN
# 0599639 051.018 INDIA QW AMETHYST
# 0598490 051.018 INDONESIA QW WHITE
# 0586668 051.018 HONG KONG QW BROWN
# 0587054 051.018 THAI QW BROWN
# 0587041 051.018 THAI QW GREY
# 0587036 051.018 AUSTRALIA QW GREY
# 0587035 051.018 PHILIPPINES QW GREY
# 0586219 051.018 INDIA QW BLACK
# 0587053 051.018 INDIA QW BROWN
# 0594704 051.018 TAIWAN QW BROWN
# 0599633 051.018 PHILIPPINES QW AMETHYST
# 0587038 051.018 BANGLADESH QW GREY
# 0598495 051.018 EMERGING ASIA QW WHITE
# 0587049 051.018 AUSTRALIA QW BROWN
# 0587045 051.018 MALAYSIA QW BROWN
# 0598033 051.018 HONG KONG QW AMETHYST
# 0598488 051.018 CAMBODIA QW WHITE
# 0586207 051.018 SINGAPORE QW BLACK
# 0598491 051.018 PHILIPPINES QW WHITE
# 0599641 051.018 VIETNAM QW AMETHYST
# 0586220 051.018 THAI QW BLACK
# 0586216 051.018 BANGLADESH QW BLACK
# 0596235 051.018 CHINA WLAN QW GREY
# 0598492 051.018 AUSTRALIA QW WHITE
# DP tracking:
# Filename: DpSpec.xml
# Timestamp: 2010-08-10 at 11:30
# Tool: CST 8.35a
attachment.php
attachment.php
attachment.php
Tải FW và file Hack :
Tại đây
Giải nén bằng 7zip và cài vào máy nhé
C:\Program Files\Common Files\Nokia\DataPackage\Products\RM530
Flash bằng Phoenix nhé
Không biết bản này có phix lỗi time vietnam không vậy? giống bản FW trước thì chạy làm gì.
đã test, tiện up một số hình ảnh cho anh em thao khảo nha
Từ hồi giờ chọt WM và Android... giờ ông anh choa cái E72 Black... đã tập tành update bản firmware ở post 1... nhưng sao install HelloOx 2.03 kể cả 2.04 mà vẫn kg hack được. Sau khi cài HelloOX xong, chạy đến đoạn Installing Cer là đứng im đó luôn. Mong bạn chỉ giúp. Thanks.
E72 firmware mới thì phải hack = JAF hoặc Phoenix thôi (bạn search trên diễn đàn có hướng dẫn cụ thể đó). Máy mình vẫn đang dùng phiên bản 023 (cái này dùng Helloox2 hack được)
jaf có fash được e72 đâu? chế độ die phone cắm vào pc nó khởi động vào chế độ sạc qua usb luôn không fash được
fw 053.001 có ai hack chưa nhì? mình update lên 053.001 mất rùi? tiếng việt không có hack cũng chưa thấy? thằng này không như s60v5 cứ nhét thẳng rompatcher vào rom rùi fash là hack ok? hix không biết e72 có tool nào để cook rom không nhì
mình đã hack FW này thành công nói chung là dùng thích hơn cái 031 chỉ có 1 lỗi đó là sai múi giờ việt nam nhưng không sao mình chỉnh sang múi giờ thái lan mình dùng :D
chưa có cách nào khắc phục được múi giờ việt nam hả các bác :-?
e đang dùng FW 031.023, sao e cắm điện thoại vào ovi suite nó báo là chưa có bản cập nhật mới các bác nhỉ?
cho em hỏi thêm chút nữa là bản FW 051.018 có phải là bản chính thức của Nokia không ạ?
cảm ơn các bác nhiều!
bản 51 là bản chính thức từ Nokia , nếu không thấy bản cập nhật , bác có thể đổi code để up lên FW mới ...
bạn làm theo cách sau :
Bạn làm như bình thường đến phần nhấn ok, bình thường là mình ấn vào nút power đúng ko.
Nhưng bây giờ khi ấn ok, bạn nhanh tay cắm cable vào máy tính là được
Cách 2: Đầu tiên cắm điện thoại vào máy tính cho máy tính nhận điện thoại, sau đó tắt điện thoại và tháo pin ra, đến khi chương trình thông báo press the power button thì nắp pin lại, chương trình sẽ chạy.
mình vẫn thắc mắc tại sao trên NSU và trên navifirm vẫn chưa thấy bản FW 051.018 nhỉ?
Đã có bảng chính thức TIENG VIET FW e72 054.005 trên navifirm
Đã có bảng chính thức TIENG VIET FW e72 054.005 trên navifirm\-/\-/\-/
bây gjờ cần gì đổi code nữa hả bác
cứ down fw về tống vào jaf hay ph0enjx và flash là ok luôn
:D
ko cần quan tâm c0de gj hết
