HDLEOV4_Ultimate_Serie_5.2.21869
nhimyeu
Mới down được bản room trên mạng mời mọi người dùng thử
Laurentius26 HDLEOV4 Ultimate serie
CE OS 5.2.21869 (Build 21869.5.0.82)
ROM version 1.59.709.0 (48753)
Radio version 1.13.25.24
ROM date 17/12/09
Pagepool is set to 17 MB
Add-ons and removed:
The rom is totally revamped, a complete new look thanks to my good friend Spike.
HTC Sence V.2.5.19211619.0 CFC modded by Spike.
Footprints and Twitter included in rom
I've removed Opera and replaced with SkyFire browser, it supports flash and gives the possibility to post in forums. Standard it doesn't auto rotate but with the buildin G-Config you can make it rotate if you like
Neo's driverpack V3
Capture screen utility
Dotfred's Taskmanager (an advanced Taskmanager to kill tasks, view processes, regedit etc..)
Enter bootloader (no need to use the hardware buttons, you can now go into boot with this lightwait app).
G-Config (auto rotate (or not) the applications you like
HTC Addict Cleanram (speaks for itself)
KeePass (a digital wallet to save your passwords/websites etc..)
Notepad (A handy notepad)
Total Commander (A more advanced file explorer then the default one)
Daveshaw's XDA-Shutdown skinned by Spike (shutdown, switch off or restart your device
Cyberon Voicespeeddial (use your voice to dial a contact)
eT9Mywords to modify Ezinput dictionairy
Topaz Camera (for fast and quality pictures, no zoom)
Rhodium dialer which supports landscape and videocall
Autocall record
What's fixed/ improved:
BT A2DP now opens Sense mediaplayer, thanks to >> Gooru
HTC Taskmanager delay fixed after softreset thanks to Noonski
Manila CFC compressed for more speed and less mem usage, thanks Spike
Videoplayback
Lockscreen delay
All applications and drivers updated to latest available HTC HD2 Leo source 1.61
Many tweaks to improve rom speed/ memory plus user experience
XIP is patched, ULDR sector removed for more speed
Used NETCF 3.5
Working VOIP drivers and SIP Config
Updated latest WLM
Note; I didn't use the flipflop clock fix as it's giving some errors with certain numbers in the Sense clock
linhdown:http://gator155.hostgator.com/~vidm...6/L26_Ultimate HDLEO Serie/L26HDLEOV4_WWE.rar
- Đây là Rom bên XDA, ko nên giới thiệu trong khu vực PDAVIET ROM bạn nhé! (Đã di chuyển ra ngoài)
- Nếu muốn giới thiệu thì bạn cũng nên đưa vài hình ảnh cũng như dịch ra tiếng Việt để mọi người có thể hiểu. Nếu ko thì chỉ cần đưa link qua XDA là đủ!
