Đây là hướng dẫn cho Fp1 nhá, Pro nào giỏi English thì dịch họ cả nhà đi
GUIDE TO ACTIVATE THE EFFECTS TAT KASTORIA
ON TERMINAL FP1
(tested on N95 8GB fw 20.0.016.
* * should go smoothly even on N95 and N82.
for non-Serien do not know)
Prerequisites
- Have done the hack (obviously)
- Have installed the program ROM Patcher
- Have installed a file manager (council X-Plore)
- Install the theme in use on c:
CASE
1) download the file KastorUI.zip attachment and send to phone
2) with X-Plore do this:
a) copy the "effects" to "c: \ resource \"
copy the file "KastorUI.rmp" in "e: \ patches \"
c) identify in "c: \ resource \ skins \" folder corresponding to the theme in use (if not successful installed on all issues and: except that you use, so in c: remain just that)
d) copy the file "effects.sel" folder in the previous paragraph
e) rename the file "effects.sel" with the name of the folder where you are. if for example you copied to c: \ resource \ skins \ 1234567887654321 \ "should be called" 1234567887654321.sel "
3) open ROM Patcher and apply the patch KastorUI
4) open Themes, select the theme, press "Options" and set "Effects theme" to "Off" and then "Enable"
5) enjoy the wonderful graphic effects
WARNINGS
- The effects are related to the theme, so if you change the subject is no longer active. to ask for it must repeat steps 2c, 2d and 2nd with new theme
- Even if you put the patch in autorun you must repeat step 4 each time
POSSIBLE DEVELOPMENTS
- The effects folder is that of a N81, but lack the effects of "smooth scrolling" in the menu and the rotation of the screen. You can probably get a N78 or N96
- Whereas the files of the effects are all in text format should be possible to create new
- If our thememakers want to try this could create rpoprie transitions and insert the file. Sel and. Kml directly to their subjects
http://www.youtube.com/watch?v=58mDQjSq5z8
download link
http://rapidshare.com/files/175370151/KastorUI.zip
