HTC HERMES - WM6.1 Touch V24 - Build 20753.1.4.0
Ok, very nice, but a couple of problems, unknown caller still does not ring, phamquang's 20749 build works well. MMS only can send not receive. video call works good.
I verify these problems . Waiting for new fixed version if you have time. Really thanks for your work
I don't understand, i don't happen this problem.
Can you speak plain again?
Thank!
Call your tytn from another phone begining with #31#...+your number .
You will make a "Unknown Caller" call to your phone . Then you will see the popup balloon in tytn but no RING or VIBE . only popup balloon . So with thí bug of BUILD 20748 also you can NOT realise a call if it is "Unknown Caller"
I hope I helped to understand nơ;)
Thank you for your guide but in my regional network very very few people used this function.
So i don't condition to test.
Do you know method..?
Thank
Thank
Let's say your mobile phone number is 66996699 .
Did you try calling your phone from your house (local) or another mobile like this ??
#31#66996699 + Green call button ???
Does your tytn has only popup "Unknown Caller" without ring+vibe??? or it rings???
I don't know other method for making this.
My home phone and mobile phone SIM does not support this function (Hide number) :(
Ok bro, hmm please try to call your mobile from a payphone, may be. I don't think each pay phone will have caller ID attached to their numbers you will know what I mean, I think the solution is here
Now I think the MMS issue needs to be fixed please if you have time. I will come back to this ROM again once all fixed with MMS I don't get that many but I get some during one month.=D>=D>
Running your 20753 Full non and integrated MMS 5.031.11 works fine. Just have the unknown caller problem.
các bác ơi cho em hỏi tại sao em ko down đc nhi?
Nó bắt nhập mã vào là PDAVIET em nhập ba lần vào rồi lỗi kô down dc.
Help!:((
Bác nào cho em hỏi em cai các bản room từ đời 17 đến nay đều có hiện tượng bị mất sống liên tục.Em sài sim mobi không hiểu là do máy hay là do bản room vậy mấy pác!??(thanks đã giúp em)
Sóng kém không phải do ROM đâu bạn ơi.
Nguyên nhân có thể là :
1. bản Radio không phù hợp.
2. Mạng thời điểm gần đây cũng hay gặp trục trặc, cái này thời gian gần đây bị đăng lên báo nhiều.
3. Do tiếp xúc giữa SIM và máy kém có thể do rỉ sét.
4. Do phần cứng máy gặp vấn đề.
Bác ơi, em dùng bản ROM của bác, dùng được khoảng 1 ngày giờ nó đơ luôn, bị khựng ở màn hình lúc khởi động ý <trước của màn hình có chữ WINDOWS MOBILE>. Haiz... em đã thử các cách như trong topic Các lỗi thường gặp nhưng nó ko chịu lên cho em nhờ... Con của em là Dopod 838pro
Bạn hãy đọc chú ý ở dưới chữ ký của mình để tìm hiểu nhé.
Chia buồn cùng bạn.
Chúc vui.
hi CMC,
đa phần thì lỗi do sự tương thích phần cứng rất hạn hữu, tuy có nhưng rất ít. Trước khi kết luận là do tương thích phần cứng hay không thì nên kiểm tra phần mềm, nhất là là phần mềm tác động đến hệ thống mà bạn cài trên máy
Ví dụ như mình, trước đây cài ver6.1 đời đầu liên tục lỗi sau đó cài được vì phát hiện lỗi là do HTC Task Management. Bản hiện nay cài lên mình cũng gặp lỗi, cũng là do HTC Task Man. thay bản khác là xong.
hy vọng mình giúp được bạn
download bang cach nao do bac
Bạn nhớ gỏ tiếng việt có dấu nhé
Đây Bạn
Download
USER/PASS login : PDAVIET/PDAVIET
Mình mới tậu được chú Hermes cũ nên đang tìm hiểu để vọc, nghiên cứu kỹ rồi tuy nhiên do Theard này có từ lâu rồi nên các link rom của dvha79 đều không tải được, mong bạn nào up lại dùm được không?, vào chữ ký của dvha tải rom về có hỏi pass mong dvha giúp cho pass
link bi loi roi anh ah
khog thay link dung duoc
Đã kiểm tra link vẫn tốt bạn nhé!
@ lần sau post bài TV phải có dấu bạn nhé, nếu ko mình sẽ xóa bài đó. Đã là tv cấp 2 rồi mà!?
T2M
Thật sự em gà quá,ko thấy line để tải luôn,giúp em với,lần đầu mày mò WM
