HTC POLARIS - PDAVIET ROM WM6.5 (Core 21202) by TranMinhMan
@TranMinhMan: with your ROM (that I use since day one) I only have 2 issues: like I mentioned earlier, the phone dialer works how windows wants, sometime 3G, sometimes new WIN 6.5 dialer with slide, sometimes the classic dialer. This problem is only when I need to answer a phone call. The second issue is the one with too big icons in start menu.
As you probably know already, the 21210 build is out, and it seems that it's not a fake one. Should we expect new ROM version ?
I would have a few recommendations for new version:
1- include WM6.5 Titanium Weather, it would be nice to have real weather on main screen
2 - include Device Lock 1.2. It simply creates a shortcut for lock screen in start menu. It's useful because, lock can be assigned to a hardware button
3 - add the hexagon lines in start menu. Ít's simple but nice.
Thank you again for this beauty.
Hello, everybody!
I fixed bug IE and have ported 21500 already, but do not upload on forum, because I think it is the fake Core.;;) So I am still waiting new Core, it may be 216xx. Core Beta are released so fast, and can not sure which is the fake Core!?:|
Best rgds!:D
Hi and thanks for your work..
The core 21613 is a Fake too..
But 21500 work fine..fast and litte different that 21202.
I have just a prob with camera, bugs, with the polaris Rev B (R 1.65.30.09)
Các bạn cho mình hỏi, đã có Hard SPL cho Cruise 09 chưa nhỉ?? Đã ai up ROM cho Cruise 09 chưa???
Cruise 09 là dòng Iolite nha bạn, còn đây là Cruise thường dòng Polaris. Bạn nên cẩn thận trong việc HSPL!;)
Tks for your feedback, alinescoo!=D>
- These are beta core so the dialer 6.5 in SYS is not complete. So I pluggin the Iolite dialer to the ROM.
- The large icons, somebody like that. But I think the same of you, they are not smooth (the icons are broken images), so they are not nice!;)
- I will pluggin Titanium Weather in next build.
Best rgds!:D
Yes, I think so!;)
May be the next core is 21501, somebody said that it is the first official WM6.5 core of MS. I just have the source in hand, but do not have time to build yet.
About your camera, you should use the radio 1.59.x.x
Yes, I think so!;)
exciting news about 21501. looking forward to your next release.
PDAVIET ROM WM 6.5 CE OS 5.2.21202 Build 21202.5.0.0
By TranMinhMan
*** Only for HTC Polaris ***
Đặc biệt cảm ơn - Special thanks to:
Man PhamQuang
Adv Mod: Sonblack, Dvha79_ddt
Trial Mod PhamNhatThanh
VIP Medkid
forum.xda-developers.com
forum.ppcgeeks.com
xbeta.cn
Hình ảnh ROM - ROM Images:
Thông tin bản ROM - ROM Informations:
- CE OS 5.2.21202 Build 21202.5.0.0 PV T2M.
- 3D Polaris Drivers
- .NET Compact Framework 3.5.7283.0
- AdobeFlash
- Advanced Configuration Tool v3.3.0.0 by Julien Schapman
- Base Hue Express
- dotFred Task Manager
- lpaso TitaniumCustomizer
- HTC Album
- HTC Booster
- HTC Camera 5.0.4
- HTC Comm Manager
- HTC Random Access
- HTC Sim Manager v6.60
- HTC TaskManager
- HTC TouchDual Dialer DIAMOND (support 3G)
- PCM Keyboard (support VN key)
- PIM Backup v2.8.0.0 by FdcSoft
- PocketNotepad v4.0.10
- Pocket RAR v3.80 by Alexander Roshal
- PocketScreen v1.3 by JJM. Roseboom
- Synchro Time v0.95 by Dennis Grachov
- TCPMP v0.72RC1
- Total Commander CE v2.51 by Christian Ghisler
- Windows Live v10.6.0034.0800
- psShutXP (mod)
- Windows Media Player 10.3 Build 21202 (mod)
- Bootscreen (mod)
The suggestion Radio is 1.59.X.X!!!
Hướng dẫn up ROM - Up ROM Guides:
- Máy bạn đã được HardSPL trước khi up ROM.
- Your Polaris must be HardSPL before up ROM.
- Bản ROM chỉ có Operating System, không có Radio.
- This ROM just has Operating System only, no Radio.
- Download và giải nén với password bên dưới. Kết nối máy với PC qua USB.
- Download and extract with the password below. Connecting Polaris with PC through USB.
- Chạy file ROMUpdateUtility.exe và làm theo các bước hướng dẫn trên màn hình => máy về trạng thái BootLoader và chờ loading 100% => máy tự reset là đã có ROM mới.
- Running file ROMUpdateUtility.exe and following step by step on the windows => Polaris run BootLoader state and loading 100% => Polaris auto reset and you have new ROM.
Link download đã có.
Download link was availabled.
Chào anh TranMinhMan,
Sau một thời gian dùng bản ROM của anh em đã phát hiện ra lỗi là khi mình touch từ dưới lên (giống mở chức năng "Innovative 3D Touch Cube interface for quick and easy navigation" của ROM gốc) thì bị lỗi biotouch.exe xuất hiện. Không biết anh đã phát hiện ra lỗi này chưa? :)
Bạn vào Settings => System => Advanced Settings => HTC TouchFLO => Scrolling chỉnh lại Disabled. Save lại và SR.
Thân!;)
vâng, em đã làm như anh hướng dẫn. Tất cả đã tốt. Cảm ơn anh nhiều. :) =D>
anh ơi cho em hỏi vì sao máy em man hình cảm ứng không sử dụng được nữa
tự dững nó bị thế ? a có thể cho e biết nó bị gì ko ah
Cảm ứng
Bạn phải nói rõ nguyên nhân bị chết cảm ứng,đã có phần nói riêng cho chủ để này bạn nên seach trước khi pos bài..thân...
có thể máy bạn hỏng cảm ứng,bạn nên thay nó,thay cảm ứng cũng ko đắt lắm.Bạn nên wa 88 trần Hưng Đạo để biết thêm về giá nhé
Chú Ý:Thay cảm ứng chứ ko phải thay màn hình nhé...:)
Máy bạn đã được HardSPL trước khi up ROM?
Mình không hiểu HardSPL là làm thế nào?Và phải làm sao khi máy không kết nối được với PC qua ActiveSync?PC cứ báo là không nhận được thiết bị.
Hãy ngâm cứu kỹ bài này và từ từ tiế́n hành theo từng bước bạn nhé!;)
