HTC POLARIS - PDAVIET ROM WM6.5 Manila 2D with Footprints (Core 23016) by TranMinhMan
Im playing with this your ROM, its fast and sounds like very good ROM, thanx. Only QuickGPS doesnt work.
One request - could you please disable SD encryption by default? On every your ROM first what we need is regedit and disable it in registry, because in settings disabling doesnt work :(
plz help
i m expereincing strange problem i m unable to do hard reset by pressing recomended buttons device just got reset ,and whn i open mesages inbox i m unable to open and read the highlighted mesage ,tapping it do nothing ,plzz help me
mr trân and friends here
plz help
You can always reflash the rom. Don't need hard reset.
plz help
If you cannot make HR, try reflash ROM once more and then make HR before screen setting
yeah about reflash its ok ,but i m unable to open and read messages in inbox taping on particular mesage dont open it and also on quick gps button ,once in press it ,it opens screen allignment and othertime the button fuction i set on it like messaging and quick gps ,is there might be problem with my default quick gps button
thanks friends plz need help
I have no problem with messages... Im not using M2D, im using Titanium...
Quick GPS doesnt work for me, i reinstall it with HTC Quick GPS and now is OK...
Do you make any changes in settings? TouchFlo settings? Correct screen alignment?
Im sorry, i dont know whats problem on your device, maybe some HW error or in other ROM works good?
so now i think its hardware problem ,once i put the display off from power button i m unable to put it back on through power butten ,if i pres send key with power button thn display come back ,and with mesaging the several mesages in inbox get automatically multi selected whn i tap on particular mesage but don get open for detailed view ,same in with contact list ,contact list,contacts automatically get multiselected as i tap on contacts ,i m unable to call contact by tapping 2 times ,cant even see it details view,plus with default gps button ,once i press it it opens screen allignment and second time the desired application alloted to it ,and hard reset too don work ,,
any hardware expert plz help
i will be really thankful to u guys
bác Minh Mãn ơi, cho e hỏi 2 câu hơi... nhé
1. em download QuickGPS, cứ được 85% thì nó báo "Lỗi kết nối"?
2. em download radio 1.65.30.8 (cho nó giống hình demo của bác), chỉ có mỗi file Polaris_Radio_1.65.30.09.nbh. Làm thế nào để update radio?
Mong bác và mọi người giúp em nhé.
thanks a lost!
everything is smooth except my memory is always over 55%... is it normal?
Yeah, it's normal friend, because this ver has more packages than the others. In the ver I test now (plug in Mega packages), it more heavy than this ver. The memory is always over 65%!;)
thanks a lost!
- QuickGPS bị lỗi bạn hãy kiếm file cab bên ngoài rùi cài đè lại sẽ ok.
- Bạn đổi file Polaris_Radio_1.65.30.09.nbh thành tên RUU_signed.nbh, rùi chép vào bộ up Rom như bình thường thui.
Thân!;)
That's bad news 'cause there will only be about 30 MB free RAM
It might be better to leave some packages out
Sascha
bác MM bàn phím compact qwerty và phone keypad lỗi skin rồi.chức năng don't lock buttons cũng không có tác dụng?
