HTC Touch Pro
support
Mã:
http://www.htc.com/www/product.aspx?id=49518
Trên trang HTC thấy cái Touch Pro này đã quá, chắc Exec lỗi thời với con này rồi :)).
Processor Qualcomm® MSM7201A™ 528 MHz
Operating System Windows Mobile® 6.1 Professional
Memory ROM: 512 MB
RAM: 288MB
Dimensions 102 mm (L) X 51 mm (W) X 18.05 mm (T)
Weight 165 g (with battery)
Display 2.8-inch TFT-LCD flat touch-sensitive screen with VGA resolution
Network HSDPA/WCDMA:
Europe/Asia: 900/2100 MHz
Up to 384 kbps up-link and 7.2 Mbps down-link speeds
Tri-band GSM/GPRS/EDGE:
Europe/Asia: 900/1800/1900 MHz
(Band frequency and data speed are operator dependent.)
Device Control TouchFLO™ 3D
Touch-sensitive navigation control
Keyboard Slide-out 5-row QWERTY keyboard
GPS GPS and A-GPS ready
Connectivity Bluetooth® 2.0 with EDR
Wi-Fi®: IEEE 802.11 b/g
HTC ExtUSB™ (11-pin mini-USB 2.0, audio jack, and TV Out* in one)
Camera
Main camera: 3.2 megapixel color camera with auto focus and flash light
Second camera: VGA CMOS color camera
Audio Built-in microphone, speaker and FM radio with RDS
Ring tone supported formats:
MP3, AAC, AAC+, WMA, WAV, and AMR-NB
40 polyphonic and standard MIDI format 0 and 1 (SMF)/SP MIDI
Battery Rechargeable Lithium-ion or Lithium-ion polymer battery
Capacity: 1340 mAh
Talk time:
Up to 397 minutes for WCDMA
Up to 485 minutes for GSM
Standby time:
Up to 503 hours for WCDMA
Up to 406 hours for GSM
Video call time: Up to 201 minutes for WCDMA
(The above are subject to network and phone usage.)
Expansion Slot microSD™ memory card (SD 2.0 compatible)
AC Adapter Voltage range/frequency: 100 ~ 240V AC, 50/60 Hz
DC output: 5V and 1A
* HTC TV Out cable needed.
Con này hơn Diamond ở quả pin Li-Ion 1340 mAh, talk time lên 8h, quá đã. Thấy Diamond pin có 900 mAh tui thì hơi chán. Nhưng giá chăc khủng
Mình mà là đại gia thì mấy Em máy này ra con nào là xào con đó ngay! Nhìn thèm nhỏ rãi!!!:)):)):))
Diamond có bàn phím cứng QWERTY như con này không nhỉ? Mà nói chung là nếu định mua con này em chọn Diamond còn hơn, bàn phím cứng dáng trượt ngang thích máy phải hầm hồ 1 chút cơ, chú này bóng bẩy quá :D
tóm lại là chưa có tiền mua cả 2 ae nhà này :))
Bác nào biết giá của nó công bố là bao nhiêu USD không vậy ?? Kết chú này quá
Em này có bộ nhớ "khủng" thế, chắc chạy ngon lành lắm đây. Bác nào có thông tin thêm về giá cả và khi nào có hàng vui lòng thông tin nhé.
mình nghĩ giá kg dưới 15 chai đâu!!!!.thôi đành quên nó luôn????
Các Bạn cứ dùng đi rồi sẽ thấy chưa có con PDA nào vượt mặt được con O2 XDA EXEC đâu !
Dùng cứ như dùng một chiếc laptop tí hon vậy . Màn hình thì khỏi chê , ROM thì bạt ngàn . Đọc sách , xem ảnh , nghe nhạc , chơi games đều good cả ! :D
UNI có mấy thứ mà đàn em sau này mãi không thay thế nổi:
- Khe SD hỗ trợ SDHC tới 32G.
- Bàn phím to, gõ sướng.
- Màn hình 3.6" VGA.
- Loa Stereo.
- Hồng ngoại xa 7m :D
Tôi cũng đổi qua nhiều máy dùng rồi, vẫn thấy UNI tiện nhất. Giờ chỉ thích cái máy nào có SDHC và màn hình WVGA thôi, thằng HTC Shift bị đi lạc đường rồi >:)
- Loa Stereo.
exec mà ram 128, màn hình cảm ứng gương + GPS thì nó là thiên hạ vô định !!!
em khoái con Touch Pro này quá.Đang chờ em nó ra và chờ...trúng xổ số may ra mới rước e nó về đc:D
Thông tin chính thức từ nhà sản xuất thì HTC Pro có giá dự đoán là 650 USD :O. Nó sẽ xuất hiện ở Châu Âu vào khoảng đầu tháng 9, tiếp sau đó mới là Châu Á. :((
Thật đáng ngạc nhiên và vui mừng vì với cấu hình ''khủng long'' như vậy ( ram 284Mb, Rom 512Mb, Chip 528Hz, Pin 1350Mah, Camera 3.2Mp có đèn Flast - Nói chung cấu hình hơn đứt HTC Diamons) mà HTC Pro chỉ có giá bán 650 USD? Lý do là thay vì bộ nhớ trong tới 4Gb như HTC Diamons thì HTC Pro lại thay bằng khe cắm thẻ Micro SD lên tới 4Gb! Theo quan điểm cá nhân mình thì mình thích thế hơn.
Lời cuối nè, nếu bạn nào có ý định mua HTC Diamons thì tốt nhất nên ''nhịn'' chờ đến khi HTC Pro trình làng nhá, kẻo đến khi ấy lại tiếc hùi hụi...:p:p
Có kiểu gì đi nữa thì vẫn thua em HTC Advantage X7510!:))=D>
Em này RAM có 128Mb thôi mà bác, cũng bình thường, mà nó gần như k phải là PPC nữa rồi, tiến đến dòng UMPC rồi.
RAM 128Mb có thể nâng cấp mà bác, thế giới làm ầm ầm rồi. GPS thì có thể dùng qua bluetooth mà, hơi tốn pin tí, nhưng đầu tư được con pin 5200mAh thì ngon :D
