[HTC UNIVERSAL- 20921] WM6.1 v1.4 by luca16thebig (UPDATED 07/11/08)
luca16
[HTC UNIVERSAL- 20921] WM6.1 v1.4.5 WWE by luca16thebig (UPDATED 11/11/08)
THANKS TO:
Michyprima
Tomal
PDAVIET and XDA Forums
BEPE
TADZIO
FRITZ
NEW VERSION 1.4.5:
New build:20921...
This version should work on G4 and device with 128mb.
Version CE OS 5.2.20758 (Build 20921.1.5.0)
This version is in three flavour: full, light and vanilla... the language is WWE:)
Changelogs v1.4.5 (20921):
-New xip (20758) and new build (20921.1.5.0)
-Memory=50.25mb and pagepool set to 4mb
-Very stable and many ram free!!
-Wktask it's integrated with SnapVue Skin
-Wktask update
-Pocket RAR update
-TotalCMD update
-Link to calculator it's present in Start-Programs
-Link Beam ON in CommManager does work
Know Bugs in v1.4.5 (20921):
-The font of some menus are too big
-IT's not present the multiselect with touchscreen [(It isn't my bug but an error of Roms after 20721 builds...I'm trying to understand how to fix)..for resolve it: use the " Shift " button ]
-Missed Shortcut to PocketRAR,TotalCMD and WkTask: for resolve it download this fix: http://rapidshare.com/files/162773881/luca16thebig_LinkUpdate.cab
Programs added to v1.4.5 (Full Edition-20921):
-Clear Storage
-BT BPP v1
-BTFTP v6
-Connection Setup v1.5
-Voice Speed Dial v1.2.0.1
-Google Maps
-JBlend Java
-PsShutXP
-PacMan 2
-Advanced Config v3.2.0.0
-Network Plugin v1
-Pocket Notepad
-Arcsoft MMS
-TCPMP with flv plugin and flashvideobundle (you can see the video of youtube,megavideo ecc on your tcpmp without save the video to your ppc:))
-DFTaskMgr
-PIM Backup
-PocketRAR
-File DIalog Changer
-CommManager with Diamond Black Skin
-WMP with diamond skin
-Total Commander
-VijayCandela
-WkTask
-SnapVue Theme by default
-ConcurrenceMgr v1.1.18143521.0000
-DSHow v2.00.080522.0
-mHub v6.54.080121.E1
-SD Setting
-ShareDLL v2.0.070522.0000
-VOIP
-Office 6.1 with One Note Mobile
-Games by default (Bubble Breaker and Solitare)
-WModem
-USBtoPC
The free ram in Full Edition after hard reset is 29.18mb!!
Programs added to v1.4.5 (Light Edition-20921):
-SD Setting
-VijayCandela
-PsShutXP
The free ram in Light Edition after hard reset is 31.01mb!!
Programs to v1.4.5 (Vanilla Edition-20921):
-Removed all apps included Office and Games
-VJCandela it's present
-PagePool set to 2Mb
The free ram in Vanilla Edition after hard reset is 32/33 mb!!
DOWNLOAD ROM with RapidShare:
DOWNLOAD v1.4.5 Full Edition(20921):http://rapidshare.com/files/1625772...921_WM6.1_v1.4.5_FULL_WWE_by_luca16thebig.rar
DOWNLOAD v1.4.5 Light Edition(20921):http://rapidshare.com/files/1625836...21_WM6.1_v1.4.5_LIGHT_WWE_by_luca16thebig.rar
DOWNLOAD v1.4.5 Vanilla Edition(20921):http://rapidshare.com/files/1625801..._WM6.1_v1.4.5_Vanilla_WWE_by_luca16thebig.rar
COMMENTS OR DONATIONS:
If you want make me happy please write a Comment or DonateMe
Bác người Ý này chăm chỉ quá, nếu ko có những người như bác thì Universal chắc chết mất.
Bản ROM này Core và XIP mới, được làm theo phong cách "thập cẩm"b-), cũng hay.
THANK!!!!!!!!!!!
Xỉu luôn, bác này ko biết tiếng Việt đâu, Mod đừng ban bác ấy nhé
Em down không được bên RS,có ai Up dùm host khác không vậy!?
Không biết phiên bản Vanilla có tích hợp Vanilla2D không nhỉ!?
Có pác nào up bản này chưa vậy?, cho ít nhận xét xem bản rom ntn, đang down
Bản nay không có FD. Add ứng dụng nhiều quá gần như thập cẩm
Sau khi up thử, dùng khoảng 1 tiếng (có tính chất kiểm tra), tôi cũng cài đủ các ứng dụng ưa thích thấy cũng được, thực ra thì trong Rom cũng không có quá nhiều các thứ thập cẩm như giới thiệu đâu. Giao diện một số thứ có vẻ mới như Window Media. Nhưng anh này chạy nhạc trục trặc (có lẽ là tại máy của tôi), không dùng được nhạc Midi, bàn fím điện thoại đẹp phết, bộ nhớ cũng bình thường, không lớn bằng các bản đang hiện hành, có cái dở là khi mở bất cứ phần mềm nào là trên thanh bar tren màn hình cứ lưu trú lại cho tới khi đóng lại mới mất, tôi không thíc vậy nên lại quay lại bản cũ đang dùng.
K hiểu sao mình up bản này k đc, đã úp 2 lần rồi đều bị treo ở màn hình khởi động, format doc xong up lại vẫn bị, mình đang xài G4, có bác nào bị giống mình k????
I upgraded to version 1.4.5 .. I also added versions Vanilla and Light ..
For more information see the first topic:)
bản rom này chạy tốt trên chip G3, có lẽ không support trên chip G4.
ai down dc bản v1.4.5 Vanilla Edition(20921) vui lòng up lên host khác cho mình và mọi ng dùng với, mình k tải dc ở Rapid, huhuhhu
cảm ơn nhiều
Tạm thời mình mới chỉ upload được 2 phiên bản Light Edition và Vanilla Edition từ mediafire mong bạn thông cảm nhé, mình đang up tiếp phiên bản Full do tải về muộn và cũng không mặn mà lắm.
Phù..! Xong rùi :D
cảm ơn bạn nhìu nha, maianhtungsten !!! Mai mốt có dịp lên Bình Dương nhớ liên lạc zới mình nhé, mình sẽ dẫn bạn đi đổi gió, thưởg thức hương đồng gió nội ở đây, tuyệt lém đóa, hihihih.......
bản rom nì chạy chậm wa, nhận và ngắt cuộc gọi cũng trễ vài giây, mở 1 ứng dụng mà cũng lâu wa chừng lun, mà mìh dùng bản Vanilla, ram còn trống trên 30MB lận đó, hic hic...fai way zia bản Rom DFT & iVGAPPC ROM WM6.1_5.2.20758 trc thôi, chờ bản Rom của bác Tomal nghe nói build mới 5.2.20924 chắc sẽ ổn hơn, hy vọng thế
mà sao bản Rom nì mih cũng k truy cập đc internet lun ?????
Hix hix, định down về Up thử xem sao nhưng nghe mọi người nói chạy chậm và hay bị đứng, lại trễ vài giây khi gọi hay ngắt là mình không dám thử..Đang đợi bản tiếp theo, hy vọng sẽ fix hết những lỗi hiện tại của bản Rom này!!!
