Hướng dẫn sử dụng J.A.F chi tiết.
mình chạy e50-2 dead phone thì báo như sau
JAF version 1.98.62
Detected PKEY: 9000D520
Card life counter: 99.99%
FBUS INTERFACE NOT CONNECTED!!!
USB Cable Driver version: 7.1.8.0
Changing mode...Done!
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
APE Variant file: NONE
Searching for JAF saved location of ini...
Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-171\
Searching for default location of ini...
Checking path: \Products\RM-171\
Scanning ini files...
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-171\RM171p_0705.C01
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-171\RM171p_0705.L511
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-171\RM171p_0705.U511
Backing up CRT...
Detected P-KEY: 9000D520
Init usb communication...
Failed to backup CRT...
PRESS POWER ON NOW!
Searching for phone...Found
Sending RAW loader...
Using 06.02.002
Elf2flash 02.36.000 RAW loader...
Patching RAW boot step1...
Patching RAW boot step3...
Sending RAW Loader...
...................Invalid APP Loader sign.
Error booting phone...
có thể giúp mình với
Bạn thử flash lại vài lần xem sao.
Nhớ kiểm tra pin trước khi flash nhé.
Lần sau bạn để thông báo lỗi trong thẻ CODE nhé. Như vậy dễ xem hơn, tránh tình trạng kéo dài topic. Thân
Mình chạy e50-1 dead phone thì báo như sau
Mã:
JAF version 1.98.62
Detected PKEY: 9000C70F
Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-170\
Checking path: \Products\RM-170\
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-170\RM170p_0736.C01
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-170\RM170s_0736.L205
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-170\RM170_EMEA.U205
Backing up CRT...
Detected P-KEY: 9000C70F
PRESS POWER ON NOW!
Using 06.02.002
...................Loader Sent!
Stage 2 starting.........................................................Loader Sent!
Stage 3 starting..........Phone prepared OK!
Waiting for the phone to boot...
Status byte: 0400
Selecting CMT flash...
Result: 0000
Phone is in flash mode...
CMT blocks: 270, APE blocks: 0
Erasing cmt...
Processing C:\Program Files\Nokia\Phoenix\Products\RM-170\RM170p_0736.C01...
Erasing cmt zone 00380000 - 01F7FFFF ... Erase result: 0000
Erasing cmt zone 00000400 - 000006BF ... Erase result: 0000
Erasing cmt zone 000006C0 - 0000FFFF ... Erase result: 0000
Erasing cmt zone 00010000 - 000105FF ... Erase result: 0000
Erasing cmt zone 00010600 - 00010FFF ... Erase result: 0000
Erasing cmt zone 00011000 - 00011FFF ... Erase result: 0000
Erasing cmt zone 00012000 - 00013FFF ... Erase result: 0000
Erasing cmt zone 00020000 - 0013FFFF ... Erase result: 0000
Erasing cmt zone 00140000 - 0032FFFF ... Erase result: 0000
Erasing cmt zone 00330000 - 0033FFFF ... Erase result: 0000
Erasing cmt zone 00340000 - 0037FBFF ... Erase result: 0000
Erasing cmt zone 0037FC00 - 0037FFFF ... Erase result: 0000
Erasing cmt zone 01FA0000 - 01FDFFFF ... Erase result: 0000
Erasing cmt zone 00000000 - 012FFFFF ... Erase result: 0000
Processing C:\Program Files\Nokia\Phoenix\Products\RM-170\RM170s_0736.L205...
Erasing cmt zone 01300000 - 035FFFFF ... Erase result: 0000
Processing C:\Program Files\Nokia\Phoenix\Products\RM-170\RM170_EMEA.U205...
Erasing cmt zone 03600000 - 07CFFFFF ... Erase result: 0000
Send CMT CFG...
Writing cmt...
Sending CMT HASH for MCUSW
Sending CMT HASH for NOLO
Sending CMT HASH for KEYS
Sending CMT HASH for PRIMAPP
Sending CMT HASH for PMM_CONF
cmt->PAPUB_CERTIFICATE_DATA_BB5 block detected
cmt->PAPUB_CERTIFICATE_DATA_BB5 block detected, sending...
Sending CMT HASH for DSP0
Sending CMT HASH for SOS+ISASW
Sending CMT HASH for PASUBTOC
Sending CMT HASH for UPDAPP
Rebooting...
Restarting CMT...
Pooling phone...
Phone not found...
Second try...
MCUSW: (null)
APESW: (null)
VariantSW: (null)
Prodcode:
Setting test mode...
Failed! Aborting!
Done!
đã thử lại khá nhiều lần với các firm khác nhau nhưng vân báo lỗi như vậy, có cách nào giúp mình nhé
Cám ơn các huyh nhiều
@Rosso: Bạn dùng Navifirm để down bản mới nhất thử nha. Bạn flash với FW bao nhiêu vậy. Hiện tại có phải máy bạn mở nguồn lên Nokia rồi tắt ko.
Mình dùng Navefirm để down rồi, mình đã thử Flash với bản 7.36.0.0.1 rồi .5 và .6 nhưng đều báo vậy, đang down bản 7.5.0.0.2 để thử xem sao
Mở nguồn lên bây h chỉ trắn màn hình rồi tắt luôn (Pin đầy)
Cám ơn tsthanhhai nhiều=D>
N81 FW mới nhất có gì khác biệt với bản cũ không.Ai biết trả lời giúp mình để mình còn biết mà update.Nếu không có gì khác biệt nhiều thì minh khỏi update tốn công.:-??
Con của bạn có khả năng phải mua log rồi. Trước mình cũng nhận 1 con như thế phải mua log.
@Rosso: Bạn chỉ nên dùng 1 bản mới nhất thôi 7.36.0.0.6. Nếu ko được thì dùng bản khác cao hơn, Language khác cũng được, cứu máy lên trước rồi downgrade lấy ngôn ngữ sau nhé.
Hix, mình đã thử cả ver 7.36.0.0.6 và bản 7.5 rồi nhưng cứ chạy đến đoạn ..pooling phone là lại bị như trên.:((
Đã quá đã up được fw v20 cho em 5800
thanh bạn tsthanhhai nhìu lắm, mình đang up fw v20 cho em 5800, mấy chục lần không được, may mà up sao đó bị die máy luôn (hỏng bật nguồn được) nhờ bài này mà đã up thành công lun rùi, phê :D
hô hô mình vừa up được con 3250 của mình lên ver 4.60.thanks các pác nhá.dùng cái JAF này đã thật.3 con máy của mình(5800 XM,3250XM,N72) đều đươc thằng JAF này chơi cho FW mới nhất.các bạn cứ đọc kĩ hướng dẫn ở đây http://pdaviet.net/showthread.php?t=46660 là lam ok ngay.thân;;)
lưu ý ở hình số 6 từ link trên:phải nhấn nút tắt nguồn từ khi có dòng "Rebooting to flash mode..."trên dòng Searching for phone..." 2 dòng
chứ kô phải dòng "Searching for phone..." như đã hướng dẫn.bước này rất quan trọng đấy:-?
có cách nay đổi cái RM- của máy ko bạn nhỉ. chứ mình dùng E71-3 RM-407 mà nó ko có firm tiếng việt. phải change RM nữa thì mới đổi TV đ5c hĩ hix
Theo mình đc biết thì E71 chưa flash từ E71-3 sang E71-1 đc.
Các bác cho em hỏi cái nhé, có thẻ "hạ" fw N82 30,31 xuống 20 hay 10 dc ko? nếu dc thì dùng chương trình nào ?
thanks các bác nhiều!
Hạ đc, nhưng phải dùng Box chuyên dụng, dùng USB dễ die máy.
em ko thể mở JAF lên được. nó báo can't creat file c:\program file\odeon\jaf\winscard.dll
cứu e với
tôi ko biết hạ con khác thì sao nhưng t vừa nghịch 1 con 3250 ver 4.60 hạ xuống 3.24, ban đầu cũng lo nhưng hạ ngon lành, cứ như ko sợ tai nạn j ý, bác làm thì nhớ chú ý bác chủ topic căn dặn thôi, nếu có nhu cầu và ko sợ thì bác cứ làm, có ng đi trc roài mà
