ORIGINAL DEB
MIRRORCREATOR
MEDIAFIRE
KEYGEN
MIRRORCREATOR
MEDIAFIRE
iBlackList allows your to create a blacklist or whitelist for filtering purposes. iBlacklist also features a scheduler which allows you to set the time of day iBlackList is active. The unregistered version of iBlackList allows you to filter 2 numbers. For unlimited numbers your must register.
Now to add a number to our BlackList press the BlackList button.
Press Settings Calls to modify the settings for call filtering. Here you can set the action to take when a filter call comes in. You can also enable or disable the call filter and set the preferences to save history, delete recent calls, filter restrict number, filter unknown number, show a status bar icon, and vibrate. Press the Save
button at the top left hand corner when finished modifying the settings.
We can also press Settings SMS to modify the filter options for SMS messages. Here you can enable or disable SMS filtering and set the preferences to save history, delete SMS upon receipt, filter unknown number, show a status bar icon, and vibrate. Press the Save button at the top left hand corner when finished modifying the settings.
You can press Scheduler from the main menu to set the iBlackList's operation schedule.
Press to select a day of the week and you can modify the hours iBlackList is enabled for that day.
Press the Save button at the top left to return to back to the iBlackList menu.
Finally you can also change your password by pressing the Password button on the main menu. Enter a new password and then press the large red Save password button.
You can now press the Home button to exit iBlackList. When ever you receive a filtered text or call you will notice an icon in your Status bar. Press to launch iBlackList from the SpringBoard.
