TP.HCM LG F180S Fix Sóng Ok !
Taki7610
Unlock_GSM
Mã:
Converting files...
Unpacking "H:\PHONE\LG\F180L-E975-F180S-F180K\F180S\F180S10g_00.kdz"...OK
Unpacking "C:\Users\DELL\AppData\Local\Temp\F180S10g_00\F180S10g_00.cab"...OK
Opening "C:\Users\DELL\AppData\Local\Temp\F180S10g_00\F180S10g_00.dz"...OK
Unpacking "PrimaryGPT"...OK
Unpacking "modem"...OK
Unpacking "sbl1"...OK
Unpacking "sbl2"...OK
Unpacking "sbl3"...OK
Unpacking "aboot"...OK
Unpacking "rpm"...OK
Unpacking "boot"...OK
Unpacking "tz"...OK
Unpacking "misc"...OK
Unpacking "system"...OK
Unpacking "system1"...OK
Unpacking "system2"...OK
Unpacking "system3"...OK
Unpacking "system4"...OK
Unpacking "system5"...OK
Unpacking "system6"...OK
Unpacking "system7"...OK
Unpacking "system8"...OK
Unpacking "system9"...OK
Unpacking "system10"...OK
Unpacking "system11"...OK
Unpacking "system12"...OK
Unpacking "system13"...OK
Unpacking "system14"...OK
Unpacking "system15"...OK
Unpacking "system16"...OK
Unpacking "system17"...OK
Unpacking "persist"...OK
Unpacking "recovery"...OK
Unpacking "BackupGPT"...OK
Unpacking done. Processing files...
Identifying sub-files...OK
Creating destination file...OK
Deleting temporary files...
Deleting directory "C:\Users\DELL\AppData\Local\Temp\F180S10g_00\"...
Deleting file "C:\Users\DELL\AppData\Local\Temp\F180S10g_00\aboot.bin"...OK
Deleting file "C:\Users\DELL\AppData\Local\Temp\F180S10g_00\BackupGPT.bin"...OK
Deleting file "C:\Users\DELL\AppData\Local\Temp\F180S10g_00\boot.bin"...OK
Deleting file "C:\Users\DELL\AppData\Local\Temp\F180S10g_00\F180S10g_00.cab"...OK
Deleting file "C:\Users\DELL\AppData\Local\Temp\F180S10g_00\F180S10g_00.dz"...OK
Deleting file "C:\Users\DELL\AppData\Local\Temp\F180S10g_00\G_TDR_0141.dll"...OK
Deleting file "C:\Users\DELL\AppData\Local\Temp\F180S10g_00\misc.bin"...OK
Deleting file "C:\Users\DELL\AppData\Local\Temp\F180S10g_00\modem.bin"...OK
Deleting file "C:\Users\DELL\AppData\Local\Temp\F180S10g_00\parts.bin"...OK
Deleting file "C:\Users\DELL\AppData\Local\Temp\F180S10g_00\persist.bin"...OK
Deleting file "C:\Users\DELL\AppData\Local\Temp\F180S10g_00\PrimaryGPT.bin"...OK
Deleting file "C:\Users\DELL\AppData\Local\Temp\F180S10g_00\recovery.bin"...OK
Deleting file "C:\Users\DELL\AppData\Local\Temp\F180S10g_00\rpm.bin"...OK
Deleting file "C:\Users\DELL\AppData\Local\Temp\F180S10g_00\sbl1.bin"...OK
Deleting file "C:\Users\DELL\AppData\Local\Temp\F180S10g_00\sbl2.bin"...OK
Deleting file "C:\Users\DELL\AppData\Local\Temp\F180S10g_00\sbl3.bin"...OK
Deleting file "C:\Users\DELL\AppData\Local\Temp\F180S10g_00\system.bin"...OK
Deleting file "C:\Users\DELL\AppData\Local\Temp\F180S10g_00\tz.bin"...OK
Directory "C:\Users\DELL\AppData\Local\Temp\F180S10g_00\" succesfully deleted!
Firmware convert done!
Checking data...OK
Platform: LG Qualcomm
Selected port: COM4
Selected model: F180S
Searching Diagnostic Ports...OK
Reading info...Failed!
Could not detect mode!
Checking data...OK
Selected port: COM192
Reading info...OK
Mode: Emergency
Model ID: BS/J1STLSG/1
SW version:
Opening "F180S10g_00.oct"...OK
Initializing flash...OK
Reading partition...OK
Writing PrimaryGPT...OK
Formating userdata...OK
Formating cache...OK
Writing modem...OK
Writing sbl1...OK
Writing sbl2...OK
Writing sbl3...OK
Writing aboot...OK
Writing rpm...OK
Writing boot...OK
Writing tz...OK
Writing system...OK
Writing persist...OK
Writing recovery...OK
Writing BackupGPT...OK
Finalizing...OK
Writing firmware done!
