It`s my post from XDA:
Solve problem with ActiveSync starting automaticaly
1. Turn on your KS20
2. Go to Start > Programs > Activesync. This will open the Activesync program.
3. Tap Menu at the bottom right hand corner of the screen. This will bring up the Options Menu. Notice the option Schedule... is greyed out? This is the all-critical option we need to get access to. But as it's disabled we can't change Activesync's default synchronisation schedule.
Ok, so how do we enable the Schedule option? Easy!!! Fool Activesync into thinking there is an Exchange Server to sync with:
1. From Activesync's Menu tap on Add Server Source.
2. In the following screens you can enter any old garbage. It does not matter, but just in case your unsure, just type the following in the indicated boxes:
Server Address: fake
Tap Next
User name: fake
Password: fake
Domain: fake
(Ticking save password or going into the Advanced menu makes no difference, so no need to bother).
Tap Next
Untick all of the 'Data you want to synchronise' options
Tap Finish
3. Ok, we're done creating the server. You should now see in Activesync's main screen your normal Activesync connection(s), and a new connection called Exchange Server.
4. Go back into the Menu, and lo and behold the Schedule option is now enabled! Go ahead and tap it!
5. You will see that both options in the Schedule screen are set to Every 5 Minutes , or Every 10 Minutes. This simply will not do!
6. Using the drop downs, change both the Peak times and Off-peak times boxes to Manually.
7. Press the OK button at the top right of the screen.
Congratulations! Activesync is now gagged from opening on it's own and ruining your life!
So there you go, your KS20 will now be happy to lead a normal and fulfilling life serving your organisational needs.
Ps:
New server doesn't influence the ks20 work. No delete new server.
Tap Next
User name: fake
Password: fake
Domain: fake
Tap Next
Tap Finish
Ps:
