Lockscreen WM 6.5
Lockscreen-1.8C,D,E final-WWE (12/12/2009)
Phần mềm khóa phím, Trượt để nhận, từ chối cuộc gọi, Thông báo cuộc gọi nhỡ, SMS, báo thức......Cho Windows Mobile 5.0,6.0,6.1 & 6.5. Đã tích hợp với Rom WM6.5 phiên bản cập nhật ngày 09/12/2009
Mã:
12-12-08pm NEW 1.8C,D,E release WWE
fixed some bugs of 1.8b
if new lock is unchecked .Device does not lock with old lock app when out call or income call .
new:
1.when you receive a call while lock screen running.
Device will into USER_IDLE MODE NOT SYS_IDLE MODE within 5 seconds when call is connected
2 when you send a call while lock screen running.
Device will into into USER_IDLE_MODE NOT SYS_IDLE MODE even if call is not connected.
3.All the hardware key are locked . when coming a call or out a call. You can not receive or reject a call via any hardware key.If screen is off automatically within 5 seconds. (USER_IDLE) You can press any hardware key to turn screen on(INCLUDE reject or receive button.Do not warry about rejecting a call or receiving a call).You can't press power button.Because device is ON just into USER_IDLE MODE.
Lockscreen v19A (20/12/2009)
Mã:
1. But if you install any old one you did better make a hard-rest .
2. separate lock trigger and stand-by. there are no relationship between them.
3.add delay time .it start from screen lock app run. but it work just you check lock and then stand-by
4.add energy optimization. Check it the stand-by means that suspend without call connecting and USER_IDLE with call connecting.
. But every app stop run.So be careful with checking it.e.g:if alarm ring ,it wake up device, but when it suspend ,alarm stop and silence.Uncheck it ,Stand-by means SYS_IDLE without call connecting, USER_IDLE with call connecting.
5.Separate ms sign 。So if it do not works please install cert.cab and reboot..
6. Fix all exist bugy
Lockscreen _ SmartLock v19B (24/12/2009)
Phần mềm khóa phím, Trượt để nhận, từ chối cuộc gọi, Thông báo cuộc gọi nhỡ, SMS, báo thức......Cho Windows Mobile 5.0,6.0,6.1 & 6.5. Đã tích hợp với Rom WM6.5 phiên bản cập nhật ngày 24/12/2009
Mã:
1. Add lock sound。
How to replace sound yourself.
uncheck Enable sound and OK.
rename sound file to unlock.wav or lock.wav
copy them to window over write old one.check enable sound and ok.
just support wav format. it better no longer than 3 seconds.
2. fixed a faults. check incall lock , when a call coming ,a call coming notify windows will show by OS.It doesn't show again now.it 's related to language of OS . language of OS: 0409.0404) has fixed
Skin Lock Screen WEIRDO_weirdo_green
Đây là Skin thôi nhé!! Tải về cài vào Main.
Sao máy của mình khi khóa vào màn hình tối lắm không nhìn rõ gì cả. Khi up rom xong cứ vào khóa là màn hình lại thấy tối thui a. Ai biết cách chỉnh thì chỉnh giùm với. Sao mình cài những cái mà bạn up lên sao không thấy có hình như hướng dẫn là sao? Máy điện thoại của mình đang dùng là I8000. Các bạn giúp mình với nhé. Cảm ơn nhiều./.
Lockscreen _ SmartLock-2.0A-ENU (28/12/2009)
Phần mềm khóa phím, Trượt để nhận, từ chối cuộc gọi, Thông báo cuộc gọi nhỡ, SMS, báo thức......Cho Windows Mobile 5.0,6.0,6.1 & 6.5. Đã tích hợp với Rom WM6.5 phiên bản cập nhật ngày 28/12/2009
Mã:
ChangeLog:
1. Optimize some code .
2. Add BlockProcessList.txt . one of more app run which in the list .when device dim ,it doesn't lock .edit it and reboot then setting work.
you can find it in Windows
Please edit it with PC make sure it code by UNICODE
3. fixed some bugs of 1.9 series.
Đặt biệt phiên bản v2.0A có hổ trợ âm thanh khi khóa/mở.
Lockscreen _ SmartLock-2.0B & 2.0C -ENU (31/12/2009)
Lockscreen _ SmartLock-2.0B-ENU (31/12/2009)
Phần mềm khóa phím, Trượt để nhận, từ chối cuộc gọi, Thông báo cuộc gọi nhỡ, SMS, báo thức......Cho Windows Mobile 5.0,6.0,6.1 & 6.5. Đã tích hợp với Rom WM6.5 phiên bản cập nhật ngày 31/12/2009
Mã:
Changelog:
1.Add option disable hardkeyboard when call connected
2.Add option blink LED when CALL connected or GPRS/EDGE/3G connected
3.Fixed some bugs of 2.0A
4.More robust.
5.Do not sign with MS SDK cert.cab
sign version will release tomorrow.it is same as today but sign.
I hope many people test it without sign.And report below.
(JUST FOR TESTING)
how to fixed device donot dim.
HKLM\\SYSTEM\\CurrentControlSet\\Control\\Power\\S tate\\BacklightOff
bkl1: 4 or 2
Lockscreen _ SmartLock-2.0C-ENU (31/12/2009)
Mã:
2.0C is same as 2.0B just add a reg value named Enable .
So it will not hang on OS without new styple lock, If 2.0B work will you donot need 2.0c
Many device do not implement boot message So abolish lock on boot.
there is no enough information to distinguish 6.1 and 6.5 ,So if your rom is 6.5 ,check new WM 6.5 lock .The default is uncheck it.
Đặt biệt phiên bản v2.0B và v2.0C có hổ trợ âm thanh khi khóa/mở.
Lockscreen _ SmartLock-2.0D-ENU (01/01/2010)
Chúc mừng năm mới 2010.
Phần mềm khóa phím, Trượt để nhận, từ chối cuộc gọi, Thông báo cuộc gọi nhỡ, SMS, báo thức......Cho Windows Mobile 5.0,6.0,6.1 & 6.5. Đã tích hợp với Rom WM6.5 phiên bản cập nhật ngày 01/01/2010
Mã:
ChangeLog:
Fiexd a serious bug of 2.0C
lock fails
Cài đặt file dẫn Certv2.0D.cab trước và Cài SmartLock v2.0D.cab vào sau Reset PPC. Vào Start/Settings/System/Smart Lock. Cấu hình theo hướng dẫn minh họa, Bạn có thể thay đổi khác sao cho phù hợp với ý muốn của Mình.
Mã:
(X) WM6.5 new lock
(X) Backlight trigger lock screen
( ) Stand-by trigger lock screen
(X) Incall lock
( ) Outcall lock
(X) Outcall connected lock
( ) Keep enable when charging
(X) Lock screen then stand-by
( ) Energy optimization
(X) Enable lock sound
(X) Disable hardkeyboard when using tel
(X) Blink LED when talking
Delay time: 6 Seconds
Xin cho hỏi, như vậy là phải cài đồng thời cả 2 file phải không bạn? Hay là chỉ cần cài bất cứ 1 trong 2?
Cám ơn!
Cám ơn!
Lockscreen _ SmartLock-2.0E-ENU (03/01/2010)
Phần mềm khóa phím, Trượt để nhận, từ chối cuộc gọi, Thông báo cuộc gọi nhỡ, SMS, báo thức......Cho Windows Mobile 5.0,6.0,6.1 & 6.5. Đã tích hợp với Rom WM6.5 phiên bản cập nhật ngày 03/01/2010
Mã:
ChangeLog:
1.Fixed a dead lock bug with blocklist thread.it will produce strange problems
2.Add a new function. disconnect DATA connection (GPRS/EDGE/3G).
Cài đặt file dẫn Certv2.0E.cab trước và Cài SmartLock v2.0E.cab vào sau Reset PPC. Vào Start/Settings/System/Smart Lock. Cấu hình theo hướng dẫn minh họa, Bạn có thể thay đổi khác sao cho phù hợp với ý muốn của Mình.
Lockscreen _ SmartLock-2.0F-ENU (09/01/2010)
Phần mềm khóa phím, Trượt để nhận, từ chối cuộc gọi, Thông báo cuộc gọi nhỡ, SMS, báo thức......Cho Windows Mobile 5.0,6.0,6.1 & 6.5. Đã tích hợp với Rom WM6.5 phiên bản cập nhật ngày 09/01/2010
Mã:
ChangeLog:
1.Fixed little bug of 2.0E
2.using KBD HOOK instead of enablekeybbd,it disable kbd from low level.
NOTE:YOU CAN NOT INSTALL IT WITH APP WHICH USED HOOK.
SUCH AS AE Button Plus.THERE IS ONLY ONE HOOK IN WINCE 5.
I THINK 2.0F EAT MORE POWER THEN 2.0E
Cài đặt file dẫn Certv2.0F.cab trước và Cài SmartLock v2.0F.cab vào sau Reset PPC. Vào Start/Settings/System/Smart Lock. Cấu hình theo hướng dẫn minh họa, Bạn có thể thay đổi khác sao cho phù hợp với ý muốn của Mình.
Skin WM65_LockScreen_HTC_HD2_v2.2
Giao diện SmartLock (LockSreen cho HTC HD2 v2.2)
attachment.php
Anh Phê ơi làm sao để thêm tên lên screenlock như của a đó "VNPT Nguyễn Văn Phê" , a chỉ e với .Cám ơn a nhiều , mới xài WM6.5 nên e gà lắm .
ngo_minh
@ngo_minh:
Dùng chương trình Registry thêm khóa hoặc thay đổi khóa:
Tìm đến khóa: [HLM\Sofware\Microsoft\Shell\Device Beta]
"Expiry"="Tên Bạn"
"Today"="Cty hay gì đó..."
Thêm 1 cáci Skin LockScreen của Dusk Lock
