Sắp được thay thế miễn phí pin MacBook Pro 15 đúng như ti-pha dự đoán rồi.
https://support.apple.com/macbookpro15/batteryexchange/index.html
The affected batteries have model number A1175 and a 12-digit serial number that ends with U7SA, U7SB or U7SC. To view the model and serial numbers located on the bottom of the battery, you must remove the battery from the computer. The battery serial number is located above the barcode. See photos below. Only batteries within the noted serial number ranges need to be exchanged.
No other MacBook Pro or MacBook batteries are part of this program.
Cuả em là have model number A1175 and a 12-digit serial number that ends with U7SB (có trong replacement list)
Chả biết nên buồn hay vui nữa ha ha...
hix hix...
