Mới tìm được 1 cách để có thể improve tốc độ của WM2005,và đã thử với O2s của mình thấy quả là có tăng lên đáng kể.Gởi cho mọi người tham khảo nhé:
1. Enter ActiveSync and change Schedule
First go to PPC ActiveSync, then choose Menu > Add Server Source ...,Enter any values you like, just make sure something is entered for each field, select Next until reach Finish (because need to set one dummy Exchange Server setting in order to edit the Schedule)
Once back to ActiveSync, select Schedule... from Menu > Set both Peak times and Off-peak times to Manually
And then enter Menu and choose Options ...>Choose Exchange Server and then select Delete > At Warning Message windows, select Yes to delete the Exchange Server setting created
2. Use registery editor, delete below two keys
HKEY _ LOCAL _ MACHINE\drivers\Builtin\StrataFMD\CompactionCritPrio256
HKEY _ LOCAL _ MACHINE\drivers\Builtin\StrataFMD\CompactionPrio256
Because these two keys will cause fikesys.exe to constantly use up CPU resources up to 100%
3. Use registery editor, update below three keys
HKEY _ LOCAL _ MACHINE\System\StorageManager\FATFS\Cac heSize =0x1000(4096)
HKEY _ LOCAL _ MACHINE\System\StorageManager\FATFS\Ena bleCache =0x1(1)
HKEY _ LOCAL _ MACHINE\System\StorageManager\Filters\f sreplxfilt\ReplStoreCacheSize =0x1000(4096)
If you feel the machine is not running too slow, you are advised not to change the setting
