[New Build - v3B1] Uni WM6 Pro - 5.2.1921 (Build 18521.0.7.0)
khoi
ranju mới build bản v3B1 , tác giả này có bản ROM lần trước giới thiệu cũng rất tốt mà mình đã post ở đây
http://www.pdaviet.net/showthread.php?t=13108
Các bạn cùng test nhé
There is a new core for your Universal.
I tried to keep it vanilla (as usual) and only most needed tools have been incorporated to the build.
The most features and usefulness of v3B1:
-- Removed SQM
-- Removed OneNote
-- Removed Transcriber
-- Removed Windows Live/Live search
-- Removed Auto Update/Approve Update
-- Fixed XIP for G3/G4 support, No Flash Disk
-- Added pBar 1.4 Task manager [with little cosmetic update] (by nncuong)
-- Added WM5torage (USB HDD Emulation)
-- Added PocketRAR 3.71 (with .zip/.rar association)
-- Added Adobe Reader LE 2.0 (optimized)
-- Added OxiosHibernate 1.3 and Performance/overclocking applet
-- Added a light-weight Birthday today plugin
-- Added a BT Audio router for routing system-audio to the (mono) BT headset
-- STK srvice, SIM Mamager and all common applications
-- SMS delivery fix (by Saman)
-- Voice notification (interesting!)
-- SDHC driver (by mamaich) [standard SD driver to be installed for SD issues]
-- SD block transfer size set to 256k (for HQ video playback)
-- Default GSM mode set to "GSM" (to save battery) [it can be changed from phone setting]
-- Set default search to Google (desktop) search
-- Default favorite added: Google, Gmail (desktop) and XDA-Developers - Universal
-- PIE cache (temp, cockies & history) relocated to the root (\IE Cache) for easy cleaning
-- PIE cache limit set to unlimited and tweaked to get best performance
-- Improved - device wakeup from sleep (before alarms)
-- Registry-type set to file-based; it will help not to forget the settings made by the user
-- Set default dev-id and BT name to "Universal"
-- Disabled incoming beams (to save battery)
-- Today item set to hidden of "Messaging", "Wireless" and "Keylock" (Unhide from Today setting, if needed)
-- Default notification type set to "Visible + Beep"
-- Unlock/Unhiding tool for extROM
-- Few other bug fix / tweaks
-- A new boot splash
Build v3 (Beta-1):
http://vidmes.com/Uni/Kitchens/ranju...8521_0_7_0.rar
Notes on SD driver Installation:
1. Copy the SD driver cab to your main storage
2. Remove the SD card from the device
3. Install the driver and soft RESET
4. Insert your SD card
trơi ạ sao nhiều bản rom thế. có ai đã thử chưa xin cho ý kiến nhé
bản v2 của ranju mình đang dùng rất ổn định và nhanh, để xem bản này thế nào.
sau khi test từ chiều đến giờ mình nhận thấy bản rom này ko bằng bàn v2:
tốc dộ chậm, hay treo. lỗi đọc thẻ nhớ, cài fix xong thì ko nhận thẻ nnhớ.
một vài ý kiến sơ bộ mong các bác xem xét.
Thế này thi không giám rồi. Đang dung bản 2.11.10 G3 thấy OK. Đang dùng rất ổn định.
sau khi test mình đành phải quay về dùng bản 2.11.10 G3 của bác nncuong thôi. mặc dù rất thích bản rom trước đây của ranju.
[Final - v3] Uni WM6 Pro - 5.2.1921 (Build 18521.0.7.0)
Sao lại không bằng bản v2 , mình thấy bản này rất ổn chỉ có một lổi là gởi file bằng BT chậm quá có khi không được.
OK nay tác giả ra tiếp bản v3 final đây
The most features and usefulness of v3:
-- Removed SQM
-- Removed OneNote
-- Added pBar 1.4 (by nncuong) Task manager [with little cosmetic update by me]
-- ArcSoft MMS
-- Standard SD driver (no SD issues)
-- Improved device wake-up from sleep (before alarms)
-- Today item set to hidden of "Messaging", "Wireless" and "Keylock" (Unhide from Today settings, if needed)
Current build v3:
Có bác nào dùng thử chưa? Cho biết y kiến đi. Mình cũng đang định thử nhưng mới dùng 2.22.10 G3 của Bác nncuong được 3 ngày nên chưa tiện thử bản mới.
Phải công nhận Ranju làm Rom khá ổn định, tuy nhiên bản này vẫn k khắc phục đc BT:((
Phải công nhận là ROM của RANJU chạy tốt thật. Mình thấy rất ổn định, và cũng không mấy hao pin (mình dùng trên MDA pro).
