[New Build - v6 Blue] Uni WM6 Pro - 5.2.1933 (Build 18548.0.7.0)
HungUTD
Features and changes of v6 (Build - 18548):
-- WkTask 1.1.7.3 (by waku) Task manager
-- WM5torage 1.78 (USB HDD Emulation)
-- Total Commander 2.5
-- PocketRAR 3.71 (with .zip/.rar association)
-- Adobe Reader LE 2.0 (optimized)
-- ArcSoft MMS Composer
-- OxiosHibernate 1.3 (no popup) and Performance/overclocking applet
-- TodayAgenda 1.0 today plugin
-- New Camera (Build - 25626)
-- TCPMP 0.72RC1 media player
-- DF's PIM Backup 2.7 (for contact, sms backup etc.) and Task Manager 2.9
-- SynchroTime (by Grachov) for Internet time sync
-- HTC Network plugin
-- Voice notification & ringtones
-- New 9-button ComManager (Blue)
-- File-Dialog changer (for better browsing)
-- SD/SDHC support (settings applet from JW)
-- CompactFramework 2.0 SP1
-- STK srvice, SIM Mamager and all common applications
-- SMS delivery fix (by Saman)
-- SD block transfer size set to 256k (for HQ video playback)
-- Default GSM mode set to "GSM" (to save battery) [it can be changed from phone setting]
-- Set default search to Google (desktop) search
-- PIE cache (temp, cockies & history) relocated to the root (\IE Cache) for easy cleaning
-- PIE cache limit set to unlimited and tweaked to get best performance
-- Improved device wake-up from sleep (before alarms)
-- Registry-type set to file-based; it will help not to forget the settings made by the user
-- Set default dev-id and BT name to "Universal"
-- Disabled incoming beams (to save battery)
-- Disabled today plugin - Date, Appointments & Tasks (replaced with TodayAgenda)
-- Today item set to hidden of "Messaging", "Wireless" and "Keylock" (Unhide from Today settings, if needed)
-- Exe's & Dll's transformed into module (wherever possile)
-- Unlock/Unhiding tool for extROM
-- New Blue theme and boot splash
-- Pagepool set to 5.2 MB
-- Should work on G3/G4 both devices [No Flash Disk]
Current Build v6 (18548.0.7.0):
http://vidmes.com/Uni/Kitchens/ranju...1933_18548.rar
Old Build v5.1 (18533.0.7.0):
http://vidmes.com/Uni/Kitchens/ranju...1933_18533.rar
enh em test song thì xin cho ý kiến nhé, xem bản rom này có gì khác với các bản rom trước không nhé
mình test Bản Rom này của Ranju rồi có ý kiến như sau:
sau khi up thấy màn hình khởi động rất đẹp nhưng nó đứng ở đó luôn. Khi up sang bản Rom khác cũng bị kẹt ở đó. Cuối cùng phải format DOC mới hết.
Nếu ai chưa có ROM gốc WM5, tool exit botloader và chưa biết cách format DOC thì đừng up thử rom này.
Mình test bản Rom này hoạt động tốt, Ram rất ổn định, tốc độ nhanh (mặc nhiên là 624 MHz, nhưng mình chỉnh về 520 MHz cũng đủ nhanh).
Chỉ hơi bị trục trặc về kết nối GPRS. Các tính năng khác bình thường.
thế theo bác thì bản rom này là do lỗi rom hay là lỗi ở máy hả bá:-/c
Tôi dùng thử sau một ngày thấy điểm chưa được của Rom này là khi bật máy lên phải đợi ít nhất là 5 đến mười giây sau chọc màn hình mới có tác dụng, tôi cho là đây là lỗi không bằng các bản rom khác mặc dù mọi thứ khác của bản rom này đều tốt.
Theo mình khi cho ra đời một bản ROM thì tác giả đã test trước sau đó là đưa cho một số thành viên thân cận test tiếp khi thấy nó chạy tốt thì mới đưa ra cho cộng đồng. Tuy nhiên trên dòng Uni thì có những bản rom hợp với máy này nhưng lại có khi kén với máy khác nhất là dòng này lại có rất nhiều rom để cho mình vọc. nếu mình cẩn thận thì trước khi up một bản rom mới chưa rõ nguồn gốc thì nên unlock sim trước để tránh những trục trặc không đáng có. nếu bạn nắm khá rõ về kỹ thuật up rom thì sẽ khắc phục được các lỗi khi gặp phải. Vậy thì:
- Nếu máy đang hoạt động tốt trên một bản rom khác thì mình phải nhận định là không phải lỗi do máy.
- Trong trường hợp này khi up rom mới nếu mình đã format DOC (để làm sạch máy) rồi up mà chạy vẫn không tốt thì là do bản rom chưa ổn định.
khi nhận được câu hỏi của bạn mình đã format DOC rồi up lại thử thì thấy bản rom này chạy cũng được nhưng nhưng thỉnh thoảng vẫn bị treo máy nên xác định là bản rom chưa ổn.
đúng là bản rom này hơi có vấn đề về kết nối GPRS bị lỗi không vào được còn WIFI thì tự động ngưng kết nối và hay bị treo máy
