[NEW CORE - 19900] Tomal's - v7.7: WM6.1 Pro
DucLong
Super V.I.P
Các bác test thử bản Rom này xem. hình như đây là bản được chỉnh sửa từ bản v7.7 của Ranju
New Core of WM6.1 Pro - CE OS 5.2.19900 (Build 19900.1.0.2) with "12.5 MB Flashdisk".
There are so many ROM's (from the different builds) are floting around. But few of them I discovered has less database mess (i.e. Build 18188, 19400 and 19900). Finally, I decided to build my next rom based on 19900 and I would stick on that for some time (until I find another).
Changes and Features of v7.7:
-- New WM6.1 Core + OS (Build 19900)
-- New Memory Manager / Auto hibernate
-- New Advanced Config tool (by Schap) with custom config
-- New System Tray (delete link from startup if you don't like)
-- New Enhanced OEM Drivers and DirectShow filters
-- New (replaced) 6-button CommManager
-- New (replaced) Calculator
-- Fixed IRDA issue
-- Fixed ActiveSync over BT
-- Fixed external connection creation issue (e.g. BT under connection menu)
-- Fixed SMS backup/restore problem (by PIM Backup)
-- Updated DF's Task Manager / Registry Editor 3.0
-- Increased Glyph cache and Filesystem cache
-- GPRS call timer (on Connection bubble)
-- SD/SDHC support and driver switch-over tool (thanx OllieD for coding support)
-- ArcSoft MMS Composer 4.2 (max. MMS size set to 2MB)
-- TCPMP 0.72
-- BT FTP explorer
-- WkTask 1.1.7.3c (by waku) Task manager
-- Camera Application (Build 25626)
-- TodayAgenda 1.10 today plugin
-- WM5torage 1.78 (USB HDD Emulation)
-- Total Commander 2.5
-- Adobe Reader LE 2.0 (optimized)
-- Performance/overclocking applet (default 624 MHz)
-- DF's PIM Backup 2.8 (for contact, sms/mms etc. backup)
-- SynchroTime (by Grachov) for Internet time sync
-- PocketRAR 3.71 (with .zip/.rar association)
-- File-Dialog changer (for file browser enhancement)
-- Voice notification & ringtones
-- Improved Video renderer (game play should be OK now)
-- NetCF 3.5 and SQLCE 3.5
-- Improved Phone response
-- PIE hi-res support
-- Source filter issue resolved
-- SMS mode set to Threaded (no more back/restore issue)
-- Image size and compression issue of MMS Composer resolved
-- Managed Program applet removed (due to Class not registered error)
-- STK srvice and all the common utilities
-- SMS delivery fix (by Saman)
-- Set default search to Google (desktop) search
-- PIE cache (temp, cockies & history) relocated to the root (\IE Cache) for easy cleaning
-- PIE cache limit set to unlimited and tweaked to get best performance
-- Enhanced wifi driver with WPA workaround
-- Set default dev-id and BT name to "Universal"
-- Disabled incoming beams (to save battery)
-- Disabled today plugins - Date, Appointments & Tasks (replaced by TodayAgenda)
-- Almost all the Today item set to hidden (Unhide from Today settings, if needed)
-- Exe's & Dll's transformed to module (wherever possile)
-- Registry type set to file-based (instead of buffer-based)
-- Some performance tweaks
-- Unlock/Unhiding tool for extROM
-- Should work on G3/G4 both devices
-- 12.5 MB Flashdisk (for G3/G4 both devices)
-- PagePool - 5.6 MB
-- 128 MB RAM Support (may need to set PP => 0)
*Cab on Flashdisk (need to be installed manually, if required):
-- Windows Live
-- Transcriber
[Delete the "Software" folder under flashdisk if you don't need the provided CAB's]
link:http://vidmes.com/xda/Uni/ROMs/Tomal/Ranju_v77_WM61_19900_19900_1_0_2.exe
Bạn thêm thông tin về Rom bằng tiếng Việt kèm hình ảnh vào nhé!!!;;):-?
Ko phải đâu bạn ạ,Nick ranju trên XDA bây giờ chuyển thành Tomal đó,vẫn là bản RomV7.7 cũ đó.
bản này được post hôm 10/06/2008. chắc là bản của Ran rồi. Mod nào move hay delete topic này dùm mình.
Bản ROM là 1. Chỉ do đổi nick từ Ranju thành Tomal thôi! :-??
Locked! Đề nghị sau kiểm tra trước khi giới thiệu nhé! :D;)
