[NEW] WM6.1 (WWE) 19900.1.0.3 Vanilla Build
18S67705
If you are keen on 19900 WM6.1 in Vanilla flavors, please read on. I have just recently micgrated from O2 Xda Flame to Dopod 900 (HTC Universal) and have ever since been looking for a "stock" looking WM6.1 WWE. The readily available Vanillas seems to suffer from "excessive parts removal" to make them light and have suffered from odd behaviours on my aged G4. Since I am not new to Rom Cooking (my previous work can be found at www.xdaflameusers.com), I decided to cook my own WWE and the one I am using now seems to be quite a performer.
This ROM is build on four separate instances:
ThingsOnASpring Kitchen ->
Tomal's 7.7 19900 nk.nbf decoded and extracted ->
OEM Components deconstructed and removal of extras ->
SYS Components revised and HTC Official Kaiser WM6.1 WWE was used as filler to restore missing components ->
Reg Mods all over for performance and stability ->
Additition of minor HTC OEM components & drivers ->
Mo3ulla 2.15 (19588) nk.nbf used as target donor host ->
ThingsOnASpring XIP as the base XIP donor ->
RESULT:
EF 2.22 WWE 19900.1.0.3 Vanilla for G4 Universal (G3 not tested because mine is on G4)
Main attributes:
- Very stock looking
- 7.5MB Pagepool for 64MB Unis and FF Pagepool for 128 Unis (need someone to test this)
- Upon first boot, 40.XXMB of Storage and 26.XXMB of Memory
- Extended ROM already unlocked and ready for use - renamed as 10MB_Store. I have confirmed that this will not clash with SDs for use for storing mail attachments. I use this extra 10MB for programs (installed later)
- Includes native support for both normal SD and SDHCs, SD Settings has been removed in favor of static SDHC components which will read/write both normal SD and SDHC. This has been rigorously tested with my 8GB Sandisk MicroSDHC (with SD adapter) and Kingston 4GB SDHC Class4. Both performs flawlessly tested using Windows Media Player with over 1000 songs on high bitrate MP3s. Using the old SDHC drivers, pause gaps between songs was around 5-6 seconds but now the gap has been reduced to 3-4 seconds
- Includes HTC Network Wizard for easy 3G/GPRS setup
- Grayscale BG for CommManager with all Stock features restored
- Runs perfectly with Radio 1.18
- Exchange Push Mail fully tested on 3G/GRPS - worked flawlessly
- Excellent synergy with SPB Mobile Shell 2.0 and Pocket Plus 4
- .NET CF3.5 installed and confirmed running perfectly
- Games, Transcriber, Schap VOIP, OneNote & Windows Live etc removed
- Registry cleaned of excess traces
- No FDISK/RAMDISK included for stability sake
- Proven stability with 3G/GPRS always on & Activesync in background with Microsoft DirectPush. On top of that with SPB Shell, SPB Finance, Windows Live and Pocket Plus running back to back
Note:
Before you flash, it's a good idea to blank out your Extended ROM to avoid complications. Default HTC Autoinstall from extended rom has been known to cause system freeze on first boot
If you are new to flashing, I highly recommend reading the Universal Wiki - the Wikis has been a great help to me when I first started over 2 weeks ago
Credits:
Of course, this has been possible due to the the hard works of Tomal, Mo3ulla, ThingsOnASpring and many more before them. They deserve all the credits where applicable.
Disclaimer:
There's always risk with cooked roms flashing. Do this at your own discretion and do it only if you are absolutely certain of your intent
Các bạn tải ROM tại đây:
Downloads:
* EF 2.22 19900.1.0.3 64MB Unis (Pagepool 7.5MB)http://www.mediafire.com/?pdzdm4idc99
* EF 2.22 19900.1.0.3 128MB Unis (Pagepool FF)
http://www.mediafire.com/?cntqndxxj4hhttp://www.mediafire.com/?cntqndxxj4h
phải thử mới được, là tinh hoa của những rom nổi tiếng, em bao cáo kết quả của riêng em sau 2 ngày nha
À download cái nào đây 64M hay 128M vậy anh. nó là Ram hả ?
Các bản Rom như thế này khi giới thiệu nên có cả tiếng việt để dễ tham khảo cho những Người ít vốn tiếng Anh. Đồng thời phải có hình minh họa của bản Rom! Các Bạn lưu ý nhé!!!;;):-?
test và báo cáo kết quả đi mấy pác ... ,vậy mod edit lại và bổ sung thêm tiếng việt dùm đi
RESULT:
Không phải đâu bạn, tác giả bảo rằng chưa thử trên G3 vì anh ấy dùng G4
Bạn lên XDA mà xem
Ặc! Rom post ở đây mà Bạn nói sang Forum khác mà xem thì còn nói gì nữa!:)) Bất kể lấy từ nguồn nào, ở đâu về mà giới thiệu trên PV thì cần phải có thông tin để Anh Em được biết!!!:))
Important UPDATE:
I just found out that my Uni is ACTUALLY A G3!. So this Rom will definitely work on all G3. Silly me, I didn't read the Wiki thoroughly enough to differetiate a G3 and G4 LOL!
Trên là nguyên văn của tác giả,ông ý vừa mới biết là Uni của ông ý là G3,vì vậy bản Rom này chắc chắn sẽ chạy tốt trên G3."Thật ngớ ngẩn,vì tôi k đọc hết trên wiki khác nhau giữa G3 và G4" đấy là ý của tác giả, nếu mình dịch sai các bạn edit lại hộ.Thanks
Vậy thì đọc cho vui vậy chứ chẳng dám up, vì chính tác giả của ROM còn không biết máy của ông ấy là G3 hay G4 thì............:-?:-?
Up xong đâu thấy gì, ROM lẩu thập cẩm như trước đây đã làm trên WM6.0
Dòng G3 Đã ai UP ROM này thử chưa
Mình mỗi ngày UP 1 Rom nhung hôm nay buồn ngủ quá. không biết Up rom này chạy ổn định không. Mong các bác chỉ giáo
mình đang dùng G3 nhưng nghe ra không giám up bản này đâu , vì chẳng thấy ai nói về bàn này cả , hơi sợ một chút ..........:p
nếu bạn thích vọc Rom thì cứ up có gì đâu mà sợ nhỉ, nếu k thích thì có thể up lại bản ROm khác mà, hihihi...........
mình thử hôm qua rồi, chán lắm vì mình vốn ưa chuộn các sòt tích hợp của Rạnu/Tomal nên vừa up xong thì vội vàng quay về bản 7.7 của Tomal ngay lập tức. Vào xem thông tin thì thấy Rom date là 2007 nên không thích. về chất lượng phone và PPC thì ae ai tét lâu lâu chút thì cho ý kiến nha. Em chỉ cho nó hiện hửu trên con EXec của em chưa đầy 5 phút nên không có cảm nhận gì!
