Nokia 5800XM FW (RM-356) v21.0.101
Hix sao mình up = NSU ko đc nhỉ. Ai có FW red của bản mới này hok máy mình down trên Navifirm đc 3 files là báo lỗi ko down đủ 7 files đc. Ai giúp dùm nhe
Link down Fw ở trên đó bạn đủ 3 màu luôn.
Mã:
JAF version 1.98.62
Detected PKEY: 9000BCC4
Card life counter: 99.99%
FBUS INTERFACE NOT CONNECTED!!!
USB Cable Driver version: 7.1.17.0
Changing mode...Done!
Detected P-KEY: 9000BCC4
Init usb communication...
Found
Init usb flashing...
Reading flashid...
CMT: 004000EC <=> SAMSUNG (SEC) -> KAT00F00RA
APE: 00000000 <=> Flash -> not detected
Done!
Searching for phone...Detected P-KEY: 9000BCC4
Found
MCU SW version: V ICPR72_09w06.3
02-04-09
RM-356
(c) Nokia
HW version: 1101
PCI version:
RFIC version:
DSP version:
APE SW Core version: V 21.0.101
APE Variant version: V 21.0.101V 21.0.101 21.0.101.210.06
APE Test version: eno_version
Retu version: 16
Tahvo version: 22
APE HW version: 256
APE ADSP SW version: 256
APE BT version: HCI Version 12 (rev. 8192). LMP Version 12 (rev. 0). Manufacturer 12708.
Production serial number: C7B571952
Product code: 0575408
Module code:
Basic production code: 0558954
Flash code:
Order number:
Product specific data:
Long production SN: 0
ATO:
Default SN type:
IMEI plain: 354182025786714
IMEI spare to net: 3A 45 81 02 52 87 76 01
IMEI SV to net: 33 45 81 02 52 87 76 41 F2
LOCK STATUS:
CONFIG KEY: 2440700000000000
Provider: AT&T;U.S.A. (3650)
Key Code count: 0, FBUS Code count: 0
Block 1:
Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN
Block 2:
Block 3:
Block 4:
Block 5:
Block 6:
Block 7:
Loading INI list...
Reading product code...
Product Code: 0575408
Searching for JAF saved location of ini...
Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-356\
Searching for default location of ini...
Checking path: \Products\RM-356\
Scanning ini files...
FILES SET FOR FLASHING:
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-356\RM-356_21.0.101_prd.core.C00
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-356\RM-356_21.0.101_prd.rofs2.V23
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-356\RM-356_21.0.101.240.07.rofs3.fpsx
APE Variant file: C:\Program Files\Nokia\Phoenix\Products\RM-356\RM356_21.0.025_018_xxx_U01.uda.fpsx
Languages in ppm: English,Chinese Simpl,Chinese Trad (Hong Kong)
Done!
Changing flashing settings...
Reading...
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-356\RM-356_21.0.101.270.06.rofs3.fpsx
Backing up CRT...
Reading IMEI...
C:\Program Files\ODEON\JAF\ProgData\354182025786714_CRT_backup_2241266.pm
Done!
Backup CRT OK!
Searching for phone...Found
Reading SW version...ICPR72_09w06.3 21.0.101
Reading battery value...4063 mV
Reading flashid...
Verifing ADL communication... Status byte 7
Rebooting to flash mode...
Waiting for the phone to reboot...
Sending RAW loader...
Using 007.016.022
    Elf2flash 08.37.001
    CMT RAW loader...
Patching RAW boot step1...
Patching RAW boot step2...
Patching RAW boot step3...
Sending RAW Loader...
....................Loader Sent!
Stage 2 starting.................
đây =.=........
kaizvn xem lại quá trình FLASH đã đúng từng bước chưa?
mình ko thấy đoạn CODE:
PRESS POWER ON NOW!
Searching for phone........
trong code bạn đưa lên.
Done!
----> chỉ có bật máy mới có code này.
Nếu đúng trước khi ấn nút nguồn J.A.F sẽ có code:
Mã:
JAF version 1.98.62
Detected PKEY: 9000BD5C
USB Cable Driver version: 7.1.16.0
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
APE Variant file: NONE
Backing up CRT...
Detected P-KEY: 9000BD5C
Failed to backup CRT...
PRESS POWER ON NOW!
PRESS POWER ON NOW!
Mã:
JAF version 1.98.62
Backing up CRT...
PRESS POWER ON NOW!
mình xem các đoạn code khi flash ko có dòng PRESS POWER ON NOW
Đề nghị tắt Phone trc khi Flash và tick vào ô Dead Phone thì sẽ có dòng đó xuất hiện thôi
Cái này fải đề nghị "Đọc kỹ hướng dẫn trước khi sử dụng" hay hơn.
P.s: kaizvn chắc vẫn còn lẫn lộn với FLASH fw v20 :D
vậy flash cái này làm theo phần 1 đúng ko bạn? vì không cần phải chọn file ngôn ngữ
Chính xác bạn àh? nếu bạn down file FW đã can thiệp ngôn ngữ thì cứ FLASH theo phần I. FLASH xong sẽ có Tiếng Việt.
Good luck!
ye đc rồi :))... khổ thân, đá phải cái dây rớt cable ra hỏi sao ko chạy
thanks các bác nhiều lắm.
nhân đây cho hỏi cái orange chỉ là thay đổi giao diện, ko thay đổi cấu hình bên trong phải không? Các bác có bao giờ bị lỗi mở ứng dụng, menu lên đều ko bấm được gì nữa, còn ra menu thì góc phải hiện dialler, bên trái là options ( giống như khi mình thực hiện cuộc gọi ) . Trong taskman thì có 1 cái app là 'telephone', dùng handy taskman kill nó thì máy restart và bình thường lại....
bản 21.0.101 này tự dưng mình bị liên tục :|.... lỗi này thường xuất hiện khi pin còn 1 cục.
*#7370# code 12345 để 4mat :D
nếu can thiệp giao diện Orange bạn sẽ fải cài lại các cấu hình Internet và GPRS
Chắc do máy nó nặng quá nên gay treo máy đó mà bạn bấm Reset *#7370# lại đi cho nó đỡ lỗi. Cái bản Orange thì nó chỉ có cấu hình lại cái web với cái GPRS và có cái thanh bên phải thôi còn ngoài ra giống bản Blue và Red vào cấu hình lại là OK
vì ngày hôm qua *#7370 mà giờ em nó mới bị crash lỗi đấy các bác :|...
các bác chú ý đừng xài pin đến 1 nấc rồi còn gọi nhé. Dễ dính chưởng vụ này lắm.
Còn nữa , chạy 1 phần mềm java ( như ola) và nhận cuộc gọi, dính ngay.
