Nokia E66 nâng cấp FW (RM-343) v500.21.009
jackpham
Giống như E71, E66 cũng được cho nâng cấp lên fw500.21.009
Data package content, corrections or changes :
NOKIA E66 (RM-343, RM-345, RM-420) SOFTWARE VERSION 500.21.009 RELEASED
Introduction
This document summarizes the main differences between Production Release 4.1 version 410.21.010 and Production Release 5.0 version 500.21.009
PURPOSE
This release is a feature upgrade release and also was intended to correct main complaints from Customers and Operators
NEW FUNTIONALITIES:
Following baselines/functionalities have been upgraded.
• Maps 3.03 Lite which has Free Navigation support
• Music Player upgrade
• Quick Office v6.2 which has Office 2007 support
• Ovi Store upgraded to 1.6.0.18 and Download! removed
• Lotus Notes traveler v8.5.1 -> Localization support is present only for 10 languages.
o The list of client languages supported in 8.5.1 are:
• Brazilian Portuguese (PT)
• English (EN)
• French (FR)
• German (DE)
• Italian (IT)
• Japanese (JA)
• Korean (KO)
• Simplified Chinese (CN)
• Spanish (ES)
• Traditional Chinese (TW)
Note: Also note that Back Up & Restore is currently not supported for Lotus Traveler
CHANGES AND IMPROVEMENTS:
• Windows Live removed from the memory card
• Ovi Suite included in Memory card
• CS Helps baseline upgraded to fix localization issues
• Start Up settings baseline upgraded
• Ovi Store Link provided in “Set Up Internet Telephony”
• Download! removed
CALL HANDLING
• Emergency call termination with RSK key corrected
• Corrected Bluetooth link drop when an outgoing call is made in a carkit
CALENDAR/CLOCK
• Fix for Israel written instead of Jerusalem
• Corrected Argentina names issue in World Clock
• Corrected localization issues in world clock
BROWSER
• CMCC Java application download corrected
• Fix provided for accessing a link that has appended space characters
EMAIL
• Fix provided for selecting desired mailbox when multiple mailboxes are configured
cái v500 này hình nhu ko hề hỗ trợ tiếng việt ,down về rồi mà sợ nt ko dc nên ko dám UP T_T đành đợi bảng hỗ trợ tiếng việt vậy T_T
mình thấy nó hỗ trợ cho Ê66 của EU ,Balkan ,arabi ... ko bik up lên cái nào ,bạn chỉ dùm mình với JACKPHAM
Có hỗ trợ TV bạn ơi, yên tâm mà update nhé.
nhưng mà trên navifirm ,ko thấy có bản nào hỗ trợ tiếng việt ,mình định up lên EU mà thấy sợ wá ,nên lên hỏi lại cho rõ đã ,up lên cái nào vậy bạn ,bạn chỉ rõ dùm mình luôn đi
Tình hình là vẫn ko bik úp lên cái nào ,trong navifirm v500.0.21.9 ko có APAC chỉ có EURO 1 2 3 ,BALKAN .... thiệt tình là ko bik up lên cái nào ,mà nghe máy bác trên nói lên v500 lỗi hơn v410 ,sao dám up đây trùi T_T
Ai biết bài hướng dẫn hack phone E66 chi tiết ko chỉ cho em với, em chưa hack phone lần nào cả T_T
Cách nào dễ nhất ấy
THank all
e 66 thì mình hack bằng hellox2.02 thành công. Các bác cứ xin cer key và signed file hellox rồi chạy ok.
các bạn cho mình hỏi.mình sài nokia E66 .vừa up FW nên 500.21.009 xong...khi mình mỏ 1 bức ảnh nên.sao nó ko có phần chỉnh sửa ảnh nhỉ(Edit)..trong khi FW 400 thì vẫn có...chỉ co FW 410 500 là ko co thui..mình đã thử cả 2 FW rồi...có ai bi như mình ko
Lỗi FW 500.0.009 E66 không có mục Edit ảnh
Hiện mình đang dùng FW 500, máy mình cũng không có, có lẽ họ đã bỏ chức năng đó đi
các bạn ai có link dow fw của e66 ver 500 cho mình xin để up offline với thx nhìu
cái này mình có tải rùi k có được nó bắt mình chờ đã rùi sau đó nó báo ero nản hic con ê66 của mình thì đang nằm bất động mong các pro giúp
up lên ver 500 này mình chạy các bản hello 0x mà chỉ chạy tới phần unpacking thì ở đó lun đã thử nhìu cách vẩn hem được hối hận wa đi
