About This Rom:
* Windows Mobile 6.1 (OS 5.2.20273 Build 20273.1.3.3)
* UC Compliant / SDAutoRun
* Schaps CommManager
* Schaps SetupVoIP
* DotFred Task Manager 2.9
* DotFred Soft Keys
* Pocket Torch
* Remote Desktop
* Internet Connection Sharing
* Modem Link
* SRS WowHD
* Sleuth PTT fix
* Storage available - Non RBS Compressed : 70.00mb | Non RBS Normal : 62.25
* Available RAM Memory - 48.93mb, Pagepool 6mb
* NEW Battery.dll as provided by CRCinAU
* MORE! (forget to mention, my hermes using as modem to uploaded rom)
What's New:
V.17
* Fixed top bar loaded when startup
* Fixed Start Menu icon unskinned (Not anymore, i hope insya 4JJI. Tried throught tens & more soft reset for tested)
* Fixed Start Menu dissapeared (Not anymore, i hope inysa 4JJI. Tried throught tens & more soft reset for tested)
* Remove Task Manager from setting tabs to get a single new HTC Task Manager
* No MMS acoount included rom for both 3 version. But for Non RBS will installed ArcSoft MMS V.4.2.81 from Extended_ROM (uninstallable)
* Remove HTC Task Manager from cooked ROM, coz not all people like it
* Cab added for default white service icon on new UC
* Cab added for disable start menu sound on new UC Deleted, will disfunction your sound scheme (Thanks lagoskon for report)
* Just a little app make me confused, flashlight won't run for second and more tried if set to button5
* Apps will installed from Extended_ROM (Non RBS):
- Arcsoft_MMS_4281.cab
- NETCFv35.wm.armv4i.cab
- JAVA_Esmertec_Jbed_20080222.3.1.cab
- PDACorner_HTCHome2.2.cab
- CyberonVoiceCommander-PPC-WWE-705142-DopodPPC.CAB
V.18
* Core and build upgraded
* Added USB to PC from HTC Raphael to fixing activesync and WM5torage problem
* Added Advanced Network also from Raphael
* Remove GPRS Authentication, CSD Line Type because no longer needed
* NetCF3.5, office, and Arcsoft MMS 4.2.8.1 included rom
* Added WM5torage 1.8
* Updated HTC Sim Manager 6.47
* Updated dotfred Task Manager 3.1
* Updated Clear Temp 1.2
* Fixed Flashlight not running when mapped to button 5
* Fixed ActiveSync throught bluetooth
* Fixed multiple marking on message
* Fixed Yahoo!Go setup crashed
* app will install from extended rom:
- PDACorner_Remote_Desktop_Mobile.cab
- PDACorner_HTCHome2.2.fixed.cab
- PDACorner_PocketRAR.cab
- ScreenCapture.CAB
- Windows_Live_10.6.0034.0800(Fixed).cab
Screenshot:
Links V18 Non RBSC/ Non RBSN: Non RBSCompr | Non RBSNormal
* Schaps SetupVoIP
* DotFred Soft Keys
* Pocket Torch
* Remote Desktop
* Modem Link
* SRS WowHD
* Sleuth PTT fix
What's New:
V.17
V.18
- ScreenCapture.CAB
Screenshot:
