PDAVIET - I8000 WM6.5 ROM (21887.5.0.86) - SB02
Sonblack
Super V.I.P
PDAVIET WM6.5 ROM - I8000
CE OS 5.2.21887 Build 21887.5.0.86 PV
Lời cám ơn - Many thanks:
Admin Kawaguchi (so much)
Manager PhamQuang (so much)
SM BatKid (so much)
Mod Tom_codon (so much)
Mod TranMinhMan (so much)
Member NguyenNhatHoa (so much)
Member huyentrangallery (from Samsung, support I8000 for cooking)
Thông tin ROM - ROM Information:
Basic ROM: PDA_I8000NXXIL5_HW_40
Language: Only WWE
Pagepool: 24MB
Version: I8000.21887.IL5.SB02
Hình minh hoạ - Illustrative Images:
Chức năng chính - Main functions:
- Core 5.2.21887 Build 21887.5.0.86
- .NET Compact Framework Version 3.5.9198.00
- Windows Media Player 10.3 Build 21887
- Office Mobile 6.1 (Word Mobile, Excel Mobile, PowerPoint Mobile, OneNote Mobile)
- Các ứng dụng cần có của PPC như: PIM Backup (v2.8), Synchro Time (v0.95), CleanRAM (v1.9), Advanced Configuration Tools (v3.3), ClearTemp (v1.2.3), Total Commander (v2.52 beta 2)... với các version mới nhất
Basic applications for PPC such as
PIM Backup (v2.8), Synchro Time (v0.95), CleanRAM (v1.9), Advanced Configuration Tools (v3.3), ClearTemp (v1.2.3), Total Commander (v2.52 beta 2)... with their newest versions.
- Loại bỏ khá nhiều ứng dụng không cần thiết! :D
ConnectedHome, ApplicationStore, Asphalt4 (Game), Crayon Physics (Game), Dice (Game), Cube, MainMenu, Digital Frame, Video Editor, Face Book, Midomi, Opera, Online Widget, Podcast, QIK, RSS Reader, SharePix, SmartConverter, Smart Reader, Smart Search, Youtube, Adobe Reader, Jblend JAVA, Touch Calendar...
Removed more unnecessary utilities! (see above list)
- Một số file đã được nén nhưng vẫn đảm bảo hiệu quả nhằm tăng dung lượng ROM ở mức có thể.
Some files are compressed but they still operate effectively for increasing ROM capacity with permited level.
Link đã có sẵn - The links are available now
DOWNLOAD I8000 ROM 21887
PDA Part 1
[DOWNLOAD]http://www.4shared.com/file/182983404/824a67ed/PDA_OS21887_I8000NXXIL5_Sonbla.html[/DOWNLOAD]
PDA Part 2
[DOWNLOAD]http://www.4shared.com/file/182991082/33900137/PDA_OS21887_I8000NXXIL5_Sonbla.html[/DOWNLOAD]
[PASS]Sonblack[/PASS]
CSC
[DOWNLOAD]http://www.4shared.com/file/178507493/786c1808/CSC_I8000FAMIJ3.html[/DOWNLOAD]
EBOOT
[DOWNLOAD]http://www.4shared.com/file/178505070/d2e6046b/Eboot_I8000NXXIL5_HW_40.html[/DOWNLOAD]
PHONE
[DOWNLOAD]http://www.4shared.com/file/178507009/4e72e283/Phone_I8000XXIL2.html[/DOWNLOAD]
Cab files for removed utilities
- Smart Reader ----> Download
- Video Editor ----> Download
Chúc vui!
Enjoy it!
Sonblack
hjhj bạn Sơn thiện chiến woa ha :D thankx bạn nhiều, anh em tha hồ có...công ăn việc làm :))
Bạn Sơn thuộc thế hệ U40 đời cuối đó nghe! :p Bản ROM tiếp theo sẽ kích cho CPU chạy ở mức cao nhất luôn! Ka ka! :))
uây zậy hả, gừng càng già càng cay, chí fai chí fai :))
nhưng mờ nếu kick CPU max như vậy bạn cần cảnh báo AE nhé, không ngộ nhỡ em i8 nào yếu tim...lăm ra chít thì tội lém ;))
thế phải gọi bằng chú rồi ;;) cháu vẫn chờ bản ROM HD2 của chú đó nha
Down và test ngay
Bác Sonblack cho e hỏi vụ nhắn tin và nhận tincó vấn đề j kô?
Tôi đã cài 2 bản CE OS 5.2.21884 và CE OS 5.2.21887 nhưng đều báo lỗi như sau: khi khởi động máy báo : MortScript V4.3b5 .mscr and .mortrun extensions registered. Please run any .mscr/.mortrun file or read the manual. (c) Mirko Schenk 2005-2009
Có bác nào up được chưa, mình up mãi không được, em nó cứ treo đơ ra rồi mấy lần sau thì hard reset liên tục, không hiện lên được gì cả
Ặc, cái vụ này nói nhiều rồi! Cứ chọt OK là xong, mỗi lần khởi động là như vậy! Và nó không phải là lỗi!
@All: Tin nhắn hoạt động bình thường!
Bác Sonblack cho hỏi mình không up rom được bản này có phải do file PDA down về bi lỗi gì không, up mấy bản khác vẫn chạy ro ro...
Chắc vậy rồi! Không hề có chuyện up mà bị vậy đâu! Chiều giờ mình up đi up lại hơn chục lần mà! :D
Down lại PDA lần nữa, up up mà em nó không lên gì cả, cứ reset lại liên tục, nếu chọt vô là treo máy. Không có duyên sử dụng sản phẩm của bác Sonblack rùi...
Bệnh của em cũng y choang. nhanh tay choc align lắm thì vào đến phần sync. rồi 1 lúc sau thì auto reset. :-/
Với i900 và i8000 (hiện giờ chỉ đã vọc qua các chú này) thì ở lần đầu tiên khi khởi động sau khi up rom hoàn thành, nó sẽ tự động restart, lần khởi động sau hãy Align.
Các bạn lưu ý điều này! Các dòng khác khởi động lại 1 lần và align là dùng luôn, còn SS thì những 2 lần (1 sau khi up và 1 sau khi xuất hiện thông báo rồi restart)
Chào tất cả, bản ROM này mình đã test từ tối qua đến giờ chưa thấy bị lỗi gì. Mọi thứ rất mượt mà. :)
Cám ơn Sonblack đã cho ra bản Rom hay và tốt.
