rDosti V.11 (WM6.1)-Vanila ROM
ltrhai
Thấy ở 4R xda-developers có bản này có vẻ mới nhưng không có thời gian up thử. Bạn nào có thời gian thử xem thế nào nhé.
This is rDosti V.6 based on the Kitchen of WM 6.1 - THING_V41.build28
Date of Release: June 23, 2008
This is a Vanilla ROM - I have removed everything I could think of to get you 31 to 32MB RAM Freed up & 47MB STORAGE !!
In order to see the below effect, after initial startup be sure to go to Settings - Home Today - and remove extra front screen options (except messages) or remove all Home Today options for even more ram. This is our first ROM that actually gives you 31.4 to 32MB ram for Regular Mode and same for the 128Dpi Mode.
Interestingly in our Version 5, our 192Dpi (normal edition) gave us just 30MB, this version 6.0 gives us 31.9MB (starts at nearly 33MB at boot) !
BE sure to use the attached Ext-Rom Unlock Cab to get 9.xx MB Additional Storage! Also be sure to use Oxios once to recover extra RAM (32MB)
Regular MODE:
Initial Startup Program Memory: 31.44 MB Free
Initial Startup Storage Memory: 37.86 MB Free
Initial Storage from Unlocked Ext. Rom: 9.xx MB Free
VGA 128 Dpi Mode:
Initial Startup Program Memory: 31.90 MB Free
Initial Startup Storage Memory: 37.91 MB Free
However this is a VGA Vanilla ROM (+Good,-Bad/Issue):
+ Added VGA Swictching (tested most of the sizes)
+ WM 6.1
+ No hangs, No Freezes, No battery drainage issues (24 hour usage/standby/usage)
+ Tons of Free Program Memory
+ Supports 16GB SDHC (Tested requires attached .cab)
+ Added Oxios CloseApps
+ Fixed BT-GPS Issues
+ Works on both 64 & 128 Universals
- ROM version & Date will always show "Thingv41 & 2007 date" (Don't really know how to change that - help would be appreciated)
- 8GB MMC Issues (some 8GB cards fail to work, others work fine. The 16GB MMC I tested works great though!)
Important Update:
June 23, 2008
Due to demand of more Vanilla Roms and the fixing of GPS - BT issues, Ive decided to stick around and help release more stable and more fixed up ROMs.
I have released V6 rom which should fix the issue with BT-GPS.
DOWNLOAD:
http://rapidshare.com/files/124485256/rDostiv6.zip
Cập nhật link tải bản rDosti V.7:
Mã:
http://rapidshare.com/files/124742337/rDostiv7.zip
Cập nhật 2-7: rDosti V.11 (WM6.1)-Vanila ROM-+37.80MB Free RAM / "80MB" Storage/disk
WHAT'S NEW IN VERSION 11? (Changelogs)
+ More Free RAM (+/- 38 MB)
+ 3.5 CF (NetFramework)
+ New Camera.exe used
+ RamDisk now supports 32MB storage!
+ Performance Improvement (Drivers oriented)
+ 80MB File Storage (Converts ram into "temporary"storage if required)
+ Support for both 64/128 Uni, Both G3 & G4 devices
+ Added Windows Mobile Office Cab (Ext-rom, Optional)
+ SDHC Support
+ Implementation of Memory Cleaners (Oxios and TaskMgr)
+ Added New Ringtones as well (Ext-rom, Optional)
- Issues with Camera (Burst Mode Exist).
Link tải:
Mã:
http://rapidshare.com/files/126486478/rDosti_v11.zip
+ Added VGA Swictching (tested most of the sizes) , cái này là ý gì vậy bro ? có phải là realVGA không bro ?
Rom này up cách đây 2 ngày, chạy chậm, giựt giựt , tụt ram, có người gọi đến la SR liền.Nói chung ko ổn định bằng Rom PV hay Raju 7.6..hehehe
Bản này cũng rất tốt,ổn định nhưng ko có FD
vậy là sao trời, 1 ng thì khen rất tốt, còn 1 ng thì...ặc ặc....cũng may mình k ham hố với những bản Rom lạ nì, heheheh.....=))
xin lỗi mình nhầm với bản V5 của tác giả này,V6 bị khá nhiều lỗi,đặc biệt là lỗi SR nên tác giả vừa ra bản V7 để Fix nhưng chưa test được.
ai thích vọc thì cứ up lên xài thử, bản này có chức năng VGA Switch hay sao đó, chỉnh VGA được 3 mode : 96, 128 ,196 ( không nhớ rõ lắm),giống như chỉnh độ phân giải trên PC...hehhe..vì chỉ up bản này được 1 ngày mà thấy bản này chậm chậm sao á nên up lại bản Rạnu 7.6
Ai tải được từ Rapi từ up lên host khác share cho mình vfa những ai không tải được với... nghe quảng cáo bản ROM này nhiều quá mà chưa tải xuống được để up thử
Cám ơn mọi người rất nhiều !!! =D>
ai test rùi , cho nhận xét dùm đi ... thấy + Added VGA Swictching (tested most of the sizes), khôg biết là gì , bạn nào tét rồi , cho mình biết nó là gì dùm đi ,,,, bản này có hao pin không ? co hay SR không ? bro nào test rồi , cho mình biết dùm hé , chưa dám up thử , sợ mất công phải up lại bản cũ quá , thấy khả quan mớ dám up thử nè
Added VGA Swictching là giống như chỉnh độ resolution trên PC thôi bạn ah...trên PC là 800x600 ,1024x600,1280x800 , vay thoi ....máy mình G4 , theo bản thân thì mình cảm thấy bản rom này chạy ko mượt lắm, chưa cài phần mềm nào mà chạy giựt rồi,co người gọi đến là SR ah.cho nên quay về Ranju 7.6 là ổn nhất..
Mình đã từng up bản 5 của bác rdosti này rồi. ROM này là ROM clean nhất trong các ROM 6.1, do đó khi mới HR thì RAM cũng còn trâu nhất trong các bản ROM (tầm >31Mb). Tuy nhiên clean quá đôi khi lại gây khó chịu cho nhiều người, tuỳ theo quan niệm từng người. Mình thì thích ROM clean nên thấy bản này cũng được, tuy nhiên thỉnh thoảng dùng vẫn bị SR. Bản này cũng là build dựa trên 1 bản ROM đã có từ lâu rồi, nhưng cũng có định hướng riêng của tác giả. Mình cảm giác mấy bản ROM của rdosti này dùng rất ít hao pin. Nói chung cũng nên up thử.
trùi trong 1 ngày mà update đến 2 lần, sao tác giả siêng vậy nhỉ hay bản rom có vấn đề nghiêm trọng đây ta ????????????
log nói:
WHAT'S NEW IN VERSION 8.5? (Changelogs)
+ Camera Fixed
+ CF 3.5 (Compact/Net Framework)
+ No need to use a cab to open Extended-Rom. It will be open by default
+ Removal of Ring Tones. Select one from Ext-Rom or Through your memorycard
+ SD Card (All Types Supported). You dont need to add a cab. Everythings done and ready.
+ Implementation of Oxios and TaskManager Both
+ Added Misscall/sms Tones, and new ringtones as well (Ext-rom, Optional)
+ Battery Meter (Colour Line) on top of Today Screen
DOWNLOADS:
rDosti V8.5 (June 26,2008 | 58069 KB)
Mình đang tò mò ở 2 cái bôi đỏ. Chưa download được từ rapid nên đành chịu.
Sao thấy Rom mới mà mọi người nhận xét ghê quá nên mình không dám Up thử,chắc phải đợi bản Fix thì may ra..:D
Tối nay về làm thử cái bản mới nhất 26/06 xem sao rồi sẽ báo kết quả, hi vọng là không như mấy lần trước cứ up các rom khác nhau lên cho đã rồi vội vàng quay trở lại bản RAN 7.7 trong vòng chưa đầy 5 phút.
