[ROM] Android Revolution HD 2.0.15 by Mike 1986[24-02-2011]
heobanhki
Update Android Revolution HD 3.0 03-03-2011
link 4rom :
http://forum.xda-developers.com/showthread.php?t=840040
- New ->> Re-based on official HTC RUU 1.84.61.2
* De-odexed
* De-branded
* Fully optimized
* SMS notification bug fixed
* All tweaks / changes incorporated from 1.72.405.3 based ROM
- New Apache14's kernel 1.3.5
* Patched up to .30
* BMA150 rotation driver fixed
- Added zipalign at boot (Thanks to LeeDrOiD for the idea and Wes Garner for the script)
- Restored original libsqlite.so
* This can cause Quadrant score drop a little but wont have any negative side effect on overall system performance.
This should also solve issues with backup tools
- Sound and GPS fix for Telus / Inspire 4G users included (Thanks to attn1 & Apache14)
- DroidDreamKiller security file included
- No full wipe needed but recommended because of new base!
- Don't flash any mods/themes until they are not ready for AR HD 3.x.x
Không cần full wipe nhưng theo đề nghị của tác giả thì nên full wipe vì là base mới
link :
http://www.wbakkercomputers.nl/Android_Revolution_HD-4G_3.0.zip
http://xda.ckgaming.co.uk/db_mirror/Android_Revolution_HD-4G_3.0.zip
http://odin.ysotop.net/Android_Revolution_HD-4G_3.0.zip
http://www.megaupload.com/?d=QCYV0DZ6
http://up.4share.vn/f/7e4f4a474c464a4c/Android_Revolution_HD-4G_3.0_2.zip.file update link phamthaibinh2010
Android Revolution HD 2.1 [01.03.2011]
- This version comes as full ROM to flash over any previous version or patch to flash over .15 or .16
- New kernel 1.3.4 by Apache14
* Motion sensor issue fixed
* Cable headset/BT headset mic fixed
* Speed improvements
- Compatibility & stability improvements
- Previous performance patch included
- No full wipe needed if you have .15 or .16 already!
- You need to have .15 or .16 installed in order to flash 2.1 patch!
- All mods/extras are compatible with AR HD 2.0.3 - 2.1
link :
http://www.wbakkercomputers.nl/Android_Revolution_HD-4G_2.1.zip
mirror :
http://www.multiupload.com/4QAMH9387F
http://up.4share.vn/f/6a5b5e525e525e53/Android_Revolution_HD-4G_2.1.zip.file link của mem phamthaibinh2010
Phiên bản cũ hơn :
1./ Android Revolution HD 2.0.16 Performance Patch [27.02.2011]
link download :
http://www.mediafire.com/?8vkm212qlc1xp7m
2./ Android Revolution HD 2.0.15
- New Apache14's kernel 1.3.1
* Fixed default speed after boot
* Cleaned up kernel messages
* Cleaned up CPU voltage table
- Fixed typo in gps.conf file
- Fixed boot loops
- Zipaligned with tool from newest Android 3.0 SDK
- Gmail updated to latest 2.3.4
- Sound fix for Inspire 4G users
link down :
http://dl.dropbox.com/u/15538649/Android_Revolution_HD-4G_2.0.15.zip
mirror
http://files.fnutt.net/revolution/Android_Revolution_HD-4G_2.0.15.zip
http://colo.glade.nl/desirehd/Android_Revolution_HD-4G_2.0.15.zip
http://www.fileserve.com/file/MB3Mp88
http://www.megaupload.com/?d=WO45U0X0
* note : update trực tiếp không cần wipe nếu máy đang chạy các Revolution HD.
3./ Android Revolution HD 2.0.14 HD & 4G Edition [22.02.2011]
- This time presenting you the first custom ROM with first custom kernel based on official HTC source for 1.72/75 base
- New Apache14's kernel 1.3.0
* Based on the newest HTC official kernel source
* Proximity driver fix
* All 1.72 libs works fine now
* Voltage tweaked
* Compatible with Desire HD and Inspire 4G
- Fixes to sysrw and sysro binaries
link download :
http://hotfile.com/dl/106854144/f5ad2eb/Android_Revolution_HD-4G_2.0.14.zip.html
- Sử dụng khá mượt, ít hao pin
ace test thử ;;)
Theme cho Revolution_HD :
link theme
http://www1281.megaupload.com/files/87a1c27960086e089be3a767061d4a7f/RevolutionDHD210211.zip
1./ up rom
2./ khởi động máy hoàn chỉnh
3./ up theme
4./ khởi động lại máy
no-Sense script for all versions of Android Revolution HD
link :
http://www.mediafire.com/?o842axhrotaqc44
1./ up rom
3./ up vr no sense
* Nguồn : Mike 1986 xda-developers.com
CÁC PHƯƠNG PHÁP UP ROM CHO DESIRE HD
http://www.pdaviet.net/showthread.php?114658-HƯỚNG-DẪN-CHI-TIẾT-CÁC-PHƯƠNG-PHÁP-UP-ROM-CHO-DESIRE-HD
HƯỚNG DẪN CHI TIẾT ROOT, S-OFF , RECOVERY CHO HTC DESIRE HD
http://www.pdaviet.net/showthread.p...P-S-OFF-VÀ-CÀI-ĐẶT-RECOVERY-CHO-HTC-DESIRE-HD
HƯỚNG DẪN CHI TIẾT UP RADIO CHO DESIRE HD
http://www.pdaviet.net/showthread.php?113590-RADIO-amp-HƯỚNG-DẪN-CHI-TIẾT-UP-RADIO-CHO-DESIRE-HD
nhìn chung ko hiểu sao revoluton cua mike lại nhiều người dùng đến vậy chú riêng phần ổn định thi leedroid ổn hơn nhiều, bản revolution đang chơi game hoặc xem youtube mà ai call đến là tịt ngòi,chụi khó chờ 1 2 phút mới xem hoặc chơi game tiếp được
tùy nhận xét từng người bạn àh.
Riêng mình các bản của mike mình thấy vừa ý nhất. dựa trên tốc độ, pin, ....không quá màu mè...... cái wan trọng là pin rất tốt.
trường hợp bạn nói mình chưa bao giời gặp cả
2.0.15 có vẻ tốn pin hơn so với 2.0.12 thì phải :(
mình cũng thấy như vậy, kg phải cái gì mới cũng chắc chắn là tốt hơn cái cũ :))
Hiện tại mình vẩn đang sài 2.0.11 rất ổn
Mình vừa sạc đầy, full wipe và flash lại .15 :D tình hình có vẻ khả quan hơn. để theo dõi thêm đã :D
mình mở wifi dowload data game từ 9h00 đến 11h00, chơi fifa 30phút, nhắn khoảng 10 sms, gọi khoảng 5 phút, tuy nhiên bỏ túi đến 19h00 thì chỉ còn 27%.
đang full wipe rồi test lại xem sao. hy vọng pin tốt.
Đã up Revolution HD 2.0.15 .Nhận xét ban đầu máy chạy khá nhanh và mượt.Tuy nhiên sóng có vẻ hơi kém, e dùng Viettel được có 2 vạch không biết có phải do khu vực nhà e thế không.Chờ tét thêm xem Pin thế nào.Bác nào đã test bản này rồi cho e hỏi nên dùng bản Radio nào.
Mới up patch .16, radio 12.35d.60.140f...... pin rất tốt, sóng sánh ngon lành bác ạh:D
mình đang sài 12.39.60.19_26.06.04.06_M thấy khá tốt
Da co link, cac ban sang xda down nhe. May bua nay rot mang nen kg down duoc.
Ps comment bang dt nen kg co dau.
3.0 sử dụng build mới nên có vẻ vẫn còn lỗi :D có bác nào dùng thử chưa? Hôm qua mình đi ngoài đường test GPS mãi ko bắt được sóng. Hôm nay chuyển vể 2.1 rồi, đợi bản tiếp theo vậy:D
Mình dùng 3.0 thấy có 1 số vấn đề:
Nhược điểm:
- pin ăn nhiều hơn bản 2.0.15.
- themes chưa mod kịp theo RUU 1.84 nên phải dùng themes gốc.
- thi thoảng máy chậm, giật. khởi động lại thì lại tốt.
Ưu điểm:
- Loa ngoài nghe rất to.
- Máy chạy mượt, nhanh.
- Sóng GSM, Wifi khỏe
- GPS nhanh.
- Cài thêm Mod: % STOCK Battery, PureBlack skin, PowerNotificationMOD vào là thoải mái dùng.
- Đang chờ themes Rotating Theme Animation 5.0 thằng này làm themes đẹp, có nhiều icons nhìn hay, mình dùng quen của nó thấy hợp.
