pnt163
[ROM] Android Revolution HD™ 6.1.1 | High Quality & Performance | Official Sense 3.0
Android 2.3.5 (Gingerbread) - official HTC RUU 3.06.405.1 with official HTC Sense 3.0 for HTC Desire HD
This is improved version of stock ROM - no visual changes!
New kernel: 2.6.35.14 (under-volted & tweaked). Details below:
CPU up to 1.61 GHz (1.15 GHz by default) - controlled automatically by built it O/C Daemon. How to use O/C Daemon?
If you want to control CPU manually, you would need SetCPU from here: SetCPU
In SetCPU remember to check "Set on Boot", but using O/C Daemon gives much better performance and battery life
Many CPU governors (SmartAss, Ondemand, Performance, Conservative, UserSpace)
GPU+ patch (Improved 2D & 3D Graphics performance - Thanks to -snq)
V(R) I/O as default scheduler
SLQB Memory Management
CIFS, TUN & UTF8 support
LZMA compression
Wi-Fi module improved drivers
Possibility to change VDD levels dynamically - check question 21 in FAQ
Code cleaned up with custom voltages, tweaks & many more!
You can find custom kernels here
ROOT (SU + SuperUser Permissions - Thanks to ChainsDD)
Fully optimized and tweaked
Unsecured boot.img
Full official HTC Sense 3.0 interface
Newest BusyBox
RAM optimizations
Speed optimizations
2-way recording patch
Enabled GPU UI rendering
SD Card speed tweak
Battery auto-calibration
Data partition special speed tweak
Very fast, clean & stable!
Battery auto-calibration script (Thanks to seo)
Bloatware applications removed (Amazon MP3, SoundHound, etc.)
All system applications updated to latest available
Improved camera performance
Multilanguage (WWE)
Advanced Power Menu and CRT Animation as extra add-ons
Full Arabic and Hebrew languages support! (see the second post)
Zipaligned (Improved RAM management)
Zipalign on boot (for user applications on data partition)
Fully de-odexed
init.d scripts (BusyBox run-parts) support
sysro/sysrw commands support
Excellent battery life!
Device partitions mounted & formatted as fast EXT4 file system instead of EXT3
SD card EXT4 partition support
A lot of themes made for my ROM & plenty of extras like Advanced Power Menu or CRT in the second post
ROM is ad-free. It means that you don't need any extra software to get rid of advertisements
You can replace HTC boot animation with any custom boot animation.
Support almost 24h a day
...and many more!
Xem Thêm và Download
Mod's for android revolution hd 6.1.x
Có bạn nào đã sử dụng ROM này thì cho xin ý kiến với nhé ;![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Proudly presenting you the most popular ROM for HTC Desire HD...
About Android Revolution HD![desirehd1.png](http://xda.androidrevolution.nl/db_mirror/Grafika/HTC%20Desire%20HD/desirehd1.png)
LZMA compression
Unsecured boot.img
Newest BusyBox
RAM optimizations
Speed optimizations
SD Card speed tweak
Multilanguage (WWE)
Fully de-odexed
...and many more!
