ROM aospX ICS 4.0.4 for DHD/Inspire 4G
htdu87
[ROM][OCT 1][ICS 4.0.4] aospX 1.0.0-MR1 | IMM76L | Source | WIP
aospX is a pure AOSP build, meaning it is NOT CM or built from CM source, so please do NOT ask for CM features. However, it does use device/hardware files for ACE from CM.. so any device specific problems that is in CM will most likely be in aospX (ie. bluetooth, wifi, gps..etc). aospX includes various fixes from AOKP (TeamKang), CodeAurora, Linaro, Oxygen-Rom and some commits from CM.
MR1:
rootdir: updated hosts file
dalvik: Various updates from AOSP master
Bionic/libm: Prefer branches and VFP ABI
Bionic/libm: Pow optimizations and bug fixes
Bionic/libm: Add assembly versions of sin/cos
Contacts: Fixed recent Android Dialer exploit
Contacts: Fix Phone/Dialer background gradient
Fixed Caller name not sticking for missed calls
Settings: Fix crash when setting the radio band
Settings: Fix memory leak in ApnSettings activity
qcom/mm-video: Merged latest from CodeAurora
Fix SkBitmap::fPixels not being locked correctly
libstagefright: Fix for crash in specific AVI clip
libstagefright: Avoid read in non-EXECUTING state
skia: Various updates from AOSP master and CAF
msm7k: Fix dlsym call to get OMX_Deinit reference
Fixed memory leak caused by CSSRuleList wrapper
external/bluetooth/bluez: Updates from AOSP master
libdex, libskia, libsqlite: Build using -O3 optimizations
ace: Use prebuilt gps.spade from 2.50.405.2 (Issue 70)
Revert "Avoid multiple dns lookups for the same query"
MPEG2TS: graceful exit if PID changes in b\w playback
kernel/msm7x30: Updated kgsl driver to latest from CAF
kernel: Update G-sensor drivers from vivo-ics-crc-3.0.16
kernel/msm7x30: build tun and cifs as modules (Issue 56)
kernel/msm7x30: Increased handset volume for spade/glacier
Toolchain: Updated mpfr, mpc, binutils and gdb from Linaro
Revert NEON optimized scanline_t32cb16 and t32cb16blend
Browser, chromium, Mms, Webkit: Updates from AOSP master
RULE #1: Do NOT ask for ETAs!
RULE #2: This is NOT CM, do NOT ask for CM features!
Features:
- Based on AOSP 4.0.4
- Busybox and Init.d support
- Updated TalonACE kernel for ICS (included)
- Compiled with Linaro Android 4.6.3
- Custom Quick Toggles Menu (tap Settings icon in notification pulldown)
- Patches from AOKP, CM, CodeAurora, Linaro, 0xlab..plus more
- Working Bluetooth, GPS, WIFI/Tethering, Camera/Video
AR = Alpha Release
BR = Beta Release
MR = Milestone Release
RC = Release Canidate
Working:
Camera
Sound
Phone works 2G/3G
Touch
SD Card
Wifi
Sensors
Headphones
Bluetooth
EGL
Market
Gallery
3D Acceleration
Video Playback
GPS
Tethering
Facebook contact sync
more..
News:
Misc
2012-08-16 - OTA updates now handled via OTA Updater in Settings
2012-07-15 - Development blueprints now hosted on Launchpad.net
2012-06-03 - Building "snapshot" releases now available on GitHub
Releases
2012-08-23 - BR7 Release, (Changelog), Fixed Issue 65 , Fixed Issue 103 , Working 720p, HSPA+ fixes
2012-08-16 - BR6 Release, (Changelog), Fixed Issue 82 , Updated kgsl/genlock from CAF, AOSP updates
2012-08-06 - BR5 Release, (Changelog), Fixed touchscreen driver, AOSP & CAF udpates, Fixes from JB
2012-07-13 - BR4 Release, (Changelog), Updates from AOSP & CAF, Fixed Issue 36, Fixed Issue 81
2012-07-03 - BR3 Release, (Changelog), Updates from CAF, 480p Recording fixed, AOSP/JB Webkit
2012-06-03 - BR2 Release, (Changelog), Updates from CodeAurora, Fixed Issue #60 , Updated kernel
2012-05-24 - BR1 Release, (Changelog), Tons of CAF updates, Merged latest from AOSP, zlib 1.2.7.1
2012-05-03 - AR31 Release, (Changelog), Updates from CAF, Updated Adreno libs, Updated kernel
2012-04-20 - AR30 Release, (Changelog), Updates from CAF, Updates from AOSP, Fixed Issue #50
2012-04-18 - AR29 Release, (Changelog), Updated kernel, Tons of fixes from CAF, update GAPPS
2012-04-04 - AR28 Release, (Changelog), Updated kernel, Fixed Issue #14 , Fixed Issue #43
2012-04-03 - AR27 Release, (Changelog), Merged AOSP 4.0.4, CAF updates, Updated kernel
2012-03-23 - AR26 Release, (Changelog), More updates from CAF, ARM/NEON optimizations, QCOM GPU libs
2012-03-16 - AR25 Release, (Changelog), Tons of updates from CAF, Update Camera HAL
2012-03-06 - AR24 Release, (Changelog), Tons of updates from CAF, Added T9 Dialer
2012-02-29 - AR23 Release, (Changelog), Fixed HD Video Playback, Streaming Video..etc
2012-02-24 - AR22 Release, (Changelog), Fixed Market issues, Merged latest from AOSP
2012-02-21 - AR21 Release, (Changelog), Fix auto rotate issue, Fixed Issue #26
2012-02-21 - AR20 Release, (Changelog), Updated Launcher, Mms, Settings, More compiler fixes
2012-02-16 - AR19 Release, (Changelog), Updated Launcher, Display updates from CAF, plus more
2012-02-11 - AR18 Release, (Changelog), Updated Launcher, Skia update, Updated GAPPS
2012-02-04 - AR17 Release, (Changelog), Display updates from CAF, Updated GAPPS, plus more
2012-01-29 - AR16 Release, (Changelog), Fixed Mic issues, Camera app FCing, possible BT fix
2012-01-26 - AR15 Release, (Changelog), Stock battery w/ percentage, updated libs..plus more
Source:
http://github.com/aospX
http://github.com/existz
Credits:
AOSP
AOKP (TeamKang)
beforedenied (preview image above)
CodeAurora
Codenamedroid
CyanogenMod
Kali-
0xlab
..and everyone involved in porting to DHD/Inspire 4G
Link:
http://code.google.com/p/aospx/
http://forum.xda-developers.com/showthread.php?t=1460820
Bác cho tí nhận xét đi, so với ice cold sandwwich 8.x thì thế nào?
camera chạy tốt ở tất cả các chế độ không?
cho nhận xét đi bác..tính up mà k bít thế nào,.,chạy ổn chứ hả,có lổi lầm j k,pin có tốt k bac,?????
ROM chạy tốt, mượt, nhanh. Ít tốn pin, camera video 720. Nói chung là GOOD
Đang chuẩn bị chạy ice cold sandwwich 8.6.1 nên chưa so sánh được :D
Sau một đêm sử dụng tôi thấy ice cold sandwwich 8.6.1 mượt hơn, nhiều tùy chỉnh hơn. Nhưng ko nhận file APK qua blutooth được, báo là ko hỗ trợ.
vậy là bản trên hoàng chỉnh hết rồi hả bác,có lổi lầm gì k?..tối nay se thử up xem sao.thanks bác nhìu
Ờ, nói chung là OK hết, wifi (thu - phát), buletooth, GPS, 3G, ....có điều chụp hình quay camera không ngon = sense của HTC
tat ca ok nhung camera mo k net em vua up k thay bat dc wifi
Chú ý viết bài bằng Tiếng Việt có dấu nhé. Cảm ơn.
Mình dã up roi và dang test.tat CA chuc Nan deu tot.
Chú ý viết bài bằng Tiếng Việt có dấu nhé bạn. Cảm ơn.
nhưng sao của mình k bat dc wifi la sao vậy
được hết mà bạn,wifi 3g,gps,mình đã tes hết rồi,máy chạy khá là mượt,k nóng,,pin thì mình đang tes,,thấy cũng chưa được tốt lắm..
đang nghiên cứu up rom no sense , đang thử MIUI thấy hay hay, dùng bản Sense khóa màn hình và dial hay bị gọi nhỡ, để túi quần và rút dt ra là từ chối cuộc gọi tức vãi .
