[ROM]Blackout ICS Incredible v3.0.0 FULLY WORKING!!! [4.0.4][Sense 3.6]--Rất Good
hacbaoklhh
8/9 [ROM]Blackout ICS Incredible v3.1.0 FULLY WORKING!!! [4.0.4][Sense 3.6]--Update..
Update v3.2.0 - 12/11/2012
Link Download v3.2.0
MD5 Sum: d7b13b44b843c36699c6a52790b8d76f
Team Blackout Mods!!
Get them HERE!
attachment.php
attachment.php
attachment.php
v3.2
~*~FUll WIPE ADVISED~*~
Rebased to 4.14.405.2
Added Mods to POST #4
Fixed Sound on Devices
Fixed Auto-Brightness
Added Incredible S Support
Added Desire Z Support
Added Desire S Support
Fixed Colors on HTC IME
Zipaligned with Latest
Fixed OC Governor on First Boot
Fixed Button Backlight
Improved Performance and Battery Life
Update v3.1.1 - 25/10/2012​
Link Download v3.1.1
MD5 Sum: ddf7b31e90d91773d08b17a97b087254
v3.1.1
Um...v3.1 but better!
Full Wipe Recommended, maybe required
Better touch Response
Fixed aroma no wipe issue
Update v3.1.0 - 8/9/2012
Link Download v3.1.0
v3.1
~*~FUll WIPE REQUIRED~*~
Back to stock look. Skin will be reworked
New kernel Blackout BeastMode v1.5
Added new device (HTC MyTouch 4G)
Removed andrev_oc and related files due to causing lag issues.
Removed duplicate entries from build.prop
Correct Device Branding
Added Bliss Mod to Tweaks
Even more Tweaks added!
Included Beats audio components for Desire HD
Updated frameworks to include new APN's
Added Battery Percent
Fixed FM Radio (Fully Functional)
Fixed Weather Sounds FC
Fixed APN's for Virgin Mobile
Fixed issue with camera and flash
Fixed issue with video recording locking up and rebooting
Fixed SMS 160 char issues
Fixed MMS send recieve issues
Fixed Data signal drop while recieving MMS
Fixed BT Hogging CPU after shutdown
Mọi người dùng thử bản ROM này nhé. Mình đã Test 1 ngày rất mượt.Ko lỗi lầm gì.
GPS nhanh ngồi trong nhà khoảng 3s là bắt đc GPS.
Sóng mạng (Viettel) ổn định. Ko như bản ROM Virtuous_infinity-v1.33.0-alpha3 thi thoảng lại mất sóng khoảng 4s rồi lại có lại :D
Còn nhiều nữa mọi người tự test nha
Lỗi duy nhất là thi thoảng có từ Tiếng Việt nó viết dấu chưa chuẩn lắm. :D
Ram free khoảng 300Mb( Lúc mới up ROM xong).
Android: 4.0.4
Sense: 3.6
[video=youtube_share;2bYd0KQ7xRQ]http://youtu.be/2bYd0KQ7xRQ[/video]
- Android Version: 4.0.4 (IceCream Sandwich)
- Based on: Incredible S 4.10.405.1
- Sense Version: 3.6
- Supported Devices: DHD, Inspire, Telus DHD, and more to come...
Not Working:
You Tell Us
v3.0
Rebase to Incredible S 4.10.405.1 (Android 4.0.4)
Camera fixed AND Recording 480p and 720P WITH audio
Camera - Removed Stereo Recording and Front Facing Cam/Mirror App
Blackout BeastMode Kernel V1.0
New OC Values
Re-Wrote Tweaks App
Few new tweaks add (more to be added ota style ;))
Exclusive Blackout Skin v1.0 with Sense 4.0 Style Clock Widget (default)
And New Team Member...be gentle with him...
http://tinyurl.com/9rltovs
MD5 Sum: 0979ec22a754b816c10ca51304ad6bad
Kernel Source
BeastMode!!!
Older Release
http://d-h.st/Ofo
HUGE thank you to j4n87 and m0narx for the help and Leedroid Tweaks that our app is based off of (Mikenif deserves a few shots for the work he put into the app )
VU For Kernel source (This rom would not be complete w/out them)
Scott Crosler for all the help and input he's provided AND just being a good friend
Newtoroot for various tips and tricks
LorD ClockaN for previous use of kernel
Shaky156 for bringing the Team together
Nguồn xda.​
Mình up thêm 1 số ảnh thực tế máy mình đang test nhé.
Máy đã cài đầy đủ apps và đang chạy tất cả các apps chưa Kill.
Ai bị lỗi Font chữ thì trước khi cài Download file này về rồi giải nén. Sau đó chép vào file ROM *.zip rồi cài như bình thường nhé.
Download
Ai test cùng cho ý kiến nhé :D.
Update cách fix font TV:
cach Fix day ne: -dùng winrar mở file rom ko bị lỗi(mình lấy từ rom weekly7) vào system trích xuất file fonts ra chỗ nào dễ nhớ.
-dùng winrar mở file rom Blackout Incredible vào system xóa file fonts,sau đó add file fonts vừa trích ra ở trên,xong.
-copy file rom vừa sửa vào thẻ nhớ và flash như bt
mình cũng đang dùng bản Rom này, lúc mới cài vào chạy thấy hơi chậm, fai dùng SetCPU set max lên 1200 thì chạy thấy ok.
Pin có vẻ hơi tốn khoảng 1 ngày là hết pin,
còn lại mọi thứ xài ok
lúc bạn cài ROM nó có các tùy chỉnh về CPU mà. Nói chung mình thấy bản này ổn định, sense 3.6 rất tiện mà ko nặng như 4.0
bạn hacbaoklhh cho minh xin file fix tiếng việt đó đi.Cảm ơn bạn rất nhiều!
Làm sao mà ngon bằng bản Android Revolution 6.3.3 với các Tweak đc cơ chứ
Chuyển qua ARHD 6.3.3 đi em....
mỗi bản ROM có 1 cái hay riêng mà. :D.
Bản Revolution 6.3.3 thì nhẹ nhất rồi nhưng Sense 3.5 nên ko tạo đc Group cho các Apps vào cùng thư mục. :D
Mod xem laị dùm cái sao ảnh cứ bị nhảy xuống. Lúc xem thử thì 2 ảnh đặt cạnh nhau đc sửa xong toàn bị nhảy xuống. Mất mỹ quan quá :D
Mấy cái ảnh này bạn chụp to quá nên nó thế đấy. Không sao cả. Quan trọng Rom dùng tốt là đc rồi :)
1 số phần nhìn nó viết TV hơi xấu. Nó đánh dấu ở cuối từ nên nhìn xấu quá. Ví dụ như từ Thông Ba'o. Đúng là bọn Tây ko hiểu tiếng Ta :))
máy mình đã s off cài bảm rom nào cung ok nhưng riênh bản rom ni cài xong thấy 1 màu đen xì .không khởi động lên đc.ai biết cách gúp mình với.dã thử 3/4 lần vẫn bị.
oh có thể do bạn up đi up lại file boot.img nhiều lần nên bị như vậy. Mình cũng từng 1 lần bị. Bạn vào HBOOT rồi reboot bootloader rồi up lại là OK :D
Chúc thành công.
