[ROM]COREDROID SENSATION XE & 4G v3.0 [SENSE 3.5]
LinhKu
Có lẽ rom coredoid không cần phải giới thiệu nhiều,Cuối Cùng CoreDroid đã hoàn thành bản rom sense 3.5
dow về và thưởng thức nào
Nguồn:
http://forum.xda-developers.com/showthread.php?t=1195902
Here is what to expect from these builds:
Android 2.3.5 (Gingerbread) HTC Sense 3.5
Multi-language Including Arabic
95% Coredroid Skinned (Due too M10 Limitations)
COREDROID SKIN APK (Most Sense 3.5 widgets parts are skinned. Make sure to apply skin from personalize)
Performance optimizations
Rooted, unsecure boot.img
Bash command & nano editor
EXT 4 optimizations
Ram optimizations
Keep your home launcher in memory
Improved overall UI smoothness
All System apks ZipAling & Optimized
All User Apps Zipalign at Boot
init.d scripts support
Excellent battery life
Improved auto-brightness values
Blocked Adds (AddFree App provided for Updates)
Fully Deodexed
Enabled GPU UI rendering
Improved Andreno configuration
SD Card speed tweak
CIFS support
Wi-Fi module improved drivers
Screenshot by pressing Power and Home
Advanced Power Menu
Increased Audio
Beats Enabled
All system & 3rd party apps updated to latest
Keyboard Animation
Amaze Camera
Camera performance Improved
Sony Bravia Engine (HQ Image and Movie improvements)
Extended Settings in Browser
Enable/disable Sense unlock animation (carousel effect)
4 column app drawer or 5 column app drawer (configured in Tweaks)
CUSTOM personalize button on Sense 3 launcher! (you can choose your own app! Defaults to browser)
Disable/enable paginated app drawer
Custom Quick settings (Hide any extended settings you don't want!)
Ability to hide recent apps in pulldown (hidden by default)
Clock options (colors/am pm settings/hide)
Signal options (color/dbm text/hide)
Battery options (text/automatically colored text based on battery level/hide icon)
Choose between showing H or 4G in the statusbar
Center clock!
Quick-quick settings option (automatically turn to settings when no notifications to clear)
And much more...
Happy Flashin!!!
CoreDroid Team-
Úp rom: thông qua recovery và yêu cầu Full wipe
link dow : http://hotfile.com/dl/140115059/fb0b829/CoreDroid_Sensation_V3_Sense3.5_RV.zip.html
-nếu bạn nào dow link hotfile chậm thì thông qua trang này http://www.premiumleecher.com/index.php rồi dán link hotfire vào phần Link to Transload: và Transload File đợi nó load 1 tý thì sẽ dow nhanh được:p
-ver 3.1
Change Log:
Updated 3rd party apps
Added 4Ext Touch recovery to Mytouch, Sensation, Desire Desire HD & Desire S
Fixed most issues
Fixed lag issue
Ram & Performance improvement
Updated MyTouch Kernel to latest RCMix
Added RCMix Tweaks App in Settings (thanks RCMIX TEAM)
Skin Updates
link ver 3.1: http://hotfile.com/dl/141666354/9b5a321/CoreDroid_Sensation_V3.1_Sense3.5_RV.zip.html
-Updates v3.2 : http://hotfile.com/dl/142691205/ea55445/CoreDroid_Sensation_V3.2_Sense3.5_RV.zip.html
-Update v3.3 :
http://hotfile.com/dl/143878990/d53eab6/CoreDroid_Sensation_V3.3_Sense3.5_RV.zip.html
Rom có thể bật sáng màn hình bằng nút volume thay vì phải ấn nút power nhé
Chính vì màu mè mới là đặc điểm riêng của rom này mà,xài mãi mấy icon gốc cũng chán
update v3.3
Change Log:
All known issues fixed (Differ from device to other)
Adjusted a couple of tweaks
Updated some skin parts
Removed Arabic/RTL patch from Sensation as it was causing apps to FC, a patch will be provided
Speed and ram improvments
And other minor adjustments
mình đang dùng firm 3.24, cài bản v3.3 không được, hay phải cài firm 3.25 mới đc nhỉ
rom này là android 2.3.5 sense 3.5 nên 3.24 hay 3.25 như bạn nói không dùng được đâu
bạn cần up về 3.21 hoặc 1.7
