[ROM]█ ELEGANCIA™ Rom Series [Mar 17] [v3.3.5], [Theme Sense 3.6 Beats] hay!!!!!
banxaydung
[ROM]█ ELEGANCIA™ Rom Series █ ◄◄ICS►►[1 Apri] [v3.5.0]◄[Sense 3.6 & Sense 4 hay!!!!!
Sau khi dùng thử các bản trên
PdaViệt thấy khá tốt nhưng vẫn còn một số lỗi. Mình check trên XDA có bản rom này Elegancia này khá hay, các iocn khá đẹp, có nhêìu tuỳ chỉnh cho các bạn nghịch, chơi game ko thấy lag và nóng máy (mình ít chơi game lên chỉ test một số game thôi), có thêm tool LeedroiTweaks khá hay
,có thể dùng cho: Sensation, Sensation 4G and Sensation XE
Nguồn: http://forum.xda-developers.com/showthread.php?t=1429953
Thông tin bản rom:
Ω Android ICS 4.03 base on RUU 3.25.401.102 with the latest HTC Sense 3.6
Ω Stock kernel @1.5 Ghz or @1.2 Ghz, selection during Flashing Installation
Ω Fully themed ROMs available
Ω Enhanced Audio Beats included and fully functional
Ω TMOus Wifi-Calling
Ω Enabled GPU UI rendering
Ω Blue highlights
Ω Deodexed, zipaligned, tweaked
Ω Improved SD card read ahead
Ω Extra Quick Settings
Ω Advanced Power Menu
Ω Busybox + runparts, TitaniumBackup
Ω Location is enabled
Ω A lot of junk removed
Ω Screenshot by pressing Power and Home
Ω Sony Bravia Engine - HQ Image and Movie improvement
Ω Latest Market
Ω Looking for Rom stability, outstanding battery life and smoothness,
ChangerLog:
- Full Rom - FULL WIPE is not needed if coming from Elegancia_ICS
- Implemented updated EQS - thanks to Jan
- Reverted back to pure Sebastian 1.5Ghz kernel as not all devices support the tweaked sebastian 1.5Ghz
The above could probably fix the youtube issue few of us were having
- Improved speed
- Added the ability to select Sensation XE during installation phase (to be use only if your device is Sensation XE)
- Added the ability to select the wake-up device by pressing the volume key during the installation phase
- Changed some build.prop values to get most of the Market applications installable
- Gmaps has been updated, that should "hopefully" fix the Navigation FC few of us were having.
- Removed Hosts file
- Enhanced the Beats Sound (as the sound was a litlle bit distorted)
- New dialer skin - thanks to Losown
- Updated Market Apps
- Other minors updates/changes
3.4.5 changelog
3.5.0 changelog
Ω Full Rom: FULL/SUPER Wipe is not required if coming from previous Elegancia_ICS
Ω Updated Sebastian kernel to a less aggressibe 2D GPU (option during installation)
Thanks to SebastianFM
Ω Added back the option to pick-up the 1.620Ghz Sebastian kernel (option during installation)
Ω Added latest Bricked kernel v0.61 (option during installation)
Thanks to show-p1984
Ω Enhanced further Beats Sound Audio
Ω Improved the Rom speed
Ω Updated windows Animation
Ω Updated some parts of the overall Rom Theme
Ω Updated the bootanimation
Thanks to Paul
Ω Updated some properties
Ω Updated PlayStore applications
- Latest Gmail
- Latest Google Play Store (world wide open)
- Latest Google Play Books
- Latest Google Street View
- Latest OpenSignalMaps
Ω Others small updates
Dowload: http://mirror.khaotic.de/elegancia/download/Elegancia_ICS_Phoenix_3.5.0.zip
hoặc http://minus.com/mk44s4Kc2/
Cách up rom:
Yêu cầu cài bản fimware 3.25 để rom chạy ổn định.
Hướng dẫn cài: up fimware trước -> vào thẻ nhớ xoá file cài fimware rồi cho bản rom đã down (.zip) vào thẻ nhớ -> rescovery -> full wipe -> rồi cài bình thường như các bản rom khác.​
Cái này ko rõ, do người dùng, mình cảm nhận pin tốt khi sử dụng, còn b ao nhiêu % thì ko biết trả lời thế nào, ai có thể trả lòi đc ko
đang cần tìm 1 bản sao cho tiết kiệm pin càng lâu càng tốt :D AI biết giới thiệu với
bản này từ ngày 14 rùi,mình sẽ đợi nó ra 1 bản cập nhật nữa rùi up thử xem sao,mấy lần cũng dow nhưng đường truyền nhà mình chậm nên dow vất vả quá nên thôi ^^
mình dùng máy sense thường ... lúc up rom không biết tích vào ô nào để up rom cho đúng vớ máy... xin bro hướng dẫn dùng với nhé
xin hỏi là rom này có tiếng việt không vậy
ICS sen 3.6 Thì hiện nay bản này được cho là một trong những bản khá nhất đấy.
mình không hiểu í câu nói của bạn ..... về rom nào ICS sen 3.6 .... hay rom ELEGANCIA
ồh công nhận giao diện đẹp thật .... cũng có thêm 1 số ứng dụng ... nhìn không đơn điệu như những bản rom khác...hehe...test đã rồi nói tiếp ... vùa up xong ... mai vọc xong thì có chuyện để nói ... trước mắt thấy đẹp la ok ....=D>
Rom này bị lỗi font roi. Bác nào chỉ e cách khắc phục đi ah. Cám ơn đã chia sẽ rom ah
Khi up rom nó có phần tích các ô khi cài, bạn tích vào phần 1.5Ghz hoặc thường là XE ko cần phải tích bạn à
