ROM Galnet MIUI ICS
pnt163
Galnet MIUI ICS is our experimental builds for the Ice Cream Sandwich framework being introduced into MIUI. These builds don’t look any different, however they do come with some of the ICS benefits such as power management and ram management.
Network Modifications:
Corrected Signal Strength Readings in Status
Improved network power consumption
Framework Modifications:
Implemented ICS sensor management
Improved power consumption whilst sleeping
Correctly implemented debugging settings via ADB
Fixed issues with Tethering cutting out mid way through large transfers
HW Acceleration Included (Browser, Video, Games etc)
Android Market (Scroll via images leading to FC fixed)
Improvement in Galnet Video Player playback
UI Improvements
Implemented Extended Settings
Implemented 4 Way Reboot
Added ICS lockscreen to default theme
Added ICS transaction effects
Improved Sharpness and Display quality on I9000 and I9100 builds
Added ICS Keyboard with Vibration Settings
OTHER INFORMATION
The battery calibration will kick in straight away once flashing this rom, therefore you will find that the battery drains quicker than before. Please allow it to drain to around 5% before recharging fully back to 100% for the perfect calibration.
Updater may FC on first boot, don’t worry about it, as it will work correctly once this occurs.
Phone call recording (This is something that we won’t support due to legal issues within the UK, please don’t expect it).
[video=youtube;MbHzfHPhP6I]http://www.youtube.com/watch?v=MbHzfHPhP6I[/video]
Dò tìm trên mạng thấy có thêm bản rom android 4 cho DHD nên post lên các bạn thử nghiệm, tôi cũng mới vừa down xong (cài rồi mới biết được :D)
Download Here
hình như đây là rom muiu ma bạn???? bạn có thể cho một vài nhận xét về bản rom này được không????
Tôi mới vừa cài đặt được cái bản rom này. Cơ bản thì nó không khác gì so với các bản rom miui khác nhiều chỉ có thêm phần hiệu ứng mở ứng dụng giống ICS basic và android version là 4.0.1. Ứng dụng Miui Control có các phần như sau: Statusbar Option, Overscroll Option, Colour Option, App drawer Option và About (chăc các bạn hiểu rõ là gì rồi ha)
Nhưng có thêm 1 phần lỗi nhỏ là mỗi khi khởi động lại thì máy không tự động dò sóng được mà mình phải tự vào phần Mobile Network rồi chọn nhà mạng.
