[ROM] RunnyDrOiD v2.0 By PVTEAM | Ultrafast & Smooth | 2.3.5 | Sense 3.5
truongban_80
UPDATE [ROM] RunnyDrOiD v3.0 By PVTEAM | Ultrafast & Smooth | 2.3.5 | Sense 3.5
Linh bản 5.0 tại http://api.viglink.com/api/click?fo...ad v5.0 Here&jsonp=vglnk_jsonp_13297212852231
Linh bản 2.1tại http://dl.dropbox.com/u/51791776/RunnyDrOiD_v2.1_By_PVTeam.zip
Link bản 2.0 down về http://www.uploadbaz.com/01xxp66w7ie9
Code:
v5.0
- Based On RUU Runnymede 1.14.709.2
- Removed software (CPU) rendering - full Andreno200 (GPU) rendering
- Enabled GPU UI rendering
- Decrese size of rom
- Update Titanium Backup
- Update Rom Manager
- Add Youtube 2.3.4
- Update Es File Explorer
- Add compass
- Improved Sounds Quality
- Improved Smoothness
- Improved Performance
- Improved Battery Life
- Some Other Tiny Things I Couldn't Remember
v4.0
- PVTeam Tweaks
- New Rosie
- New Htc Quick Launch Widget
- New Market ( 3.4.4 )
- Fixed Small Bugs
- Fixed Rebooting After Call ( For incredible S )
- New Framework-res
- Fixed HtcContacts Issue
v3.0
- Based On RUU Runnymede 1.11.1113.1
- Added RCmix Kernel v12
- Removed ICS Keyboard
- Disable SMS To MMS Converting ( Thanks To Memnoc )
- Imrpoved Smoothness
- ZipAlign With Latest SDK r16
- Updated Adobe Reader To 10.1.1
- Updated Adobe Flash Player To 11.1.111.5
- Updated Facebook To 1.8.1
- Updated Maps To v6.0.3
- Improved I/O
- Fix Wallpaper Croping
v2.1
- Added Rcmix kernel v11.1 v2.0
- Change Market Version to 2.3.6 ( More Speed And No Error )- Tweaks For Optimize Ram Usage For Desire Z
- Add 3d Home Screen Settings in Settings/Display
- ZipAlign With Lastest Android Sdk
- Updated Google Maps to v6.0.1
- Updated Facebook to v1.8.0
- Added ICS Keyboard ( For someone want to have persian and herbew keyboard)
- New Bootanimation
- Fixed USB Issue ( Some times have issue some times not )
- Fixed Symlink & Permisions
- Improved Camera Quality
- Camera Fixed For Desire HD
- Tweaks for build.prob
- Removed Full Wipe From The Rom
- Force button lights on when screen is on For Vivo & Vivow (Need To Test)
v2.0
- Multi Device support ( Thanks To RCTeam )
- Supports these devices
- HTC Desire HD
- HTC Inspire 4G
- HTC Desire HD Telus
- HTC Desire S
- HTC Desire Z
- HTC Glacokier
- HTC Incredible S
- HTC Incredible 2
- Added Ultra Smooth Rosie v1.1
- Added Dock Mode
- Added Quick launch widget
- Added ADFree Hosts
- Updated Superuser to 3.0.7
- Removed UV Script ( Now Availbale In Mods At Post 2 )
- Added More Tweaks
- New Bootanimation
- New Downanimation
- Fixed Auto Brightness
v1.1
- Edited Build.prob
- Fixed init.d tweaks
- add uv script
- Added new style of status bar
- Added Bravia Engine
- Added New MMS
- Market Updated to v3.3.12
- Removed EReader.apk
- Removed Watchapp.apk
- Removed Watch 3d widget
- Updated Es file Explorer to 1.6.0.8
- removed delet bookmark from updater-script
- added Lower Auto brightness
- Improve battery life
- Improve performance
v1.0
- RCmix v11.1 Kernel
- EXT4
- Beats Audio added
- CRT added
- Advanced Power Menu
- Increased R/W speed on SD
- some build.prop tweaks
- Improved sound quality
- Improved Graphics
- %Battery
- Removed useless apps
- Busybox added
- Quick Settings XL Added
- Boot.img Edited For More Speed
- Ultra Smooth Rosie Added (Thanks to hamdir)
- Some init.d tweak Added
- Improved camera quality
- Tweaks for internet speed
- Tweaks for optimize ram
- Tweaks for vm management
1 vài hình ảnh từ máy của mình
1 vài cảm nhận khi dùng bản này
- Máy chạy nhanh và mượt
- RAM free lên đến 400MB
- Bộ nhớ trong của máy còn gần 1GB
- Camera hoạt động tốt
- Fix lối skype cũng như gtalk http://dl.dropbox.com/u/51791776/SkypeFix.zip
- 3G và wifi ok
- Ko tích hợp sẵn RC tweaks,các bạn vào đây http://www.uploadbaz.com/0zmqbfo2qux5 để cài
- Pin sạc đầy vào lúc 10h tối, để qua đêm đến 7h sáng check thấy còn 94%, nói chung là tạm ổn
- Bật điện thoại bằng nút volume http://dl.dropbox.com/u/51791776/wake_up_By_Volum_Key_For_RunnyDrOiD.zip
- Update RCTweaks v2 cho bản rom này http://dl.dropbox.com/u/51791776/RCTweaks_V2_For_RunnyDrOiD.zip
- Amaze Camera http://dl.dropbox.com/u/51791776/HTCAmaze_Camera_MODv7_IS.zip
- Fix lỗi máy tự khởi động lại khi gọi http://forum.xda-developers.com/atta...1&d=1325537997 (cảm ơn bạn laloan)
vẫn còn cái biểu tượng gps 911, nhưng trong hinh thi ko có ???, ko có sóng gsm, 3g cũng ko thấy có, ram free 200 ( task manager) còn free ở đâu 400mb thi ko biết
Mình đã uprom này rồi, chạy rất mượt trên HTC Droid Incredible 2 nhưng không có sóng GSM (dùng mạng Viettel). Ai đã up rồi và sữa được lỗi này xin chỉ giúp.
Nếu check ở task manager thì RAM free chỉ có 200MB thật nhưng nếu vào phần running service thì sẽ thấy, còn biểu tượng wifi và 3G lúc mình chụp quên ko bật:))
Do bản này mới ra nên lượng comment ở bên XDA cũng ít nên lỗi trên I2 chưa thấy fix, mới chỉ có fix được lỗi Skype và Gtalk thôi
Thật ra bản ROM này có kernel riêng là "KERNEL: RCMIX_ACS_v11.1_OC_UV_NCR_EXT4 " và có rất nhiều mod nữa. Các bạn tham khảo ở ĐÂY.
Tuy nhiên đây là một dạng Rom giống kiểu Virtuous Rom nên support cho rất nhiều dòng máy khác nhau (điều này không thể bằng Rom viết riêng cho một điện thoại).
Cuối cùng theo mình bản Rom này cũng nên test (vì có nhiều mod kèm theo).
Rom mới thường rất tốt vì nó được chỉnh sửa cho phù hợp với các yêu cầu của người dùng, sửa các lỗi mà bản trước nó chưa hoàn thiện.
Cái sau thì thường tốt hơn cái trước!
Chỉ có một điều là chưa thấy rrom nào làm cho truy cập danh bạ nhanh và thông minh như BlackBerry!
Bản rom này ai thích mượt và nhanh thì nên dùng, ngoài ra nó có khá nhiều mod để chọn, các bạn có thể vào XDA forum DHD để xem và load về
Máy của mình là IS nên chắc chắc là GSM rồi, mình cũng nhận xét tiếp là bản này ít bị lỗi nhất trong các bản mình đã thử, độ nhanh và mượt thì ko phải chê vào đâu được rồi
Thanks. Rom cho Inc2 cũng khá nhiều nhưng ít rom hay hỗ trợ GSM.
có cách nào làm em này chạy gsm trên in2 được không các bác :D mình thấy ưng em này bữa down trên XDA nhưng mà không GSM thì bó tay rồi :(
rom này chỉ có cdma thì phải, gsm ko có, chỉ nhận cuộc gọi được chứ ko gọi đi được, tất cả đều ổn trừ 3g ko thấy hoạt động ( ai biết hướng dẫn tôi với ) không nhận cáp usb nữa (chỉ luôn giùm nha ), còn lại đều ổn, pin xài lâu wifi chơi game tẹt ga
Máy của bạn là I2 đúng ko? Vì trước đây mình cài ko hề bị lỗi này, dùng rất ok mỗi tội giao diện ko đẹp lắp.
uh..i2...nếu is xài được gsm thì i2 chắc cũng xài được gsm chứ, vì is có gsm ko thôi mà, ai xài i2 bị lỗi như vầy mà đã fix thì chỉ bảo với nhá...cảm ơn
Đã có ở trang đầu nhé, bản này mình thấy chụp ảnh có vẻ ổn hơn, bạn nào test rồi cho cảm nhận nhé
mình dùng I2 cài bản 2.1 chọn gms only thì thấy cột sống ko có nhưng vẫn nghe gọi được mới tài o.0 . Dùng mượt, ko bị nóng máy, 3g chưa test, chỉ có cái cột sóng ko hiển thị đúng. Chắc mình dùng I2 nên bị lỗi này.
