ROM senser 3.0 cho HTC DROID Incredible 2
hongkong
<img src="images/pvRanks/VipMem.gif" alt="" border
[ROM]-[Updated][9-10-11]Incredible 2 3D v2.0.1[sense 3.0]GB 2.3.5(softkeys fixed)
This rom is a test rom strait from HTC..... Desire HD was never meant to have anything more but sense 2.1 but HTC decided to update them to sense 3.0 for some reason.... why is this good for us? it good for us because everything is sized correctly by htc, so it looks like it should..... I will no longer be updating my pyramid rom unless something major pops up this will know be my main focus for a sense 3.0 rom..... i use it as my daily driver now and i am very pleased with it, so im sure you will be as well
change log
v 2.0.1
fixed 3D homescreen
fixed usb mount[dont flash kernel if you want usb mount]
switched back to stock kernel
laggyness is gone
almost perfect now
v 2.0.0
New base Desire HD ACE_SENSE30_S (3.06.405.1)
Switched to Ext 4 file system (a lot faster)
switched to dreselldees custom kernel (multiple goveners)
cut down junk in system saved 100+ mb space
fixed cam and front cam
updated build prop
added special build prop tweaks for responsiveness
fixed auto brightness
fixed random chinese in spots
added more speed tweaks to initd
debloated some more
fixed problem with market
updated gapps
added voice dialer
added add free app
tried to fix usb mount but our kernel dont support it so we are stuck with automount for now
all in all its 50% better rom give it a shot its my daily
v 1.0.1
Fixed phone hot restart
Fixed wallpaper previews
Added bootanimation/downanimation
Added missing bianarys
Modified data driver to work better
Added new ramscript
Edit default.xml for our device
And some other things you prob won't notice
Full wipe guys!!!!!!
v1.0.0
fixed wifi
added Htc Calibrate
added 3D homescreen
took out sig check in services jar
added custom OC kernel by chad
added adrev OC daemon
added better weather videos
added new market
fixed mms
added display manager
added SD card speed tweak
added battery calibration script
Beta 2
New complete base(Thanks Goapk)
Fixed softkeys Finally
Mic works
added auto mount from market for mounting p.c.
bluetooth fixed hopefully
cleaned out bloatware
This rom is going to be amazing once i get the bugs worked out i worked on it for 3 hours lastnight and i didnt want to stop but i had to so i uploaded what i have
Beta 1
added missing apks
Fixed mic
added some tweaks to system
cleaned up some of the debug test stuff
added bianarys that were missing
added new default.xml so widgets are loaded on the home screen
still very early i only have a couple hours into it but its better than the alpha build
Features
Sense 3.0
Gingerbread 2.3.5
sized by HTC for wvga
4 in 1 advanced power menu
custom OC kernel
andrev OC Daemon
Native screen capture
Htc screen calibrate
2 stock skins
New inhanced weather videos
250mb free ram on first boot
and a lot more
known issues
*Sd Card unmounts P.C sometimes
*Cant record videos with stereo audio checked uncheck it and record with regular audio
tham khảo thêm và dowload ở đây: http://forum.xda-developers.com/showthread.php?t=1231283
Đẹp hoàn hảo, có mỗi cái ko hỗ trợ GSM hay sao á.
Làm up xong phải way lại Miui, lần sau tìm hiểu kĩ rồi post nha ...
