ROM UNI mới 2.12.02 WWE của Jwrightmcps
minhsu
<img src="images/pvRanks/VipMem.gif" alt="" border
Đã có Rom 2.12.02 WWE của Jwrightmcps mới nhất. Được giới thiệu có nhiều tính năng hay, các bạn cùng test nhé.
Jwrightmcps Crossbow ROM Update 2.12.02 WWE
Previous Release Fixes:
New OS Core 5.2.1921 (Production)
Added SDHC support.
Added support for "Flight" mode (via Comm Manager).
Corrected password lockout issue.
Corrected button assignment for record button (press & hold).
Corrected Microsoft Voice Command startup issue.
Corrected "Remote SIM Access" service startup issue.
Corrected GPRS resume from standby issue.
Corrected lock-up on soft-reset issue.
Corrected default notification sounds.
Corrected system notifications (low battery)
New ROM Details:
Windiws Mobile 6 (CROSSBOW)
OS 5.2.1921 (Build 18521.0.7.0)
Storage Memory: 43.72
Program Memory: 49.95
Page file: 5.2MB
What's new in this Windows Mobile 6 ROM Update
CE Rom: (2.12.00 WWE)
- Adobe Reader LE 2.0
- CompactFramework 2.0 SP1
- Device Page Pool set to 5.2 MB
- GPS receiver Control applet
- Improved outlook, including fax view
- Increased interface speed
- Bundled IP-telephony (VoIP, SIP standard)
- Smart Dial 2.0, fast search through contacts, call history
- Support for shortcuts in Outlook Mobile
- Full-fledged meetings arrangement system
- Support for HTML in messages (Exchange Server 2007 required)
- Smart Filter – handy and fast search through messages
- Numerous MS Exchange 2007-tailored changes
- Integration with Windows Live online-services (including MySpace)
- Marketplace – purchase, download, and install directly from the device
- Encryption – bundled memory card encryption
- Improved Remote Desktop, supports true full screen and sound
- New Bluetooth stack including A2DP
- Better integration of SIM / USIM contacts
- Alphabetic sorting of SIM / USIM contacts in contacts list view
- Improved 'Internet Sharing'
- Much improved quick start wizard with 'skip' for tutorial, settings setup at boot time
- Pre-provisioned email accounts
- vCards over SMS
- SMS Multiple Recipient improvements
- Save SMS to SIM
- One handed PPC folder navigation improvements
- WMP full screen video on all devices
- Smart-type search
- Larger number of preconfigured email providers (including GMail!)
- USB Hard-drive emulation updated (for sharing storage card contents via USB connection)
- Bluetooth Mouse support (Stowaway Driver set)
- Bluetooth car-kit SIM access
- Added Battery Icon at bottom
- IA Zip update
- SIM Manager
- WM 6 Comm Manager with "Flight" mode
- New Task Manager 1.5
- New Global Network Configuration Wizard
- New Support for SDHC cards
Extended Rom: (2.12.07 WWE)
- Skype 2.1 (with Today Plug-in)
- Windows Live Search
- Windows Mobile DST Update
Radio Rom: (1.15.00)
- This radio stack has passed our testing.
Release Bugs:
None
Dopod 900 WWE Download:
ftp://xda:xda@ftp.xda-developers.com...1207_11500.zip
i-mate JASJAR WWE Download:
Orange SPV m5000 WWE Download:
O2 XDA Exec WWE Download:
QTEK 9000 WWE Download:
T-Mobile MDA Pro WWE Download:
Vodaphone V1640 WWE Download:
WinCE 5.2.1921 Source Package:
ftp://xda:xda@ftp.xda-developers.com...21_WWE_SRC.zip
NOTE: The installs have been digitally signed for your confidence and safety!
(Digital Serial Number: ec b8 10 3b e7 65 19 ba 4f 05 48 14 e3 34 97 61)
How-To Verify a digitally signed file against a known serial number
Step 1
Download the file you wish for your device.
(i.e. "JASJAR_WWE_20108_20301_11300_wwe_ship.zip")
Step 2
Unzip the download.
(double-click the ".zip" file and then click on "Extract all files")
Step 3
Open the directory that you un-zipped the download to.
(i.e. folder "JASJAR_WWE_20108_20301_11300_wwe_ship")
Step 4
Locate the InstallSheild setup program in the ROM folder, then right-click it and choose "Properties".
(i.e. "JASJAR_WWE_20108_20301_11300_wwe_ship.exe")
Step 5
Once the file properties is open select the "Digital Signatures" tab, then in the "Signature List" double-click the "HTCCertificates signing authority" signature.
Step 6
Once the "Digital Signature Details" is open select the "Advanced" tab then compare the "Serial number" with the known one.
(My S/N: “ec b8 10 3b e7 65 19 ba 4f 05 48 14 e3 34 97 61”)
Step 7 (Results)
If the serial numbers match then rest easy because you are using a "TRUE" Jwrightmcps ROM that has not been altered and is virus-free.
If the serial number does not match then it is not my original work and should not be used!
NOTE: I did this is case these files make it onto other sites, it will give you guys a way to tell if it is really mine or not. I will always use this serial number (ec b8 10 3b e7 65 19 ba 4f 05 48 14 e3 34 97 61) from now on to sign all my work, so please make note of it!
bạn đã test bản Rom này chưa, cho mọi người vài lời nhận xét để biết với !
cảm ơn bạn nhé !
tôi thấy bản này có vẻ hòan chỉnh đây,đang down thử đây ,bây giờ test xem có lỗi gì không ,tiện thể mọi người test xem có lỗi không rồi cùng thảo luận nhé
bạn minhsu ơi ! bạn kiểm tra lại link download đi nhé !
mình và mọi người k down được !
Minhsu vẫn download bình thường, nếu dùng CT như NetAnts download sẽ nhanh hơn. Minhsu chưa uprom được vì EXEC của mình đang bị trục trặc.
Dưới đây là link của Jwrightmcps Crossbow ROM Update 2.12.00 WWE trong forum.xda-developers:
http://forum.xda-developers.com/showthread.php?t=336149
Rom có vấn đề với non-SDHC card
1. Gif image không thể coi được
2. Máy sẽ bị đứng nếu sài card non-SDHC.
2 lỗi này mình post trên xda-developers rồi.
Đã up rồi !!!!Chạy ngon !!!!Nhưng phần email chon lưu trên thẻ nhớ ngoài không được!!!
em vào tải về ko được ! có bác nào úp hộ lên link khác giùm nhe,em thanks trước.
Jwrightmcps cũng đã có thêm 02 Patch đưa lên 13.10.2007:
Signed_SDHC_Rollback_Driver
Signed_VoIP_Today_Plugin
Chạy tốt được 02 ngày, hôm qua bắt đầu xuất hiện treo máy khi có cuộc gọi đến, bắt đầu xuất hiện tình trạng khởi động lại máy phải reset 2-3 lần mới chạy bình thường, không thi vào đến màn hình bình thường rồi treo luôn reset lại mới được.
Trước đây chạy 2.02.02WWE cũng như vậy, bực cái khi treo máy mình không biết nhưng gọi đến vẫn đổ chuông bình thường, thế mới ác.
Khi chạy bản ROM gốc 1.30.162 hay bản 2.10.11 PDAVIET thì không bị như vậy, chạy rất trơn tru với Radio 11.
Thêm một số phát sinh nữa khi dùng bản 2.12.00 WWE này:
Comma... khi chuyển sang chế độ Flightmode (on), sáng dậy chuyển lại sang off không tác dụng, chọt tè le cả phone, flightmode cũng chịu phải softreset lại;
02 chương trình khá hay của O2:
1. O2SMSPlus 1.6: không chạy được, không khởi động lên được
2. O2Plus 2.3: cũng vậy, hơi tiếc, trên bản 2.10.11 PV O2Plus 2.3 cũng không chạy Schedule được nhưng những phần khác vẫn khác vẫn ổn.
Kể cả các bản trước và bản này mình cũng chỉ cài đặt những chương trình thông thường như: spb backup, spb time, resco explorer, fontvnsys, typing, TCPMP, ATM PV, ... khi chạy trên bản 1.30.162 WWE hoặc 2.10.11 PV đều tuyệt đối ổn, không hề treo hay phải softreset mấy lần mới được.
