[ROM] Update Android Revolution HD - by Mike 1986 {Gingerbread Android 2.3.2}
heobanhki
Android Revolution HD β| Gingerbread & New HTC Sense 2.1 | Android 2.3.2
http://forum.xda-developers.com/showthread.php?t=984045
*********Phiên bản Beta *****
Android Revolution HD 4.0 β 4
- New kernel 2.6.35.10-g1418c33 (incorporated from 2.25 base)
- HUGE SPEED IMPROVEMENT
- Incorporated some goodies from 2.25 base (but no bugs)
- Added Voice Dialer (will be installed only for 4G users)
- Working HTC Notes Widget included (Thanks to bosbode)
- Added 3G prefix for 3G capable networks
- Some users may notice louder / better sound quality
- There is hard work in progress to bring you first custom kernel for HTC Desire HD Gingerbread ROM. Be ready for the Revolution ;)
- No full wipe is needed if you have already flashed any version of AR HD 4.0 beta.
link :
http://xda.ckgaming.co.uk/db_mirror/Android_Revolution_HD-4G_4.0_beta4.zip
http://uploaded.to/file/5r6ctsx8
http://www.megaupload.com/?d=M8WOZVXE
http://www.fileserve.com/file/YSKXraY
http://www.filesonic.vn/file/326301291/
http://hotfile.com/dl/111478306/e9321e8/Android_Revolution_HD-4G_4.0_beta4.zip.html
http://rapidshare.com/#!download|975l33|453974314|Android_Revolution_HD-4G_4.0_beta4.zip|228472
http://www.multiupload.com/Q8GNABR1IX
Thêm % pin:
link :
http://www.mediafire.com/?3bya78lqss7251p
mirror:
http://dl.dropbox.com/u/17626742/Programy/Bateria/3.0.0.x.Stock%2.3.2.zip
Theme - based 2.16 :
******info******
4x5 grid and widget
Rosie.apk
com.htc.FMRadioWidget.apk
com.htc.FriendStreamWidget.apk
com.htc.MusicWidget.apk
com.htc.StockWidget.apk
com.htc.TwitterWidget.apk
com.htc.WeatherWidget.apk
htccalendarwidgets.apk
HtcClockWidget.apk
HtcLaputaWidget.apk
htcmailwidgets.apk
htcmsgwidgets.apk
HtcRecommendsWidget.apk
HtcCalculatorWidget.apk
Icon Changed
Rosie.apk
com.htc.resources.apk
framework-res.apk
Link theme
http://www.mediafire.com/?wd3xma2v9h2tt32
[/IMG]
[/IMG]
[/IMG]
[/IMG]
Link :
http://www1099.megaupload.com/files...e/Kalagas_Mixed_Theme_GB_ARHD_v1.0_signed.zip
http://fileshare193.depositfiles.co...7/Kalagas_Mixed_Theme_GB_ARHD_v1.0_signed.zip
Hường dẫn :
1./ Uprom
2./ khởi động lại.
3./ Up theme, ... % pin.
PHIÊN BẢN CŨ
Android Revolution HD 4.0 β 3.1
Info :
- Version 3.1 - fixed scrolling issue
- Fixed proper network speed
- build.prop fixes
- Stability fixes
- HTC Notes Widget removed (doesn't work on GB yet)
- HTC Plurk removed
- Wap browser removed
- Adobe Flash Player updated to latest 10.2.156.12
- Facebook updated to latest
link :
http://xda.ckgaming.co.uk/db_mirror/Android_Revolution_HD-4G_4.0_beta3.1.zip
http://dl.dropbox.com/u/10700171/Android_Revolution_HD-4G_4.0_beta3.1.zip
http://dl.dropbox.com/u/11823/Android_Revolution_HD-4G_4.0_beta3.1.zip
Android Revolution HD 4.0 β 2 [11.03.2011]
Info :
- Audio fix for Inspire 4G / Telus users included
- Removed development tool
- Added more locations
- Added Hindi fonts (Thanks to not_a_geek)
- More build.prop changes
- More bloatware stuff removed
- Google Maps updated to latest 5.2.1
- Market fix (Thanks to RaiderX303)
- Boot-sound removed
- hosts file updated to latest
link download :
http://xda.ckgaming.co.uk/db_mirror/Android_Revolution_HD_4.0_beta2.zip
mirror :
http://www.megaupload.com/?d=T8IRDSVE
http://hotfile.com/dl/109774022/5ea6af3/
http://www.filesonic.com/file/198561661/
http://rapidshare.com/#!download|214tl2|452030399|Android_Revolution_HD_4.0_beta2.zip|230508
link mediafire
http://www.mediafire.com/?hccpmf6pnujv0at
http://www.mediafire.com/?3e936aksa3dohzp#1
Android Revolution HD 4.0 β 1
link :
http://www.mediafire.com/download.php?b9i8a1dkaax54tv
http://www.mediafire.com/?arizqisshvx2mw2
About Android Revolution HD β
* Official Android 2.3.2 (Gingerbread) - leaked HTC ROM 2.16.0.0
* This is improved version of stock ROM - no visual changes!
* Kernel: 2.6.35.10
* ROOT (SU + SuperUser Permissions - Thanks to ChainsDD)
* Unsecured boot.img
* BusyBox
* RAM optimizations
* Speed optimizations
* Very fast, clean & stable
* Bloatware applications removed (Amazon MP3, SoundHound, etc.)
* All system applications updated to latest available
* Multilanguage (WWE)
* Zipaligned (Improved RAM management)
* Zipalign on boot (for user applications)
* Fully de-odexed
* init.d scripts (BusyBox run-parts) support
* NANO text editor & sysro/sysrw commands support
* Excellent battery life
* ROM is ads-free. It means that you don't need any extra software to get rid of advertisements
* You can replace HTC boot animation with any custom boot animation. Just replace bootanimation.zip in data/local
* Nguồn Mike 1986 [xda-developers.com]
Soft nối file :
http://www.mediafire.com/?3lskeqs7mxmzdpq
full wipe 1.3:
http://www.mediafire.com/?gwwxqgp95cbgbcn
thanks bạn! bạn cho thể hướng dẫn chi tiết cach update theme được ko? thankss!
1./ Uprom
2./ khởi động lại.
sau khi up rom khở động lại máy cho lần đầu hoàn chỉnh rồi mới uptheme
trong 2 cái trên bạn chỉ chọn hoặc theme hoặc % pin vì trong theme đã có & pin rồi.
cách up thì như uprom nhưng không wipe
m đã up theme như bạn nhưng khi hiện màn hình có ảnh ảnh đuôi *gif ( có rom hình chữ android) là nó đứng yên, thế mới chán:( lại phải up rom lại
bạn thực hiện sau khi đã uprom và khởi động lai điện thoại.
Nên nhớ là không up 1 lèo rồi mới reboot máy.
XIn cho hỏi : Theme trên và % pin có u đc cho room của Ledroid và Codroid không nhỉ ?
Mình đã xài B1 của Mike hơi giật giật . Thử bàn B2 xem thế nào
Ah cho hỏi nữa .. Khi mình up room mình chỉ Wipe data/ Factory reset trong Recovery thôi.. Như vậy có OK không
Full Wipe thì được cái gì nhỉ và làm như thế nào ?
Tác dụng của Full wipe là bạn xoá sạch các file trong bản rom cũ trong máy bạn để tránh xung đột với rom mới, thường khi bạn úp bản rom cook sang rom miui nên mới cần làm, theo mình trước khi up rom bạn nên làm bước này dù cho bạn up bản nào, cũng không mất nhiều time đâu mà. cách làm thì bạn qua Đây!
Sao mình up cái theme BGB4x5Theme vô thì mấy cái widget của HTC đều bị lỗi hết vậy .People với Messsages thì bị thu nhỏ mất 1 khúc,phôt thì bị lệch lên trên,còn Calendar thì dùng không được.Gỡ cái theme này ra sao vậy bạn ?
theme trên dùng cho các bản có base 2.16.
nếu bạn có backup thì retore lại, còn cách gỡ theme thì bạn thử factory reset , nhưng mình chưa làm thế bao giờ :D
mình nghĩ tốt nhất là bạn up rom lại.
bạn heobanhki cho mình hỏi bạn dùng phần mềm nào chụp ảnh màn hình vậy? HD m sử dụng luôn nhé! thanks
bạn co thể lên market tìm ct shootme.
cài xong khi chạy shootme chon hide ( màu xanh), mỗi lần bạn lắc máy nó sẽ chụp ảnh màn hình hiện tại, kg muốn chụp nữa thì mở nó lại rồi chọn quit.
Bạn cho một ít nhận xét về bản β2 mới post đi, chụp hình quay phim có ngon hơn không, máy chạy có mượt không vậy? âm thanh, web thế nào?
Tùy nhận xét của từng người thôi. Mình chỉ nhận xét là khá mượ t, rất đáng dùng.
Trước khi bận đánh giá mình khuyên bạn nên chú ý để kg nhận xét là giật...
1./ Menu 2.3 mở theo dạng lật từng trang 1, mỗi khi vuốt thì menu chạy 1 trang xong dừng lại, vuốt cái thứ 2 nó mới chạy trang tiếp theo, không như 2.2 khi vuốt nó chạy liên tục đến hết vì thế mở menu 2.3 có cảm giác giật. nhưng thật chất kg phải vậy.
2./ Khi mở hình trong galery lần đầu tiên, máy sẽ load hình hơi chậm do máy phải tạo các preview hay các hình nhỏ để chung ta xem trước, sau bước này bạn mở lại hình sẽ chay rất nhanh ( nhưng vẫn kg nhanh như các bản non sense ).
3./ GSM, wifi khá tốt khỏe hơn 2.2 ở cùng 1 bản radio.
4./ Âm thanh nghe sống động, chơi gam mượt hơn.
Tớ thd chưa up bản này nên chắc cũng ko nhận xét nó giật đâu, tớ up thử bản beta 4 của leedroid thấy cũng kha ok, chụp hình và quay phim good hơn, tiếng to hơn, máy chạy mượt, web nhanh. Đặc biệt là màn hình màu có tươi tắn hơn thì phải. Tuy nhiên máy vẫn bị vài lỗi nhỏ chưa biết cách khắc phục. Bản này có lỗi gi ko.
Bản này mình thấy chạy giật hơn bản 2.2. Chờ bản hoàn thiện ra chắc ngon hơn.
Sau một thời gian nghịch Rom thì có cảm nhận trong những bản Rom cook đình đám thì Rom của Mike có vẻ kém hơn so với Miui và LeeDroid, cũng chả phải chuyên gia nhưng nhận xét từ phía một người dùng thì thấy Rom của mike có nhiều lỗi vặt và máy chạy không được mượt (kể cả các bản 2.2), thỉnh thoảng hay đơ dù đã up và sử dụng đúng cách.
Bạn phuongDung16023 dùng Room của Ledroid có OK không ? Đã xài thử room của PDA chưa.. Mình ngại up room quá, cái nào cũng có cái không ưng ý
