ROM v1.17.707.10G >>> v1.17.707.11G (Aku 0.7) CHO HTC TOUCH
I have one problem, with this rom. When I install Wisbar Advance (v2 or v3) BatteryStatus stoped working. Any ideas, please?
you need part two cause the file is being compressed into 2 separate files of "rar" it needs each other in order to be able to extract everything :D
I see. So I guess I was lucky to do the right thing by putting both rar-files in the same folder and when I unrar the first one it automatically also unrar the second one.
Just installing it ....
I can not download TouchROM_v1.17.07.11G_PDAVIET.part1.rar. When finish only15.5 kb. No have anythings, How I can do..
Thanks! =D> excellent relaese except that "notes" does not work.:O
Looking forward to version 12 :D
When will version 12 be out with "notes" fixed?? :)
Looking forward to its release ;)
Bản ROM 12 sẽ có thay đổi về OS:
CE OS 5.2.1933 Build 18533.0.7.0
ROM sẽ giới thiệu sau vài ngày nữa.
Hi PhamQuang,
Good to see your updates. Waiting for you to upload and show the link.
THANK YOU!!! :)
how come the OS vérsion in 12G is older than in the 11G version?
Thanks in advance for the upgrades you are doing a great job!
bác Quang oi!em mong ban Rom này của bác quá, bác có cho skin touchflo cube của XDA_developers vào không?và touchflo 2 như trên youtube gthieu k?Neu dc nhu the thi that la tuyet voi bac Quang ah?cam on bac nhiều!chúc bác thành công
xin lỗi,hình như tất cả các link tải rom dều die rồi.Ai đó có thể post lại rom tốt nhất bây giờ không.cám ơn.
