[ROM] Wildfire S Gaming ROM -OC-806Mhz-Customized and Modded [DATA2EXT] ( 3/16/12 )
Screenshots:
GB 2.3.3 Features:
Overclock Kernel
tun cifs utf8
sio, vr
Support Swap Ext4
Transparent SenseUI
DATA2EXT
New Transistion Effects
Extended Quick Settings
Modified HTC Wallpapers
Added Herring Skin by slobo2712 modded by me
Sense 3.0 MMS
Added V6 Supercharger thanks to zeppelinrox
Auto Battery Calibration after newly flashed
SD Card read speed Increased
Auto zipalign during boot
VM Heap size Changed to 32M
Removed HTC and Android Spyware
Newest Busybox
Newest adfree hosts
Zipaligned
Advance Power Menu
CRT On Off Animatiom
New Bootscreen Downanimation
Ubuntu Font
4x5 App Drawer
Bravia Engine
Fast GPS fix by d33ps1x
added beats mod - by fuss132
Deodexed
Updated Apps:
Google Search Box
Gmail
Market with Navigation
Power Dashboard Widget
Youtube
Superuser and su
Maps
HTC Flashlight
Teether Game
Preinstalled Apps:
Adfree
ES File Explorer
No frills CPU control
WifiKill
Terminal
Script manager
ICS keyboard
Flash Player 11
Dolphin HD
ROM Manager
ROM install instructions
Download Minitool Partition Wizard and install
Put SDCARD in card reader
Make the following Partitions
1.Fat32 - Resize this to have unused space of 1500, files won't
be touched or erased in this partion.
2.Ext4 = 1200 - PRIMARY label this "userdata" without quotes
3.Ext4 = 220 - PRIMARY label this "extdata" without quotes
4.LinuxSwap = 80 - PRIMARY
NOTE: it should be in the ff. order FAT32,EXT4,EXT4,SWAP
5.In Minitool Partition Wizard - Click Apply wait to finish
6.Copy ROM to SDCARD, and eject and put inside phone.
7.Boot in recovery
8.Wipe Data, Factory Reset
9.Wipe Cache
10.Advance > Wipe Dalvik Cache
11.Go back Install zip from SDCARD
12.Choose the ROM zip then flash.
13.When finished flashing, Reboot system now
14.Wait 5-15 minutes until ROM is fully booted.
Files Download:
ROM
http://www.mediafire.com/?qsb7db713eruzy8
nguồn: http://forum.xda-developers.com/showthread.php?t=1541848
Update bản final 22/03/2012
ROM install instructions:
1.Download Minitool Partition Wizard and install in PC
2.Put SDCARD in card reader and
make the following Partitions NOTE: it should be in the ff. order FAT32,EXT4,SWAP
be touched or erased in this partition.
3.Make 2nd Partiton Ext4 = 1400 - PRIMARY
4.Make 3rd Partition LinuxSwap = 100 - PRIMARY
7.Boot in recovery
9.Wipe Cache
15.Reboot to recovery again > don't wipe > install zip from sdcard then choose data2sd zip
16.Then reboot system - This will take time cause files will odex.
NOTE: If you install some mods or modify system files NEVER wipe cache, and dalvik cache.
RULE OF THUMB: If you choose to flash over without a wipe and have lags, FC's, things missing, or things just don't work right then flash again with a complete wipe'
Files Download:
ROM
http://www.mediafire.com/?dgnokk7513by32v
DATA2SD
http://www.mediafire.com/?6gtj6gnukb54yx9
Nguồn: http://forum.xda-developers.com/showthread.php?t=1541848
đây là rom 2.3.3 đc cook từ rom ship thì phải? :)
xài room này ngon thật.
Hihi.rom cook nào cũng phát triển và chỉnh sửa trên nền rom ship mà.câc dev chỉ thêm or loại bỏ app,oc cpu,thay kernel...cũng chính điều này làm máy ko ổn định.
rom này có bị delay lúc bấm mút mở ra ko bạn.. trc giờ thấy rom nào cũng bị vấn đề đó.. khó chịu ghê luôn. delay chừng 2 s
Room này có mượt ko bạn mình đang dùng cái room and 3.5 send 3.5 giat lắm rất là khó chịu mà bản này có tiếng việt không vậy
Ai có room nào ỏn định ko. Room update đầu tiên của máy lên 2.3.5 có tiếng việt ý m xài mấy room up này giật kinh khung khong biết làm sao nữa máy giạt quá
đang dùng bản 2.3.5 h chạy bản này có sao ko.mà ớn nhất là mấy cái OC,hay bị đơ máy lắm
rom này là rom 2.3.3 y như lúc mua máy vậy!
mình up rom ship 2.3.3 xài chán nhưng rom này ngon!
đã có update bản final
