ROM WM6.5 cập nhật dành cho HTC WIZARD
ROM Version :
ROM Version : 6.5.0.0.7
OS Version : 6.5.0.0 WWE
Releasd Date : 04 May 2009
OS Version :
Windows Mobile 6.5 Professional
CE OS 5.2.21728 ( Build 21728.5.0.20 )
Preinstalled Softwares :
Advanced Config v3.3
AdvancedNetwork v1.0.10.1
Arcsoft MMS v5.0.31.81
BtCrawler v1.1.0
Bluetooth FTP v1.2.33309.91
BTBPP 1.7.18
Camara v3.00.25498
Comm Manager v2.7.5.0
ClearTemp v1.2
CleanRAM v1.3.9
Chome
Connection Setup v2.7.37654.1
Diamond/Topaz/Rhodium Mixed Ringtones
EzInput v1.5.32288.0
HD Wallpapers
HTC Album v2.0.18183032.0
HTC Audio Manager v2.0.18193326.0
HTC Calculator v1.0.19132026.00
HTC Task Manager v2.1.34837.5
Input Config v0.1
MS Office 6.1
Modem Link
OBEX Inbox v0.94
PIM Backup v2.8.0.0
Poorlyduck Diamond Dialer
PDAcraft Paint v1.1.2
Palringo v1.3.1
RSS Hub v2.1.1.1087.01
Synchro Time 0.94
SRS WOWHD With BT v1.2.10.0
SmartLock v1.7C
Touch Note v1.0
TaskMgr v3.1
TouchFlo v3.0.32567.1
Voice Recorder v1.10.18181632.3
Windows Media Player v10.3 Build 21728
WinMo 6.5 Few Extra Themes
Games :
BubbleBreaker
Chess
Kevtris
PocketSand
PocketSudoku
Solitare
Screen Shots :
New Features :
Input Config : [ StartMenu -> Settings -> Personal -> Input Config ]
A small new tweaking like app developed by me, for selecting/switching the inputs ( EzInputs <- OR - > Default Inputs ). You can select either EzInputs ( Full QWERTY ( Default ), Compact QWERTY and/or Phone Keypad ) or Default Inputs ( Keyboard ( Default ), Letter Recognizer and/or Block Recognizer ) to display/show in SIP list. BTW; we get 2 - 3 MB FREE RAM, when all or any of the Default Inputs are selected/set'ed. After making any changes; Click apply and accept for softrebooting ( Highly Recommended ).
Modem Link : [ StartMenu -> Internet -> Modem Link ]
A same app which works same as internet sharing. For more info search for Modem Link, either here or google.
Log Report :
Added/Updated -
CleanRAM.
Input Config.
Modem Link.
"My Special Thanks To" in Getting Started.
And some backend...
Fixed/Changed -
Connection Setup.
Error while opened new doc in Word Mobile.
Icons on StartMenu.
Increased PP from 5MB to 6MB. For getting better and faster performance.
And some minor...
Removed -
Smart dialer/dialing. ( Was taking more RAM memory )
Smartskey. ( Had trouble with Startmenu opening )
FingerKeyboard.
ULDR Part on MBR!
Known Bugs :
NOT YET FOUND!!!
Storage - 42+ MB Free.
Program - Min 20 MB ~ Max 25 MB Free, in Default Inputs selection(s) and Min 18 MB ~ Max 22 MB Free, in EzInputs are selection(s).
quan trọng link
http://www.4shared.com/get/10973679...sionid=E2DFE5E19F0C0427F05BEB651C8B6618.dc138
http://rapidshare.com/files/240565861/CR86_THD_v6.5.0.0.7_Beta.zip
cho mình hỏi rom nay cai cho chip g4 unlock được ko,mình mới dùng máy nên ko biết nhiều
bản rom mới của cracing 6.5.0.0.7 dùng rất cool... nhưng bị 1 cái là ko thể tìm tên nhanh bằng dialer để gọi ... hơi buồn chút .. bác nào biết cách fix chỉ mình giùm nha thanks (cái này khá quan trọng )
cài smartdial vào bạn ah!bộ cài thì mình kô nhớ nữa nhưng bạn cứ search trên diễn đàn nhiều lắm!
hịc tình hình là em ko tìm ra được :|... bác giúp em thì giúp cho chót thanks bác nhiều lắm :)
Version 6.5.0.0.8​
ROM Version :
ROM Version : 6.5.0.0.8
Releasd Date : 07 May 2009
OS Version :
CE OS 5.2.21806 ( Build 21806.5.0.20 )
BtCrawler v1.1.0
BTBPP 1.7.18
Camara v3.00.25498
ClearTemp v1.2
CleanRAM v1.3.9
Chome
HD Wallpapers
Input Config v0.1
MS Office 6.1
Modem Link
OBEX Inbox v0.94
PIM Backup v2.8.0.0
Palringo v1.3.1
Synchro Time 0.94
SmartLock v1.7E
Touch Note v1.0
TaskMgr v3.1
Windows Media Player v10.3 Build 21806
Games :
Bubble Breaker
Chess
Kevtris
Pocket Sand
Pocket Sudoku
Solitare
Pocket Gravity
New Features :
Log Report :
Added/Updated -
* SmartLock.
* Pocket Gravity.
* Donor list in Getting Started.
* And some backend...
Removed -
* ULDR Part on MBR!
Known Bugs :
NOT YET FOUND!!!
For SoftSPL Users :
Bin folder is hidden in the package so first you should enable "Show hidden files and folders" in folder options and then copy the nk.nbf from the bin folder.
For HardSPL Users :
Just run the welcome shortcut or enable "Show hidden files and folders" in folder options then go to bin folder and run RUU_GO.exe.
For Connection Setup Users :
ROM don't includes data base file ( With effect from version 6.5.0.0.6 ) so you have to install manually ( cab from Xtra Stuffs, post #7 ) and use connection setup from settings -> connections.
Welcome shortcut is only for hardspl users. NOT FOR SOFTSPL USERS
Download Link :
http://www.4shared.com/file/110326724/e61f7ac1/CR86_THD_v65008_Beta.html
http://rapidshare.com/files/241693835/CR86_THD_v6.5.0.0.8_Beta.zip
Special Beta, IE6 + Widgets : http://www.4shared.com/file/110324609/153c642/CR86_THD_v65008_IE6Widgets_beta.html
( IE6, Market Place, LiveSearch Widget, Money Widget, Weather Widget )
Version 6.5.0.0.8​
ROM Version :
OS Version :
BtCrawler v1.1.0
BTBPP 1.7.18
Camara v3.00.25498
ClearTemp v1.2
CleanRAM v1.3.9
Chome
HD Wallpapers
Input Config v0.1
MS Office 6.1
Modem Link
OBEX Inbox v0.94
PIM Backup v2.8.0.0
Palringo v1.3.1
Synchro Time 0.94
SmartLock v1.7E
Touch Note v1.0
TaskMgr v3.1
Games :
Bubble Breaker
Chess
Kevtris
Pocket Sand
Pocket Sudoku
Solitare
Pocket Gravity
New Features :
Log Report :
Added/Updated -
* SmartLock.
* Pocket Gravity.
Removed -
* ULDR Part on MBR!
Known Bugs :
NOT YET FOUND!!!
For SoftSPL Users :
For HardSPL Users :
Download Link :
Mấy bản này bị lỗi kết nối không tự động cập nhật các thông số của mạng vina,viettel,mobile...khi kết nối internet phải cài đặt lại thông số nhưng vẫn bị lỗi
tai vì mấy bản rom này không có netwizard chứ không fair là lỗi đâu bạn!bạn cài netwizard vào là nó tự set cấu hình thôi!
lâu lắm mới vô pdaviet :d
Bản 6.5 này mềnh dùng từ ver đầu tiên cho đến ver hiện tại :d
NGON
:x
Mình đang dùng bản 6.5 v0.0.6 thấy ổn định nên chưa up bản v.08. Ai up rùi cho ý kiến + post hình cho anh em tham khảo với!
Thanks nhìu! :)
Loay hoay từ chiều đến giờ với bản Ver 6.5.0.0.7 mà vẫn chưa được cứ báo lỗi (300). Chắc là tại cái cáp USB rồi.:(.
minh dung 007 thấy it loi ram tot nhung ton pin lam!đang tim mot ban kha quan hơn!
cho mình hỏi : những bản Room đó, bản nào dùng cho Chip OMAP Prophet vậy
Các bác cho í kiến về ver này của xda và 0.8 của cracing cái nhỉ :D ... em vừa đi chơi xa về thấy mấy ver mới máu nó lại nổi lên mới chết .. hì hì :D
[11/JUN/09] X2H's WM6.5 Designers ROM | IE6 + Widgets | Better Faster & More Stable
Introduction:
Hey Guys!!!
This is my special Designers ROM(D.R) which has custom made themes, wallpapers, startup animation, etc by different users and me. It also includes the latest IE6 and M$ Widgets so you'll enjoy using this release, it'll be out in time of few days.
*Windows Mobile 6.5 Professional
*CE OS 5.2.21812 (Build 21812.5.0.50)
*24MB(24960KB)+ Free RAM at Boot
Application List:
* Advanced Configurations Tools v3.3
* Arthemus QVGA Dialer
* Arthemus QVGA Taskbar v3.1
* BTFtp
* Cool Camera
* CHome(Titanium) [with Titanium Weather]
* DShow
* FullScreen Player
* Finger Keyboard v2.1 (only the BlackGreen skin included, for rest download this)
* htcAddicts cleanRAM v1.4.0
* HTC Camera
* HTC TaskManager
* Iolite Album
* Iolite CommManager
* mHubVO
* Microsoft Mobile Office 2007
* Network Plugin
* Network Wizard
* Obex Inbox
* Opal USB to PC Popup
* Opal ArcSoft MMS v5
* Oxios Memory(CloseApps, Hibernate)
* NETCF 3.7
* Performance Tweaks
* Pocket RAR
* psShut XP
* Rhodium/Topaz Calculator
* Smartskey (no overclock)
* Smart Touch
* Sound Tweaks
* Topaz Advanced Network
* Topaz Data Disconnect
* Topaz Picture Enhancements
* Topaz Outlook Enhancements
* TouchFlo Settings (with StatusScreen)
* WM5torage v1.8
* Windows Live 10.6.0046.0800
* Windows Vista WMP Skin
* X2H Custom Startup Animation
* X2H Theme Pack (X2H Stripes, X2H Green & X2H I Use This Theme)
* X2H Tweaks
* X2H Wallpaper Pack(7HD Wallpapers)
* Xplode Keyboard Skin
Screen Shots:
(The wallpaper in the images is X2H Bliss by exhno, while default one is X2H Stripes by DuChene)
Change Log:
BETA:
-Initial Start
BETA2:
-Changed Build to 21812
-Larger & Finger Friendly Start Menu
-Downgraded Windows Live to v10.6.0046.800
Download Links:
BETA2: Rapidshare
Bạn đã cho hiện thư mục ẩn (Bin) trong thư mục down về chưa? Bạn làm hiện lên thư mục Bin đó rùi dùng RUU khác up thử xem. Mình up = RUU có sẵn trong đó cũng bị lỗi 300. RUU khác ok luôn!
cho mình hỏi bản 0.8 của cracing cài bàn phím khác sao không dùng được vậy nhỉ VD: fingerkeyboard hay ntd vnkey... (vào input config nó chỉ cho chọn 2 bản phím có sẵn khi soạn thảo click vào nhưng bản phím mới cài nó ko hiện ra) :|
Đối với trường hợp này thì tốt nhất bạn nên dùng PM SipChangeTool mà dùng(rất nhỏ gọn)
