ROM WM6.5 cập nhật dành cho HTC WIZARD
Thể theo nguyện vọng anh em, xin Mod box Wizard cho em lập ra Topic này để có thể cập nhật những bản ROM Wmo 6.5 mới nhất cho dòng Wizard!
b-)b-)b-)Các bản ROM Wm6.5b-)b-)b-)
CRACING's ROM
Ver 6.5.0.1.8
Ver 6.5.0.1.7 RC3
Ver 6.5.0.1.6
Ver 6.5.0.1.1
http://s289.photobucket.com/albums/ll214/0988456766/?action=view&current=4shared.pngVer 6.5.0.0.10 >>>>>>>>>>>>>>> Download: Link 4shared | link rapidshare
Ver 6.5.0.0.7 .............>>>>>>>>>>>>>>> Download: Link 4shared |link rapidshare
XDA2's ROM
Ver XDA v4.0......................................................ᗎᗎᗎᗎᗎᗎ Download:Xda2_v4.0
Ver XDA v3.0..........................................................ᗎᗎᗎᗎᗎᗎ Download:Xda2_v3.0
Ver Manila2D Interface built21202 : .........ᗎᗎᗎᗎᗎᗎ Download:Xda2 M2D
XDA2 CHome+LockScreen..................................ᗎᗎᗎᗎᗎᗎ Download:Xda2 CHome
cho em hỏi là máy em đang dùng bản room gốc bây giờ bum bản này thăng vào đc không bác??? QTEK 9100,chip G3....và nếu đc thì up như thế nào??? mong bác chỉ giáo. em gà qúa fải ko???8-|
ROM][WM6.5.x][21859 - 23064][Clean] - MSD™ Series
Windows Mobile 6.5.1 - 23064 - Clean
Dear Wizard Users,
Here it is the ROM I have cooked for Wizard.
As the title states, this is a clean ROM, but I have included some tools that I thought might be usefull. I also included ActiveSync and InternetSharing in this release.
I hope you enjoy it.
The tools are as follows:
Alt+Tab
Black Keyboard Skin
Bluetooth FTP
Comm Manager v2.9.5
HTC Album v2.5
HTC Calculator
HTC Camera
Microsoft New Contacts
Notepad
Obex Inbox
Office Mobile 2007
PIM Backup v2.8
psShutxp
SRS WOW HD
+ Standard WM6.5 Applications
Memory Details:
Storage - ~40MB Free.
Program - Maximum 27.5MB free.
ROM Version:
ROM Version : 6.5.1.0.1 Clean
OS Version : 6.5.1.0
OS Version:
Windows Mobile 6.5 Professional
CE OS 5.2.23064 ( Build 23064.5.3.0 )
ScreenShot:
I have attached the screenshot of this release. But please notice that I have customized it for myself on my device.
My Theme: Classic Blue + Installed dwizzy130 Clear 6.5.1 Tray QVGA.
Fixed Errors:
Fixed the "Time Zone" visibility in phone setting.
Applied a fix for Camera close (X) button. (As far as I don't have this problem, please test if it's fixed.)
Note 1: The first screenshot(s) are related to older releases.
Note 2: The provided package only contains the .nbf file, so you need to first find out the type of your device (G3 or G4), then try to install it on your device using the right updator utility.
Note 3: Please Soft-Reset after your device started completely.
LINK : http://rapidshare.com/files/290315090/MSD-Wizard-WM6.5-23064.rar
ScreenShot: http://img2.pict.com/a2/76/9b/1732717/0/800/screenshot23064clean.jpg
Có box hướng dẫn rùi mà bạn! Với máy của bạn như vậy, bạn cứ up vô tư! :D
Có 1 số lưu ý khi up ROM cho máy, bạn vào Box hướng dẫn up Rom đọc để hiểu cho rõ hơn nhé, không lỡ tay... "đi" em nó thì buồn :(
Version 6.5.0.3.0 Super Clean beta
Hello Brothers and Sisters,
These are beta releases so I'm not sure that they are bug free and/or stable. Feedback's are requested and I will try my best to solve the problems and issues. As usual the description is below, Please read it before downloading, flashing and using the ROM.
ROM Version :
ROM Version : 6.5.0.3.0 beta
OS Version : 6.5.0.0 WWE
Released Date : 10 OCT 2009
OS Version :
Preinstalled Softwares :
Advanced Config v3.3
Arcsoft MMS v5.2.3.22R1
Bluetooth FTP
Camara v3 ( Wizard )
Comm Manager ( MEGA )
Chome
Calculator
Connection Setup ( Topaz )
Dshow ( MEGA )
DotNet CF 3.5
Hibernate
HD Wallpapers
Internet Explorer v6
Modem Link
mHub ( Tachi )
mHubVO ( LEO )
OBEX Inbox v0.94
PIM Backup v2.8
SRS WOWHD With BT v1.2.10
SIM Mgr ( MEGA )
Notepad v1.6
TaskMgr v3.1
TouchFlo Scrolling
Windows Media Player v10.3
And more...
Games :
Bubble Breaker
Solitare
New Features :
Input Config : [ StartMenu -> Settings -> Personal -> Input Config ]
A small tweaking like app developed by me, for selecting/switching the inputs ( EzInputs <- OR - > Default Inputs ). You can select either EzInputs ( Full QWERTY ( Default ), Compact QWERTY and/or Phone Keypad ) or Default Inputs ( Keyboard ( Default ), Letter Recognizer and/or Block Recognizer ) to display/show in SIP list. After making any changes; Click apply and accept for softrebooting ( Highly Recommended ).
Modem Link : [ StartMenu -> Internet -> Modem Link ]
A same app which works same as internet sharing. For more info search for Modem Link, either here or google.
Log Report :
Added -
All the themes provided my M$.
Removed -
Magnifier Setup
Chome Editor
CleanRAM
YouTube
Build Changes -
GUI Interface.
Icons Image ( Theme ) .
Radio Box, Tick Box, Button and list box.
and some unknown...
Known Bugs/Errors :
1. When I apply a themes, it will be installed as cab. Shows remove entry on remove programs.
Reason/Solution : May be a build related problem/issue too. Just forget about that coz it doesn't give any problems.
2. Bottom bar is bigger and cannot use 3rd party keyboards and no sip selection icon.
Reason/Solution : Since M$ is making OS fingerfriendly, It takes some time to setup all correctly. No solutions found yet!
3. How can I use HTC Taskmanager from title bar in today screen?
Reason/Solution : Just tap on the clock ( lil bit right corner ) and taskmanager should come up. No solutions for disabling clock, found yet!
Memory Details :
Storage - 42+ MB Free.
Program - Min 20 MB ~ Max 25 MB Free
Before using the ROM, Read :
Warning & Important Notes on post #9 or click here
Before posting your problems, queries or etc, read :
FAQ on post #9 or click here
Download Link :
- Version 6.5.0.3.0 Super Clean beta -
http://www.mediafire.com/file/44yxjt4z3gh/CR96 THD v6.5.0.3.0 beta.7z
http://rapidshare.com/files/291043799/CR96_THD_v6.5.0.3.0_beta.7z
nếu thick thì thanks 1 cái cũng không có sao :)
[ROM][WM6.5.x][6.5.1.4 - 23071][6.5.0.2 - 21869][Clean] - MSD™ Series >> 15-Oct-2009
Windows Mobile 6.5.1.4
Build 23071 - Clean
Alt+Tab
Black Keyboard Skin
Bluetooth FTP
HTC Album v2.5
HTC Calculator
HTC Camera Applied fix
HTC Comm Manager v2.9.5
Microsoft Office Mobile 2007
Microsoft New Contacts New
Notepad
Obex Inbox
PIM Backup v2.8
psShutxp
SRS WOW HD
Memory Details:
Program - Maximum 27.5MB free (Using Oxios Hibernate).
ROM Version:
ROM Version : 6.5.1.4 Clean
OS Version:
CE OS 5.2.23071 ( Build 23071.5.3.0 )
ScreenShot:
My Theme: amarullzGreenBlack Theme
Download: RapidShare Link 6.5.1.4 - (Build 23071)
http://www.mediafire.com/download.php?0hjzeyziyun
CR96 Touch HD™ v6.5.0.3.1 beta Build 23064
ROM Version : 6.5.0.3.1 beta
Released Date : 12 OCT 2009
OS Version :
* Advanced Config v3.3
* Arcsoft MMS v5.2.3.22R1
* BtCrawler v1.1.0
* Bluetooth FTP
* Camara v3 ( Wizard )
* Comm Manager ( MEGA )
* ClearTemp v1.2
* Chome
* Connection Setup ( Topaz )
* EzInput v1.5 ( Iolite )
* Dshow ( MEGA )
* HTC's Mixed Ringtones
* DotNet CF 3.5
* Hibernate
* HD Wallpapers
* HTC Album ( Iolite )
* HTC Audio Manager ( MEGA )
* HTC Calculator ( LEO )
* HTC Task Manager v2.1
* Internet Explorer v6
* Input Config v0.3ei
* MS Office 6.1
* Modem Link
* mHub ( Tachi )
* mHubVO ( LEO )
* OBEX Inbox v0.94
* PIM Backup v2.8
* PDAcraft Paint v1.1.2
* RSSHub ( MEGA )
* Synchro Time 0.94
* SRS WOWHD With BT v1.2.10
* SmartLock v1.7E
* SIM Mgr ( MEGA )
* SIPChange v2
* Notepad v1.6
* TaskMgr v3.1
* TouchFlo Scrolling
* UITweaker
* Voice Recorder ( MEGA )
* Widgets ( WMLiveSearch, WMMoney, WMWeather ).
* Windows Media Player v10.3
* Youtube
* And more...
Games :
* Bubble Breaker
* Chess
* Kevtris
* Pocket Sand
* Pocket Sudoku
* Solitare
* Pocket Gravity
New Features :
Log Report :
Added -
* All the themes provided my M$.
Removed -
* Magnifier Setup
* Chome Editor
* CleanRAM
* YouTube
Build Changes -
* GUI Interface.
* Icons Image ( Theme ) .
* Radio Box, Tick Box, Button and list box.
* and some unknown...
Memory Details :
Program - Min 20 MB ~ Max 24 MB Free
Download
http://rapidshare.com/files/292073484/CR96_THD_v6.5.0.3.1_beta.7z
[ROM][WM6.5.x][6.5.1.5 - 23075][6.5.0.2 - 21869][Clean] - MSD Series >> 23-Oct-2009
Windows Mobile 6.5.1.5
Build 23075 - Clean
Dear Wizard Users,
As the title states, this is a clean ROM, but I have included some tools that I thought might be usefull. I also included ActiveSync and InternetSharing in this release. In this release you do not need to arrange the start menu icons anymore, I arranged them for you the way I thought it might be useful. I hope you enjoy using it.
Alt+Tab
Black Keyboard Skin
Bluetooth FTP
HTC Album v2.5
Notepad
Obex Inbox
PIM Backup v2.8
psShutxp
SPB Calculator
SRS WOW HD
Memory Details:
ROM Version:
ROM Version : 6.5.1.5 Clean
OS Version:
CE OS 5.2.23075 ( Build 23075.5.3.0 )
ScreenShot:
My Theme: amarullzBlueBlack Theme
RapidShare Link 6.5.1.5 - (Build 23075) http://rapidshare.com/files/296604389/MSD-Wizard-WM6.5-23075.rar
(Mirror) http://www.mediafire.com/?ojgtmydtfom
(ScreenShot) http://img2.pict.com/53/2e/4b/1820037/0/800/screenshot23075clean.jpg
Thanks rùi anh em còn có hứng post tiếp :)
[ROM][WM6.5.x][6.5.1.6 - 23081][6.5.0.2 - 21869][Clean] - MSD Series >> 25-Oct-2009
Windows Mobile 6.5.1.6
Build 23081 (New GUI) - Clean
Dear Wizard Users,
Alt+Tab
Black Keyboard Skin
Bluetooth FTP
HTC Album v2.5
Notepad
Obex Inbox
PIM Backup v2.8
psShutxp
SPB Calculator
SRS WOW HD
Memory Details:
ROM Version:
ROM Version : 6.5.1.6 Clean
OS Version:
CE OS 5.2.23081 ( Build 23081.5.3.0 )
ScreenShot:
My Theme: DVFGreen + dwizzy130's WM6.5 Clear Buttons
Download: RapidShare Link 6.5.1.6 - (Build 23081)
http://rapidshare.com/files/297626383/MSD-Wizard-WM6.5-23081.rar
(ScreenShot)
http://img2.pict.com/1c/dd/a2/1834614/0/800/screenshot23081clean.jpg
Rom cho Wizard ra liên tục nhỉ, để em test thử thằng này xem sao rồi sẽ phát biểu cảm nhận cho các bác rõ :)
Bản rom mới này vẫn còn khá nhiều lỗi.
1.Không thay đổi được màu sắc theme khi dùng Spb 3.5
2.Không mở được wifi ( hình như không hề hỗ trợ wifi )
3.Không thay đổi chế độ từ bình thường sang yên lặng hay rung khi nhấn giữ nút Beam...
Trước mắt thấy có nhiêu đó...
những rom sau này cái thanh phóng to taskbar khj mình click vào biểu tượng trên pin hay những biễu tượng trên taskbar nó che mất task manager khi click vào clock.Bạn nào tắt được cái thanh phóng to này thì chỉ giúp mình
Windows Mobile 6.5.1.7
Build 23085 (New GUI) - Clean
Dear Wizard Users,
As the title states, this is a clean ROM, but I have included some tools that I thought might be usefull. In this release you do not need to arrange the start menu icons anymore, I arranged them for you the way I thought it might be useful. I hope you enjoy using it.
Alt+Tab
Black Keyboard Skin
Bluetooth FTP
HTC Album v2.5
Notepad
Obex Inbox
PIM Backup v2.8
psShutxp
SPB Calculator
SRS WOW HD
Memory Details:
Storage - ~39MB Free.
ROM Version:
ROM Version : 6.5.1.7 Clean
OS Version:
CE OS 5.2.23085 ( Build 23085.5.3.0 )
ScreenShot:
My Theme: amarullz's BlueBlack Theme
Download:
http://rapidshare.com/files/302071329/MSD-Wizard-WM6.5-23085.rar
http://www.mediafire.com/download.php?3tmtt4izann
CRACING Version 6.5.0.3.2 beta
ROM Version :
ROM Version : 6.5.0.3.2 beta
Released Date : 11 NOV 2009
OS Version :
CE OS 5.2.23506 ( Build 23506.5.5.0 )
* BtCrawler v1.1.0
* Bluetooth FTP
* ClearTemp v1.2
* Chome
* Dshow ( MEGA )
* DotNet CF 3.5
* Hibernate
* HD Wallpapers
* MS Office 6.1
* Modem Link
* mHub ( Tachi )
* mHubVO ( LEO )
* OBEX Inbox v0.94
* PIM Backup v2.8
* RSSHub ( MEGA )
* Synchro Time 0.94
* SmartLock v1.7E
* SIM Mgr ( MEGA )
* SIPChange v2
* Showcase Suite v1.1.0
* Notepad v1.6
* TaskMgr v3.1
* Youtube
* And more...
Games :
* Bubble Breaker
* Chess
* Kevtris
* Pocket Sand
* Pocket Sudoku
* Solitare
* Pocket Gravity
New Features :
Showcase Suite : [ StartMenu -> Settings -> System -> Showcase ]
Works same as HTC Task Manager but no quick task list lcon on today screen top bar or etc. To task list on today screen or any screens, press and hold Windows flag icon. Press and hold X button to close the app and just tap X button to minimize.
Log Report :
Added -
* Showcase Suite
* UITweaker
Removed -
* PDAcraft Paint
Known Bugs/Errors :
Reason/Solution : Just tap on the clock ( lil bit right corner ) and taskmanager should come up. No solutions for disabling clock found yet!
Note: Doesn't work on latest builds.
Memory Details :
http://www.mediafire.com/file/ytrjitudzam/CR96 THD v6.5.0.3.2 beta.7z
Đang up thử :D:D hình như 2pic đang chậm lại, bữa h hok thấy rom mới, trên xda cũng vậy.Nhưng rom này free ram ít wa, có bản clean ko bồ?
vừa mới úp xong.không hỗ trợ font tiếng Việt sao bác!đẹp!:O
Nhưng mà nặng quá! 8125 kéo muốn điên.nó hết chạy rùi,h chỉ bò thôi!
Mình mới up rom lên 6.5, công nhận giao diện đẹp, có thể cạnh tranh với giao diện iphone, nhưng hơi nặng nề, mất trên 55% ram, đổi lại thấy sưóng con mắt. chạy ổn định. =D>
Những rom này,vừa cài xong thì free ram 24~27mb, nhưng xài khoảng từ 1-2 ngày thì free ram chỉ còn 13~15mb thôi,soft reset lại thì free ram trở lại bình thường,h thấy box dậm chân tại chỗ, ko còn rom mới nữa..Bùn thiệt
mình đã test qua tất cả các bản room này
mình khuyên các bạn chỉ nên cài đặt bản room
bản này pro nhất chay ngon lành cành đào
mình đã từng cài rất nhiều bản room nhưng chưa thấy
bản nào chạy mượt mà mà không thấy lỗi nào như bản nỳ
bản mới nhất của CR chạy lề mề mà lại tốn pin kinh hồn
đây chỉ là ý kiến của mình, nếu không phải mong các bạn thứ lỗi
