TP.HCM Samsung Galaxy S i9003 Fix boot ok !
Taki7610
Unlock_GSM
Mã:
[6/27/2013 10:15:37 AM] [START OPERATION_ID = DCC_READ_MEMORY]
[6/27/2013 10:15:37 AM] Current Settings:
[6/27/2013 10:15:37 AM] -----------------
[6/27/2013 10:15:37 AM] Address: 			000000000000
[6/27/2013 10:15:37 AM] Length: 			000000000000
[6/27/2013 10:15:37 AM] Address Space: 		RAM
[6/27/2013 10:15:37 AM] AutoFullFlash: 		UNCHECKED
[6/27/2013 10:15:37 AM] Use End Address: 		UNCHECKED
[6/27/2013 10:15:37 AM] ECC Module Enabled: 	UNCHECKED
[6/27/2013 10:15:37 AM] Image File is Used: 	UNCHECKED
[6/27/2013 10:15:37 AM] Use Address as Offset: 	UNCHECKED
[6/27/2013 10:15:37 AM] Main (UNCHECKED):
[6/27/2013 10:15:37 AM] Redu (UNCHECKED):
[6/27/2013 10:15:39 AM] Open serial port...OK
[6/27/2013 10:15:39 AM] Connecting to the RIFF Box...OK
[6/27/2013 10:15:39 AM] Firmware Version: 1.35, JTAG Manager Version: 1.49
[6/27/2013 10:15:39 AM] Selected Resurrector: [Samsung I9003 (via IRAM) V1.0.4464.49936]
[6/27/2013 10:15:39 AM] Connecting to the dead body...FAILED
[6/27/2013 10:15:39 AM] None is detected.
[6/27/2013 10:15:39 AM] [FINISH OPERATION_ID = DCC_READ_MEMORY]
[6/27/2013 10:15:44 AM] [START OPERATION_ID = GET_DEVICE_ID]
[6/27/2013 10:15:45 AM] Open serial port...OK
[6/27/2013 10:15:45 AM] Connecting to the RIFF Box...OK
[6/27/2013 10:15:45 AM] Firmware Version: 1.35, JTAG Manager Version: 1.49
[6/27/2013 10:15:45 AM] Selected Resurrector: [Samsung I9003 (via IRAM) V1.0.4464.49936]
[6/27/2013 10:15:45 AM] Connecting to the dead body...ERROR
[6/27/2013 10:15:45 AM] Set I/O Voltage reads as 1.81V, TCK Frequency is 2 MHz
[6/27/2013 10:15:45 AM] None is detected.
[6/27/2013 10:15:45 AM] [FINISH OPERATION_ID = GET_DEVICE_ID]
[6/27/2013 10:16:40 AM] [START OPERATION_ID = RESURRECT]
[6/27/2013 10:19:50 AM] Open serial port...OK
[6/27/2013 10:19:50 AM] Connecting to the RIFF Box...OK
[6/27/2013 10:19:50 AM] Firmware Version: 1.35, JTAG Manager Version: 1.49
[6/27/2013 10:19:50 AM] Selected Resurrector: [Samsung I9003 (via IRAM) V1.0.4464.49936]
[6/27/2013 10:19:50 AM] Connecting to the dead body...OK
[6/27/2013 10:19:50 AM] Detected dead body ID: 0x0B6D602F - IGNORED!
[6/27/2013 10:19:50 AM] Set I/O Voltage reads as 1.81V, TCK Frequency is 2 MHz
[6/27/2013 10:19:50 AM] Resurrection sequence started.
[6/27/2013 10:19:50 AM] Establish communication with the phone...OK
[6/27/2013 10:19:50 AM] Initializing internal hardware configuration...OK
[6/27/2013 10:19:50 AM] Uploading resurrector data into memory...OK
[6/27/2013 10:19:50 AM] Starting communication with resurrector...OK
[6/27/2013 10:19:50 AM] Detected an Initialized FLASH1 Chip, ID: 0x00EC/0x0050 (512MB)
[6/27/2013 10:19:50 AM] Flashing the dead body...
[6/27/2013 10:19:50 AM] ERROR: Timeout while waiting for DCC Loader response. Trying to recover...FAILED
[6/27/2013 10:19:50 AM] ERROR: Failed due to multiple communication errors. Terminating at 0x00000108D000
[6/27/2013 10:19:50 AM] [FINISH OPERATION_ID = RESURRECT]
[6/27/2013 10:19:51 AM] [START OPERATION_ID = RESURRECT]
[6/27/2013 10:19:54 AM] Open serial port...OK
[6/27/2013 10:19:54 AM] Connecting to the RIFF Box...OK
[6/27/2013 10:19:54 AM] Firmware Version: 1.35, JTAG Manager Version: 1.49
[6/27/2013 10:19:54 AM] Selected Resurrector: [Samsung I9003 (via IRAM) V1.0.4464.49936]
[6/27/2013 10:19:54 AM] Connecting to the dead body...OK
[6/27/2013 10:19:54 AM] Detected dead body ID: 0x0B6D602F - CORRECT!
[6/27/2013 10:19:54 AM] Set I/O Voltage reads as 1.81V, TCK Frequency is 2 MHz
[6/27/2013 10:19:54 AM] Resurrection sequence started.
[6/27/2013 10:19:54 AM] Establish communication with the phone...OK
[6/27/2013 10:19:54 AM] Initializing internal hardware configuration...FAILED
[6/27/2013 10:19:54 AM] ERROR: Wrong response code from the RIFF Box: 0x81
[6/27/2013 10:19:54 AM] [FINISH OPERATION_ID = RESURRECT]
[6/27/2013 10:21:29 AM] [START OPERATION_ID = RESURRECT]
[6/27/2013 10:21:34 AM] Open serial port...OK
[6/27/2013 10:21:34 AM] Connecting to the RIFF Box...OK
[6/27/2013 10:21:34 AM] Firmware Version: 1.35, JTAG Manager Version: 1.49
[6/27/2013 10:21:34 AM] Selected Resurrector: [Samsung I9003 (via IRAM) V1.0.4464.49936]
[6/27/2013 10:21:34 AM] Connecting to the dead body...FAILED
[6/27/2013 10:21:34 AM] None is detected.
[6/27/2013 10:21:34 AM] [FINISH OPERATION_ID = RESURRECT]
